SPC UCA Alignment Question
Discussion in 'Suspension' started by renlo, Mar 9, 2018.
  1. Mar 9, 2018 at 8:38 PM
    renlo
    renlo [OP] New Member
    Rene
    2016 Tundra Platinum
    Bilstein 5100 top setting Coachbuilder .25" Shim SPC UCAs Bilstein 5100 Rear
    Went in for an alignment today. The shop only set caster to 1.7 Left and 1.9 Right. Camber and Toe is spot on. They did not touch the adjustable bolt on uca and I am now going back on Monday so they can up the caster.
    My question is, can they just adjust the caster setting on the UCA without causing changes to the camber and toe?
  2. Mar 9, 2018 at 8:43 PM
    Can you post a sheet of what they did?
  3. Mar 9, 2018 at 9:36 PM
    renlo
    Rene
    Here's the after. The truck and steering feels light. I want more caster, about + or - 3 degrees. Everything else is fine.
  4. Mar 9, 2018 at 9:38 PM
    Take it to a shop that specializes in lifted vehicles. Wish you were local, I would ensure it’s all green for ya.
    What uppers do you have?
  5. Mar 9, 2018 at 9:40 PM
    renlo
    Rene
    This shop has done good work for me in the past. I tell them what i want and they do it. There was a misunderstanding this time though.
    Any thoughts as to my question.
  6. Mar 9, 2018 at 9:41 PM
    What uppers?
  7. Mar 9, 2018 at 9:41 PM
    renlo
    Rene
    SPC, on the title.
    T-Rex266 likes this.
  8. Mar 9, 2018 at 9:49 PM
    Sorry.
    Yes
    Here are my results from like 3 years ago.
    renlo[OP] likes this.
  9. Mar 9, 2018 at 9:53 PM
    renlo
    Rene
    Awsome, was hoping for that answer. Just a simple adjustment.
    Thanks alot.
  10. Mar 9, 2018 at 10:04 PM
    TheBeast The Beach
    yes above 3 for caster on each side if you have mildly lifted truck and 0.24 ish max toe on both sides (like 0.12 and 0.12)
    renlo[OP] and T-Rex266 like this.
  11. Mar 9, 2018 at 10:06 PM
    TheBeast The Beach
    if the guy has a good machine, give him the numbers you want and he will make it work. That's what I did last time.
