Spark plugs
Discussion in 'General Tundra Discussion' started by Ken, May 29, 2015.
  1. May 29, 2015 at 9:20 AM
    Ken
    Ken [OP] New Member
    I have a 2007 Tundra with 88k miles
    When have most of you been changing your plugs and timing belt?
    5.7 engine
  2. May 29, 2015 at 9:49 AM
    Mike Tread lightly.
    south carolina
    the 5.7 or (3uz-fe) uses a timing chain not a belt. The chain rarely has to be changed unless you have 300,000 plus miles on it even then it still might be good.
    As for spark plugs every 60,000 miles they should be changed or 5 years. For best performance change them every 30,000 miles or every 2.5 years.
    Black Wolf likes this.
  3. May 29, 2015 at 10:06 AM
    I changed my OEM iridiums at 50K although manual said at 130K which seemed extreme. At 50K plugs were still like new and didn't need replacing yet but put NGK's in anyways. The AT fluid isn't changed until 100K. Not super keen on that either.
  4. May 29, 2015 at 10:18 AM
    What do you think about waiting 100K for AT?
    Imagine what the dealer would charge to replace a timing chain if the 3u h ad one? Geesh. I'd have to buy a horse.
  5. May 29, 2015 at 10:27 AM
    Mike Tread lightly.
    south carolina
    Its a sealed gearbox. So nothing can get in or out of it without leaking.
    100,000 would be fine best to change it at 60,000 or even 30,000 would be best to get rid of any contaminants in the oil,from break in when the truck was new plus get rid of any loose metal shavings.
  6. May 29, 2015 at 10:43 AM
    That's what I was thinking. When I first got the truck I tried to check the AT level. No dip stick, then I RTFM and realized no AT till 100K. You'd think maybe changing after 5K new and then shoot for 100K. Going to check AT change prices around here. Don't like not knowing what condition the fluid is.
  7. May 29, 2015 at 11:00 AM
    Mike Tread lightly.
    south carolina
    Why do you thin i have a 1st gen for ;)
  8. May 29, 2015 at 11:03 AM
    Imagine my surprise when I looked for my oil filter for 30 minutes. Then realized what bee-yahch it would be to change the oil which I obviously don't do myself anymore.
  9. May 29, 2015 at 12:46 PM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    I normally tell people to wait until 100k miles to change plugs. They're made to go that long, and a lot of people notice no change in mpg or performance, even well over 100k miles.
  10. May 29, 2015 at 3:58 PM
    I think 60k is a good start for the AT...better safe than sorry.
  11. May 29, 2015 at 4:03 PM
    And my truck is now eight yrs. Agree BSTS ( see above)
    T-Rex266[QUOTED] likes this.
  12. May 27, 2019 at 6:29 PM
    Kerktam
    Kerktam Lexus truck wanted
    middle of nowhere, up north
    2023 limited TRD OR, 2024 silverado 5.3
    35 tires, 2 inch level kit
    I put 230k on my 2010 5.7 tundra
    Still original spark plugs and AT fluid
    I do change synthetic oil every 10k
