SPC upper control arms
Discussion in 'Suspension' started by Phillipk98, Jun 11, 2017.
  1. Jun 11, 2017 at 5:28 PM
    Phillipk98
    Phillipk98 [OP] 05 sequoia
    2005 sr5 sequoia
    Has anyone used the SPC UCAs off toytec's website? I'm piecing together a 4 inch lift and thinking of going with these. Any input is appreciated. Thanks guys.
    Toytec Lifts likes this.
  2. Jun 11, 2017 at 5:29 PM
    Yep. I use them
    Rica25, MotoTundra, Noodle and 2 others like this.
  3. Jun 11, 2017 at 6:03 PM
    Phillipk98
    2005 sr5 sequoia
    Sweet thanks. Do you like them? I'm putting them on an 03.
  4. Jun 11, 2017 at 6:04 PM
    chphilo
    chphilo Tundra addict
    Western PA
    I've had them (along with the OME kit) for over 3 years now. Maintenance-free and no issues.
    Rica25, Patriot, JC303 and 1 other person like this.
  5. Jun 11, 2017 at 6:05 PM
    Phillipk98
    2005 sr5 sequoia
    Hell yeah thanks guys.
  6. Jun 11, 2017 at 6:13 PM
    No issues here. Great customer service as well.
    mtntop, Rica25 and Patriot like this.
  7. Jun 11, 2017 at 6:25 PM
    Basskrazee
    Basskrazee Pop
    Joe
    Indianapolis, IN.
    2016 Tundra SR5 /TRD
    AFE mass air intake TRD rear anti sway bar Headwaters seat covers TRD Pro grill Bilstien 6112 coil overs Bilstien 5160 rear shocks Consol vault
    Sean266
    How high did you lift your truck?
  8. Jun 11, 2017 at 6:29 PM
    3.5"
    Rica25 likes this.
  9. Jun 11, 2017 at 7:41 PM
    scotch
    scotch New Member
    Denver, CO
    2010 Tundra
    2010 Tundra Method 20x9 Fat Fives 18offset, 305/55/20 Duratracs, Bilstein 6112/5160, SPC/LR Upper Control Arms, TRD Rear Swaybar, OME/Dakar leafs with CB +1 Shackles, Husky Weatherbeaters, Du-Ha, Extang Solid Fold, Line-X, Toyota Bed Mat, Stoptech Cryo Rotors and pads, Goodridge brake lines, Stoptech STR-660, Rigid Fog Lights, Odyssey Battery, Firestone Airbags with CB spacer, etc, etc... Previous Toyota's: 97 4runner, 02 tacoma, 09 tacoma
    i have them on my Tundra and 4runner for 3+ years, and on my old tacoma for 3 years. Works perfectly.
    T-Rex266 likes this.
  10. Jun 11, 2017 at 7:58 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    I gots them too. No issues.
    MotoTundra and T-Rex266 like this.
  11. Jun 11, 2017 at 8:35 PM
    dmeneses1983
    dmeneses1983 New Member
    Dennis
    2016 Silver Tundra
    got them as well and installed them a week ago and no issues. I have a 4" lift in the fron and ride is close to stock
    Les7311 and T-Rex266 like this.
  12. Jun 11, 2017 at 10:21 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Had them on my Tacoma. No issues. Very adjustable.
    Went with Total chaos with the Tundra.
    Sefferston likes this.
  13. Jun 12, 2017 at 3:06 AM
    Phillipk98
    2005 sr5 sequoia
    Thanks guys. Great input. I appreciate
  14. Jun 12, 2017 at 3:12 AM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    How long it took you to install them? Out of 10 being the worst, what's difficulty level?
  15. Jun 12, 2017 at 7:19 AM
    TXMiamiFan
    Jose
    45 mins to drive to the shop and 45 min drive back at the end of the day :p
    Patriot, joonbug, chphilo and 2 others like this.
  16. Jun 12, 2017 at 7:35 AM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    Such a great product to help insure getting your truck aligned without any issues!!
    Maintenance free design, grease-able zerk on the Ball joint, overall a very solid product!
    -David
  17. Jun 12, 2017 at 7:52 AM
    scotch
    scotch New Member
    Denver, CO
    2010 Tundra
    2-3 on a 1-10 difficulty, home mechanic skills takes me about 30 minutes to swap out. You'll need an alignment afterward (obviously). Save the instructions to give whoever does the alignment.
  18. Jun 13, 2017 at 3:47 PM
    Les7311
    Any write up/ pics//vid?
    Am planning said surgery soon.
    Rica25 and Phillipk98[OP] like this.
  19. Jun 18, 2017 at 8:36 AM
    dmeneses1983
    Dennis
    2016 Silver Tundra
    it took about 3 hrs to install. Had a independent shop installed them for me.
    Les7311[QUOTED] likes this.
  20. Jun 18, 2017 at 5:22 PM
    Phillipk98
    2005 sr5 sequoia
    What would you say max lift capacity with these UCAs? Height wise?
  21. Jun 19, 2017 at 6:48 AM
    Toytec Lifts
    Denver, CO.
    I'd say 4'' is max in my opinion.
    -David
    Rica25 and Les7311 like this.
  22. Jun 20, 2017 at 6:27 PM
    Phillipk98
    2005 sr5 sequoia
    Okay cool! Is that because of the geometry of the axles. Or alignment issues with going higher? How far does your different drop kit come down and help out?
  23. Jun 21, 2017 at 7:28 AM
    Toytec Lifts
    Denver, CO.
    Yeah we like the geometry to stay as safe and sound as possible.. 4'' is right around max without doing a drop bracket style lift kit.
    Our Diff Drop kit drops the front part of the diff 1'' or 3 degrees, just to help decrease the angles of your CV's.
  24. Jun 21, 2017 at 4:55 PM
    Phillipk98
    2005 sr5 sequoia
    Great thanks for everyone's input!
  25. Jun 23, 2017 at 9:36 AM
    showtime240
    showtime240 New Member
    I also have em with my OME 614s.
    The SPCs are great. So far about 22k miles and zero issues. Love em
  26. Jul 29, 2017 at 4:29 AM
    Les7311
    ......so what do you recommend for a 6 inch lift? The 25490 won't work?
  27. Jul 29, 2017 at 5:19 AM
    Phillipk98
    2005 sr5 sequoia
    Well the kit you are getting should come with new spindles. At least the first gen sets do. But to better answer this there is @ToyTec Lifts
  28. Jul 29, 2017 at 6:20 AM
    Les7311
    :tumbleweed:
  29. Jul 29, 2017 at 6:35 PM
    Quartermeter
    Quartermeter New Member
    James
    Alabama
    2014 SR5 DC WHITE
    FOX 2.0 REARS, OME FRONTS FIRESTONE AIR BAGS RCI SKID PLATE
    Would a diff drop help your front end alignment on 2.5-3" lift w/o new ucas??
  30. Jul 31, 2017 at 6:29 AM
    Phillipk98
    2005 sr5 sequoia
    For your axles yes. For your suspension no.
