Spark plugs
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mazesun101, Feb 9, 2019.
  1. Feb 9, 2019 at 6:32 PM
    Mazesun101
    Mazesun101 [OP] New Member
    Miguel
    2015 white Tundra SR
    Hello guys I need help so I justchanged my spark plugs and I'm running into an issue here when I take off my headlights dim and when I'm stopped my battery gauge Reed's between 9 and 14 volts did I do something wrong
  2. Feb 9, 2019 at 6:35 PM
    Battery terminals on tight on battery posts? Battery holding charge? New one needed? Alternator need testing?
    15whtrd likes this.
  3. Feb 9, 2019 at 6:41 PM
    Mazesun101
    Miguel
    thanks a lot I re tighten battery terminals fixed the problem. thank God you guys are here
  4. Feb 9, 2019 at 6:54 PM
    Mazesun101
    Miguel
    Guys is it normal for water to drip from the exhaust pipe. It's a constant drip. Do you think maybe my water pump is leaking
  5. Feb 10, 2019 at 12:50 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
    2016 Tundra TRD Crewmax
    Bilstein 6112, 5160, Coachbuilder 1” shackle lift, Wildpeak A3’s, LED backup, Maxiplus mats, Bak Rollover Mx4, BedRug, Westin HD Headache Rack. Westin HD Brush Guard, Spidertrax 1.5 spacers. TRD Brakes. Headlight Revolution LED. TRD rear Torsion Bar. Dirty Deeds 10 inch Stainless. TRD Pro Grill. Bushwhacker Pocket Flares. Baja Designs Combo Driving/Fog lights.
    Moisture from the air and condensation in the exhaust is normal especially when cold. Once it’s hot the residue is blown out and the moisture comes out as vapor. But all the time is not so good. If you take a lot of short trips with the engine and exhaust not getting to temp. It can seem that way.
    Extra water or steam means coolant is getting into the combustion chamber. Like a blown head gasket or cracked head. But this will cause white smoke to billow out when it’s hot. It’s unkikely because you would notice that and your coolant level would start to drop. Water pump would not send water to the exhaust system. Usually If it leaks. It’s at the pump.
    If it’s running good and you take short trips. Take it out for a good ride at speed and get everything hot. Highway is good. See if that changes helps.
    equin and Mazesun101[OP] like this.
  6. Feb 10, 2019 at 1:16 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    If you’re not blowing smoke then you’re fine. My truck drips fluid from the tailpipe especially when first started.
    15whtrd likes this.
  7. Feb 10, 2019 at 1:26 PM
    Mazesun101
    Miguel
    Ok good I was worried. Trucks running good and I take alot of long rides due to my job and I all ways check my coolant level since I noticed the water dripping from the exhaust pipe.
  8. Feb 10, 2019 at 2:22 PM
    15whtrd
    15whtrd Mr. Blonde
    Get it nice and hot and make sure you step on it now and again to keep it nice and cleared out LOL then recheck. Should be zero water when it’s good and hot. But it is normal to get condensation in your exhaust.
    TXRailRoadBandit73 likes this.
