SPC UCAs w/ 285/75/18 Stock Wheels
Discussion in 'Wheels & Tires' started by worktruckwhite, Nov 17, 2022.
  1. Nov 17, 2022 at 7:37 AM
    worktruckwhite
    worktruckwhite [OP] bryceCtravels.com
    Charleston, SC
    2010 White Crewmax
    Think I’m going to put 285/75/18s on in the next few weeks.
    I know they’ll clear everything except my SPCs.
    surprised no one has asked this before, I’ve done plenty of googling.
    Anyone with SPCs running 285/75/18 on stock wheels?
  2. Nov 22, 2022 at 2:25 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Bryce! You may not be able to clear the UCA due to using the stock +60 rims. You will most likely have MM to play with. Best bet is if you look into some Bora/Spidertrax 1.25" spacers to push the stock wheels out a bit more to clear the 285/75.
    worktruckwhite[OP] likes this.
  3. Nov 28, 2022 at 1:48 PM
    worktruckwhite
    Charleston, SC
    2010 White Crewmax
    Thank you!! I've figured a bit as much -- 275/70s are already quite close.
  4. Nov 28, 2022 at 2:08 PM
    Wheel spacers may do it or get some aftermarket 0 offset wheels.
  5. Nov 28, 2022 at 2:10 PM
    2mchfun
    Not sure it won't work, I had exactly the same thing going on. In hindsight I almost wish I would have kept the stock rims and at least tried first. For sure it would have been close, but I actually think it would have been alright. My suggestion is ask the shop to try and fit one, you just may get really lucky! Report back and let us know!
  6. Nov 28, 2022 at 2:17 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    You can definitely look into +25 or +18 offset wheels just for that sweet spot.
  7. Nov 28, 2022 at 2:24 PM
    2mchfun
    Man, I am telling you, I went down this exact path for months. I'm even almost certain someone here posted one, maybe even two. However, I can't recall who it was. I just know I was finally swayed because I wanted to add flares, so needed a little different offset to match the flares positioning.
  8. Nov 28, 2022 at 2:30 PM
    2mchfun
    Fwiw, I ended up at +30 offset and still have about an inch of clearance.
  9. Dec 5, 2022 at 11:19 AM
    worktruckwhite
    Charleston, SC
    2010 White Crewmax
    This is what I’ll do. Prefer to not use spacers — rims aren’t an option with the thrashing my wheels see
    2mchfun[QUOTED] likes this.
  10. Dec 19, 2022 at 10:10 AM
    Stant1dm
    Stant1dm New Member
    Dave
    Michigan
    2019 Limited TRD Off-road
    I put on 285/75 on, had to trim the skid plate. Still rubs on the sway bar at full lock. Not sure what to do about that yet. Thought about spacers, but that tends to create more rubbing.
