SPC uppers
Discussion in '1st Gen Tundras (2000-2006)' started by Aaol1, Oct 23, 2023.
  1. Oct 23, 2023 at 10:01 AM
    Aaol1
    Aaol1 [OP] New Member
    Sam
    05 DC tundra TRD offroad 4x4 V8 w/ LSD and tow
    2 inch lift, diff drop
    So I put in the SPC uppers, and I get the whole adjustment part except for one thing. The top bolt has the ability to slide ( when loosened) towards truck or away from truck, as in pic. The SPC instructions don't actually mention this bolt or where to set it, aside from torque specs. In guessing since is slides, it's to due with alignment? If so, what would be a good preliminary spot to put it in?
    AggiePhil likes this.
  2. Oct 23, 2023 at 10:09 AM
    I swear their instructions did for me, and suggested setting it close to center, and to clock the UBJ at a specific position, "D".
    You need to be careful to torque that down to at least 100-125lbft to lock it in before putting vehicle weight on it, with a final on-the-ground torque of 150 so it doesn't shift when you lower the truck. And VERY sure the little star-holed rectangular piece under the arm which allows it to slide is FIRM in the slot.
    Furthermore, double-check the torque and clocking position after alignment. Shops don't seem to know wtf to do with that thing.
    digitalferg likes this.
  3. Oct 23, 2023 at 10:13 AM
    Aaol1
    Sam
    Yea alright I'll put it closer to center, yea unfortunately I don't have a big enough torque wrench , I'll have to figure that out. Thanks!
  4. Oct 23, 2023 at 10:15 AM
    Proof, and a warning about the star plate, and note the caster is mirrored from left to right, although the neutral setting "D" has the logo perfectly parallel to the door skins on each side:
  5. Oct 23, 2023 at 10:17 AM
    This is an excellent budget split-beam wrench. Doesn't require you setting torque to zero when done with use, and has ample length for great leverage. https://www.amazon.com/gp/product/B0B4BFXNJ9?ie=UTF8
    You'll also need a 1-1/4" socket IIRC. You'll be using this in other places on your truck if your current wrench can't do 90+
  6. Oct 23, 2023 at 10:19 AM
    Aaol1
    Sam
    Yea I've got the socket already, and kk I must have missed the center position thing , I'll check my instructions again, but I probably just missed it. Thanks!
  7. Oct 23, 2023 at 10:22 AM
    Not trying to harp, but sometimes missing little details can really bite you in the ass later. I'm not a hardcore "RTFM" kinda guy, but when it involves something that could easily end my life or cost ample $$$$ if missed, well, I read it twice or thrice :rofl:
    During my coilover install, I actually read the instructions so hard I found a pretty signifcant typo in Toytec's instructions! I hope they've fixed that by now.
    M3Tundra-JK and Tundra2 like this.
  8. Oct 23, 2023 at 10:31 AM
    Aaol1
    Sam
    Haha yea fair enough no I definitely won't skimp on this one, I'll buy a torque wrench if I have to.
    Question on alignment specs, I read the number as per this post:
    Question on C or D, so if I understand correctly C got you closer to the number on the post, but D got you closer to OEM? Why would we aim for those different numbers VS OEM?
  9. Oct 23, 2023 at 10:37 AM
    So here's the deal.
    *In theory* if you clock the UBJ at 'D' and set the balljoint in the center of the slot, you'll probably end up in damn near back in alignment. I'd always take it to a shop to check, but I was damn near dead-nuts on after my CO and UCA install.
    If you intend to hit @assassin10000's recommended high-caster numbers, especially if you go to a big-box shop who never deals with custom suspension/offroad suspension (therefore they will know fuckall about these SPC arms), I would personally clock the UBJ to 'C' on both sides - i.e. the flat face of the balljoint will rotate one notch toward the front bumper, SPC logo facing toward the bumper corner - then the shop can probably get away with their usual toe-and-go, and only manage minimal dial-in for camber/caster using the LCA cams.
    I'm not the expert on this, I do not do this for a living, nor regularly. So you may want to hang around for a 2nd opinion.
    M3Tundra-JK and AggiePhil like this.
  10. Oct 23, 2023 at 11:02 AM
    Aaol1
    Sam
    Kk good to know . I'm also doing Lowers and can bolts and the old alignment was garbage, so I don't have a good starting spot... I think I'll leave it in D and see where it goes
  11. Oct 23, 2023 at 11:20 AM
    If you haven't done the LCAs yet, You can mark all four positions on your cams with a paint marker to tag center and replicate with the new ones, it should get you pretty close.
