SPC Control Arms "C" Setting?
Discussion in 'Suspension' started by rustytoys, Mar 1, 2021.
  1. Mar 1, 2021 at 10:02 AM
    rustytoys
    rustytoys [OP] New Member
    Is anyone using the "C" setting (+2 Degrees of Positive Caster) on the SPC control arms - and if so what kind of caster numbers did that give you on alignment? Thinking the "D" +1 caster may not be quite enough for a solid 3" lift.
  2. Mar 1, 2021 at 10:25 AM
    Mine is on "D" and pulled all the way out towards the outside of the wheel well. No issues at all. I am on a 3/2 lift.
  3. Mar 1, 2021 at 12:19 PM
    rustytoys
    Thanks, do you remember what sort of caster numbers did that gave you?
  4. Mar 1, 2021 at 3:04 PM
    I'll look. I have my alignment sheet in the truck I think.
  5. Mar 1, 2021 at 4:29 PM
    rustytoys
    I am sure the D setting will get you within factory specs with a 3" lift - but, I guess what I am saying is that I am not sure if that is ideal, as you may want more caster. It's really a personal preference.
