SPC vs. Total Chaos UCA
Discussion in 'Suspension' started by Dustydirt19, Nov 12, 2016.
  1. Nov 12, 2016 at 11:37 AM
    Dustydirt19
    Dustydirt19 [OP] Hoghead
    Dustin
    Duluth, MN
    2015 Blue Ribbon Metallic 5.7L 4WD SR5 TRD DC
    ProComp 6" stage 2 lift 18x9 Fuel Vapor -12 offset 35x12.5 Nitto Ridge Grapplers BullyDog Tuner Gibson Metal Mulisha cat-back exhaust, S&B cold air intake, Color matched TRD PRO Grille, Compustar Remote Start N-Fab Hooped Nerf Bars, AMI Big stick antenna, Salex organizer and tray, Weathertech laser cut floor mats, Weathertech window deflectors Black out badge Black out front and rear bumper Black out flags 24/7 black out TRD Off-road decals Spray in Line-X Bedliner Scosche phone mount Soft rolling tonneau cover TRD pedals and footrest
    was curious on pros and cons between these 2 UCAs. SPC seems like they are more adjustable but the TC seems more heavy duty. thoughts?
  2. Nov 12, 2016 at 2:15 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Spc is a ball joint.
    TC is a uniball.
    SPC requires less maintenence.
    TC has a greater range of motion.
    SPC uses grease.
    TC uses dry lube.
    SPC has a lot of adjustablility for caster and camber. Could lead to more expensive alignment if the shop doesn't understand the adjustments.
    FlashCulprit, joonbug and T-Rex266 like this.
  3. Nov 12, 2016 at 2:33 PM
    Dustydirt19
    Dustin
    Duluth, MN
    Which would you suggest? the price difference doesn't bother me.
  4. Nov 12, 2016 at 3:46 PM
    That depends if you want maintenance or maintenance free. I have SPC and they're solid. Hell, our resident Toyota mechanic, @LOTSOFTOYS even recommends them
    Dustydirt19[OP] likes this.
  5. Nov 12, 2016 at 3:51 PM
    Dustydirt19
    Dustin
    Duluth, MN
    Which one is maintenance free? SPC?
  6. Nov 12, 2016 at 3:55 PM
    Ya. SPC
  7. Nov 12, 2016 at 3:58 PM
    dragos28
    dragos28 New Member
    dragos
    tundra
    nothing much
    TC if you wheel your truck
  8. Nov 12, 2016 at 3:59 PM
    csuviper
    Broomfield, CO
    I got the TC. Had SPC on my Tacoma. Decided to go for more travel.
  9. Nov 12, 2016 at 4:14 PM
    Dustydirt19
    Dustin
    Duluth, MN
    Ok thanks
  10. Nov 12, 2016 at 4:17 PM
    Dustydirt19
    Dustin
    Duluth, MN
    Thanks guys. does it matter for wheel size? like can you get bigger wheels and less cutting with one or the other?
  11. Nov 12, 2016 at 4:19 PM
    Yes. On my 2012 it rubbed at certain angles with stock uca
  12. Nov 12, 2016 at 4:27 PM
    Dustydirt19
    Dustin
    Duluth, MN
    But between the 2 can you get bigger tires with one or the other?
  13. Nov 12, 2016 at 4:29 PM
    Dustydirt19
    Dustin
    Duluth, MN
    I want 35s or as close as I can get with the least amount of trimming
  14. Nov 12, 2016 at 6:49 PM
    I have SPC and have 35"
    A lot will depend on your offset
  15. Nov 12, 2016 at 7:33 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Spc are very user friendly. simple, no maintenance and adjustable. TC or anyother uniballs uca are much stronger, requires maintenance and are not adjustable... depends on what u r gonna do with the truck really
  16. Nov 12, 2016 at 8:42 PM
    scotch
    scotch New Member
    Denver, CO
    2010 Tundra
    2010 Tundra Method 20x9 Fat Fives 18offset, 305/55/20 Duratracs, Bilstein 6112/5160, SPC/LR Upper Control Arms, TRD Rear Swaybar, OME/Dakar leafs with CB +1 Shackles, Husky Weatherbeaters, Du-Ha, Extang Solid Fold, Line-X, Toyota Bed Mat, Stoptech Cryo Rotors and pads, Goodridge brake lines, Stoptech STR-660, Rigid Fog Lights, Odyssey Battery, Firestone Airbags with CB spacer, etc, etc... Previous Toyota's: 97 4runner, 02 tacoma, 09 tacoma
    I have the SPC's on three toyota's (4runner, tacoma, and tundra). They've performed well. 80,000 miles on one set with no issues.