    Honestly, you can get any vehicle aligned 90% of the way there with a tape measure and a 3ft level. It's how I confirmed mine, the shadetree/goodnuff way
    Tape measure to get the front edges of your tires as close as possible to the rear edge, but if you don't spin in/out your tie rods, you may find it's already OK. Use a section of 2x4 laying flat against the sidewall of both tires to get a good measurement.
    Then use the level to set the camber vertically plomb.
    So we're clear on those terms and what they mean... Camber set with level; toe set with TRE. Is it perfect? No. Good enough to drive 30mi to get a pro alignment? Totally.
  12. Oct 23, 2023 at 11:49 AM
    Aaol1
    Sam
    Yea exactly, I get the gist of how it works but I'm happy to pay a shop for this , I've also changed the tie rod ends. Everything is getting out back to what it was approximately before ( cam bolts going back to what they were before) so I'll be back to a shitty alignment like it was before, lol. Uppers were the only variance due to now being SPC.
    Lowers are already out , cam bolts all cut. I couldn't do a good mark because of fluid film and rusty garbage, but I took pics of all of them so I'll get em close enough
    shifty` likes this.
  13. Dec 20, 2023 at 7:29 PM
    AggiePhil
    AggiePhil Texas Chapter President
    College Station, TX
    2020 Smoked Mesquite Platinum 4x4
    I’m reading 32mm everywhere else. Will 1 1/4” work? Don’t want to get the wrong thing.
  14. Dec 20, 2023 at 8:00 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    32mm is 1.259".
    You'll be fine with either.
  15. Dec 20, 2023 at 8:31 PM
    What Assassin said, but I’d just add, I’m coming from a lifetime of working on mostly GM vehicles, primarily trucks. Thus mostly standard tools when it comes to weirdly large sizes. Just so happens the conversion works here, similar to how 3/4” is a good sub for 19mm (.02” diff’ce)
    AggiePhil[QUOTED] likes this.
  16. Dec 20, 2023 at 9:55 PM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Thanks man! I installed these recently and must've missed that line. Mine is closer to the outside edge, and it makes the steering knuckle sit REALLY close to the tire. Only a finger width between the two. I'll get this corrected over the weekend
  17. Dec 20, 2023 at 10:05 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    Ahhhh...the good ol 32mm and 1-1/4”. My KTM 990R uses those sizes for the front axle nut, rear axle nut, counter sprocket nut, and clutch center nut. One size to rule them all! I went as far as to engrave the socket size (and torque spec) onto the nuts.
    shifty` likes this.
  18. Dec 20, 2023 at 10:08 PM
    whodatschrome
    lots of dents
    How much space is required or recommend? I think i have about 7/8 of a finger’s width of space between my tire and the stock UCA.
  19. Dec 21, 2023 at 12:35 AM
    M3Tundra-JK
    Scott
    2005 GX470
    Not sure but it seemed awfully close. These are stock rims, though. I have a set if TRD rims that will go on soon, no tires on them yet. But the TRD's offset should push the tire away from the knuckle some
  20. Dec 21, 2023 at 12:40 AM
    M3Tundra-JK
    Scott
    2005 GX470
    Actually, my instructions didn't include that line. They must've done a revision at some point. But also I haven't gotten around to adjusting anything yet since it's a project vehicle under construction
  21. Dec 21, 2023 at 6:26 AM
    AggiePhil
    College Station, TX
    I thought all the Toyota wheels had the same offset, with the exception of the Rock Warriors.
  22. Dec 21, 2023 at 7:09 AM
    That sheet is for the SPC 25470, which I believe is for Tacomas: https://www.spcalignment.com/component/spc/?task=part_description&pid=25470
    Instructions: https://www.spcalignment.com/instructions/25470-INS_WEB.pdf
    The sheet I shared is for SPC 25485 which most of us used our Tundras (and is also sold by Eibach + one other company I won't mention): https://www.spcalignment.com/new-products/299-toyota-light-truck-ucas-25485
    Instructions: https://www.spcalignment.com/instructions/25485-INS_WEB.pdf
    I don't think I knew SPC was offering a new, maintenance-free (zerkless) upper balljoint for these. Interesting. I wonder what longevity of that BJ looks like compared with the greasable version?
    M3Tundra-JK[QUOTED] likes this.
  23. Dec 21, 2023 at 7:11 AM
    Depends on which year and vehicle you're talking about. Some folks using newer Tacoma wheels have found different fitment than the 1st Gen OEM alloys
  24. Dec 21, 2023 at 7:28 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    The steelies I had OEM are about 1"+ offset from the OEM starfish
  25. Dec 21, 2023 at 8:42 AM
    AggiePhil
    College Station, TX
    My bad, didn’t realize this was the 1st Gen forum. In the 2nd Gen world, all OEM wheels have the same offset with the exception of Rock Warrior.
  26. Dec 21, 2023 at 8:44 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
