Spark plugs
Discussion in '2nd Gen Tundras (2007-2013)' started by MyFj08, Oct 24, 2019.
  1. Oct 24, 2019 at 8:47 AM
    MyFj08
    MyFj08 [OP] New Member
    Mark
    2012 crewmax 4wd.
    I'm working on it
    So. Let's talk spark plugs
    Has anyone used the E3 plugs in the 5.7
    Motor
    I have had great results using them in the FJ
    But the Tundra is a different monster
    I believe they are slated for Iridium plugs
    I assume Denso from the factory
  2. Oct 24, 2019 at 9:04 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    I just put back in OEM Denso's. Don't over complicate them.
  3. Oct 24, 2019 at 9:05 AM
    blackoutt
    blackoutt YEAH BUDDY!
    Indy
    07 DC Long Bed - Old Man Tan
    OEM+
    Denso's from a reputable source. Amazon and ebay are wrought with knock off copies.
  4. Oct 24, 2019 at 9:10 AM
    MyFj08
    Mark
    2012 crewmax 4wd.
    I'm working on it
    So. Dont e en try the E3's
    I have read here a few ppl using NGK IX Iridium's
    Which would be my 2nd choice over the E3's
  5. Oct 24, 2019 at 9:39 AM
    LlamaResistance
    LlamaResistance Member
    Concord, CA
    2017 White Crewmax SR5 TRD Offroad
    MLED Retrofitted Platinum Headlights, Ranch Hand bumper, Firestone airsprings, Leer 100XR Shell, Amp Research Steps
    All those side electrodes are actually hiding the spark from the combustion chamber. Iridiums are a far better choice.
  6. Oct 24, 2019 at 10:57 AM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    Stick with the OE iridium plugs. I ran E3's in a 4.7L Dodge years ago and had nothing but problems with them. A friend of mine, a 25+ year master GM tech asked me about 6 times what the tag under the hood said for plugs and I gave him the same answer 6 times. He said "that's the plugs that should be in there!" That Dodge was set up from the factory to run cheap Champion plugs and your Tundra is set up to run Denso iridiums.
  7. Oct 24, 2019 at 11:09 AM
    Dr_Al
    Dr_Al New Member
    Al
    There's nothing really magic about a spark plug. Companies like Splitfire want to make it sound like you can gain something if you buy their product but any good brand iridium plugs will do (and last the longest). I used NGK plugs as they were easy to get.
    MyFj08[OP] likes this.
  8. Oct 25, 2019 at 4:35 AM
    SgtNewundies
    SgtNewundies New Member
    Eric
    Iridiums NGK or Denso and change at about 90,000-100,000 miles.
