SPC UCA Question - Please Help!
Discussion in 'Suspension' started by Boisefly, Jan 12, 2022.
  1. Jan 12, 2022 at 1:33 PM
    Boisefly
    Boisefly [OP] New Member
    Boise, ID
    2014 Crewmax 1794 4WD
    Preparing to install SPC UCAs on my 2014 Tundra 4x4.
    I have toytec aluma 2.5 coilovers on the front set at about 3" of lift. Have Toytec lift shackles in the back at around 1.5" of lift. With the stock UCA that I currently have, I could only get about 2.3 Caster on both sides with camber at 0.5.
    When I install the SPCs, I'm planning to set them at caster setting "C". I'll then drive it over for an alignment. I see some people saying to set it at setting "D", but that doesn't seem right. What have you guys done when installing?
    Thank you in advance!!
  2. Jan 12, 2022 at 4:57 PM
    Boisefly
    Boise, ID
    Any suggestions would be appreciated! I know a lot of you guys have installed these.
  3. Jan 12, 2022 at 5:05 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Why does D not seem right but C does?
    Why not just have the alignment shop deal with it?
    AggiePhil likes this.
  4. Jan 12, 2022 at 5:20 PM
    Boisefly
    Boise, ID
    The C setting adds some more caster which is preferred. D would seem to set things at a low caster setting.
    Might as well install it at a good setting and let them make fine adjustments. All I was thinking….
  5. Jan 12, 2022 at 5:21 PM
    Set it at D and pull the wheel all the way out towards you. Worked like a charm for myself and several others.
    14burrito and 2mchfun like this.
  6. Jan 12, 2022 at 5:23 PM
    Set it at D. See my other reply.
  7. Jan 12, 2022 at 5:24 PM
    Alot of alignment shops are not familiar with adjustable ball joints. I set mine at D from the advice of others on here but took the installation sheet with me just in case.
    14burrito[QUOTED] and Ely010606 like this.
  8. Jan 12, 2022 at 5:30 PM
    2mchfun
    X2- set mine at D as well.
    Tundra234 likes this.
  9. Jan 12, 2022 at 5:50 PM
    Boisefly
    Boise, ID
    Got it. I’ll set it at D and see how things go.
    Thanks guys!!!
