SPC UCAs
Discussion in 'Suspension' started by TXRailRoadBandit73, Sep 8, 2017.
  1. Sep 8, 2017 at 6:49 PM
    TXRailRoadBandit73 [OP] YOTAS,RAILROADIN',RÖKnRÖLLN',BEER,MAX/GEMMA
    Well after some researching come to find out im stuck like chuck with my RC 6" lift since rear crossmember is cut...the upside to it is that RC makes a 6" strut now thanks to @Les7311 who told me about it...i can remove the spacer and preload spacer as well and install new strut...also anyone out here running SPC adjustable UCAs? Or heard good bad things about em? I'm gona order these since my tires starting to show wear on inside since i bought my truck
    Les7311 and Eclipsed & Floating like this.
  2. Sep 8, 2017 at 6:54 PM
    Sean happens to have some on his truck. Wish I did.
    Eclipsed & Floating and T-Rex266 like this.
  3. Sep 8, 2017 at 7:00 PM
    What do you have Matt?
  4. Sep 8, 2017 at 7:04 PM
    Stock. Need to upgrade....waiting for money tree to bloom.
  5. Sep 8, 2017 at 7:07 PM
    Much better alignment and no need to grease them
  6. Sep 8, 2017 at 7:09 PM
    If you ever go Chaos....I want to buy yours.........1st dibs........heh...heh
    T-Rex266[QUOTED] likes this.
  7. Sep 8, 2017 at 7:25 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I the the TCs on my Tundra. Had the SPCs o my Tacoma. No complaints. Very adjustable to achieve alignment specs.
    Eclipsed & Floating likes this.
  8. Sep 8, 2017 at 8:05 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    How does your alignment hold up with the TCs in comparison to SPCs? Does the size and weight of your tundra influence alignment more than the taco?
  9. Sep 8, 2017 at 8:20 PM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    ARAM
    I did a write up on the SPC. It's a must have to correct the positive camber. Check photo sent.
    I paid $495 on eBay. About a month back. The surgery is easier than changing the brakes.
    https://www.tundras.com/threads/how-to-install-adjustable-uca-25490-help.15214/
  10. Sep 8, 2017 at 8:35 PM
    Les7311
    SEAN
    Harbor freight gease gun plus lithium cost under $20, last weekend
    Not only did I greased the SPC Adjustable UCA 25490, I also hit the drive shafts. So it's a win win and takes a little more TLC when you do it, vs....
  11. Sep 9, 2017 at 4:18 AM
    Tundra_mike89
    Tundra_mike89 New Member
    Michael
    South Texas
    2016 TUNDRA CM 4x4
    Toytec boss coilovers Toytec shackles Total chaos uca's Method wheels Nitto ridge grapplers
    I have the total chaos uca's. I grease once every 2500 miles. No complaints.
  12. Sep 9, 2017 at 5:22 AM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    So with a good aftermarket coilover setup and SPC UCA's, is that considered mid travel or is any other brand of UCA besides SPC considered mid travel? Does SPC allow more droop like TC,MCM, CAMBURG, ICON or its only advantage is correcting alignment issues and no maintenance?
  13. Sep 9, 2017 at 7:07 AM
    But there's no need to grease the SPC's - at least the ones I have. Which version are you running?
  14. Sep 9, 2017 at 8:55 AM
    Les7311
    My are. I am in the 25490 version.
    Two pieces
  15. Sep 9, 2017 at 10:12 AM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    I'm no expert on suspension, but from what I understand you're going to get more travel out of a uniball UCA (TC, Camburg, MCM, etc.) than a ball joint as the uniball allows for more articulation. The ball joint ones just can't move in as full a motion. But it also depends on what coilovers you use and how you have them set up on whether it's considered mid travel or not. Shoot @jberry813 or @ColoradoTJ a PM as they're the resident experts.