    Dustydirt19[OP] and T-Rex266 like this.
  17. Nov 12, 2016 at 9:57 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Hmm....piqued my interest now
    zcarpenter92 likes this.
  18. Nov 13, 2016 at 4:00 AM
    Dustydirt19
    Dustin
    Duluth, MN
    As always guys thanks for the help. I really appreciate it. im just trying to get all the info in everything so I can save up and have everything put on at once. don't want any unwanted surprises
  19. Nov 13, 2016 at 4:14 AM
    Dustydirt19
    Dustin
    Duluth, MN
    I don't really want anyone hacking on my truck and I want to have to option to off road so tell me your thoughts on this...
    Toytec Boss 3" full lift
    SPC UCA
    Toytec shackles
    295 70 18 tires
    18x9 wheel either +18 or +12 offset ( want them flush with bushwacker fender flares or sticking out just a tad )
    That sound pretty solid? shouldn't have to cab mount chop or trim bumpers or anything?
    the only other change I would make is maybe 305 70 18 tires but I believe you guys told me I'd have to do a cab mount chop and bumper trim with that right? I can deal with losing a little height and width if I can get away without having to chop and trim
  20. Nov 13, 2016 at 7:05 AM
    chphilo
    chphilo Tundra addict
    Western PA
    Go with 18. I have 18 and my tires are only few mm from the body mounts. 12 would've rubbed. Other components look solid.
  21. Nov 13, 2016 at 7:31 AM
    csuviper
    Broomfield, CO
    All look like good choices. I would also go with +18.
    305/70R18 is 35" diam and 12.5 width. You will. We'd to trim front plastic and cab mount chop most likely.
    295/70R18 is a 34.25" diam and 12" width. You probably will need to trim the plastic in the wheel well.
  22. Nov 13, 2016 at 8:10 AM
    Go with the larger tire size....let your balls drop and just get the cmc done :)
  23. Nov 13, 2016 at 10:03 AM
    Dustydirt19
    Dustin
    Duluth, MN
    Does yours rub at full lock with suspension compressed?
  24. Nov 13, 2016 at 10:05 AM
    Dustydirt19
    Dustin
    Duluth, MN
    Do you guys have pics of what you had to trim or a dyi on it? the cab mount I'm familiar with. plastic and bumper trimming or heating the fender wells with a heat gun I'm not
  25. Nov 13, 2016 at 10:12 AM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    I'd go with +18 if you want to minimize trimming. Check my build thread if you want to check out what I trimmed to fit +12 on my 3" lift.
  26. Nov 13, 2016 at 1:59 PM
    chphilo
    Western PA
    Mine did rub at full lock and I pushed in the plastic liner and rescrewed bottom screws (I understand this procedure is somewhat more difficult with 2014+). I have no more rub. I have 3.5 OME lift and 295/70/18 Nitto Trail Grappler. I am not sure about full compression since I don't really go off road in any serious way.
  27. Nov 13, 2016 at 2:28 PM
    Dustydirt19
    Dustin
    Duluth, MN
    Thanks. huge help!!
    BlueBottle[QUOTED] likes this.
  28. Nov 13, 2016 at 2:30 PM
    Dustydirt19
    Dustin
    Duluth, MN
    Ok thanks I appreciate it. im not doing anything serious either just your typical Northwoods redneck mud running
  29. Nov 16, 2016 at 9:09 AM
    Dilsky
    Dilsky Toyota Brand *****
    Shawn
    Edmonton, Alberta
    2014 Platinum Tundra Crewmax Black
    King Front Coil-overs Coachbuilder shims Toytec Rear shackles - Stock Rear Baja Designs Sport Fog Lights Rough Country 30" Lightbar 18" Method Roost Wheels (Bronze) 285/70/R18 Nitto Exo Grapplers Diamondback HD Cover
    Hmm I am looking at the same thing...now to find a sale on SPC UCAs.....anyone anyone?
  30. Nov 16, 2016 at 9:16 AM
    TheBeast The Beach
    I'm going with TCs and coilovers on my future setup.
    here is my front liner after last weekend: 33x12x18 with +18 offset and pro comp spacers in front.
