spark plugs
Discussion in '2nd Gen Tundras (2007-2013)' started by ausei, May 1, 2015.
  1. May 1, 2015 at 12:42 PM
    ausei
    ausei [OP] New Member
    Ause
    Baton Rouge, LA
    2011 Spruce Tundra TRD SR5 2WD
    3" Leveling Kit 3.5" Spindle Lift 4" Rear Blocks AirAid Intake 20" XD Monsters w/ Nitto Grapplers 1" wheel spacers for rear Magnaflow Exhaust Pro Comp Shocks for rear
    i felt like changing my spark plugs. i also felt like splurging on some pulstars. i now have a check engine light and something seems to have gone wrong. not sure what the issue is. anyone use pulstars before?
  2. May 1, 2015 at 12:58 PM
    I have read that setting the gap is critical for Pulstars and the Tundra ECU has had some issue knowing how much gas to send with these plugs installed causing the check engine light. I decided to stick with the iridiums.
  3. May 1, 2015 at 1:55 PM
    Mike Tread lightly.
    south carolina
    Go back to the denso spark plugs you will thank me later.
  4. May 1, 2015 at 2:22 PM
    ausei
    Ause
    Baton Rouge, LA
    thanks friends, after my visit to oreilly, they said it was cylinder 3. and it wasnt the coil because we swapped them around reset light and rechecked after the light came back on. so im hoping its just a defect in the plug. if it still is im going back to the denso.
    how important is dielectric grease to be used?
  5. May 1, 2015 at 2:28 PM
    Mike Tread lightly.
    south carolina
    Dielectric grease... Called Dow 4 or light bulb grease.
    It is use to water proof power connections where water or moisture could cause problems.
    Any place where you have a power connection use it.. Also keeps rust from forming too..
    Just a FYI.. toyota engines are, a very pain in the butt with different spark plugs other than denso.
    T-Rex266 likes this.
  6. May 1, 2015 at 3:03 PM
    ausei
    Ause
    Baton Rouge, LA
    thanks bro
  7. May 5, 2015 at 8:08 AM
    ausei
    Ause
    Baton Rouge, LA
    so i have still been waiting on my new spark plug to come in. it is supposed to be coming in today. however...my check engine light is no longer on anymore. it used to flash...sometimes stay solid which is what normally was. also with LSD light on. i turned her on this morning no lights. ran fine. im going to take it to oreilly and see if there are any codes. i heard from a friend that since i didnt unhook my battery when i did it. it may have taken some mileage to realize there are different plugs....
    any thoughts?
  8. May 5, 2015 at 8:23 AM
    That certainly sounds reasonable. Maybe the reported issues I read about was mainly a lack of patience waiting for ECU to acclimate for lack of a better word. Hope the plugs work out for you. Pulstsar technology is kind of cool.
  9. May 5, 2015 at 8:26 AM
    Dave333
    Dave333 New Member
    Dave
    2015 Platinum CrewMax
    Could be the computer relearning the new plugs. I do agree on the Denso though, they are all the truck needs. Don't forget to put some anti-sieze on the spark plug threads.
  10. May 5, 2015 at 8:38 AM
    Mike Tread lightly.
    south carolina
    The ecm was learning the new curve do to different spark plugs and burn rates why the cel was flashing. With the light off now the learning curve is complete. I wouldnt pull the spark plugs out unless the cel or engine gives you problems or fuel mpg goes down.
  11. May 5, 2015 at 9:05 AM
    ausei
    Ause
    Baton Rouge, LA
    ok guys. just got off the phone with pulstar. because im super paranoid. they are super nice and friendly. they are next daying me a whole new set. apparently is a misconception that their plugs are already gapped. i had no idea. i figured if they know the year make and model it is ready to go...apparently not the case. they come standard for the dg1h10 is 40. its supposed to be 44 for my tundra.
    so when you buy denso are they pre gapped for the truck?
  12. May 5, 2015 at 9:13 AM
    My Denso's were pre- gapped, but I check them anyways to be sure. Sound like Pulstar has good customer support.
    irishpride114 likes this.
  13. May 5, 2015 at 9:14 AM
    ausei
    Ause
    Baton Rouge, LA
    yea, that what im going to do too just to be sure. what tool do you use. i see a bunch of different kinds. i saw one that is in inches and mm. im assuming that i need .44 mm. and is it .044 or .44
    just called and verfied is its .044
  14. May 5, 2015 at 9:48 AM
    0.044 in or 1.1176mm. Your local auto parts will have the gap tool you will need for 5 to 10 bucks. Maybe less.
  15. May 5, 2015 at 9:55 AM
    ausei
    Ause
    Baton Rouge, LA
    thank you! new plugs will be here tomorrow and i will post to let you know if there are anymore errors
  16. May 5, 2015 at 10:23 AM
    Mike Tread lightly.
    south carolina
    remember to disconnect your battery so the ecm will lose the config on the spark plugs you have now. Touch the + and - together so the cap will drain totally out.
  17. May 6, 2015 at 11:31 AM
    ausei
    Ause
    Baton Rouge, LA
    smh. spark plugs came in bright and early this morning...with only 6. two more will be here tomorrow.
  18. May 6, 2015 at 11:47 AM
    All's well. I you had a V-6 you would have gotten 4 plugs.
  19. May 6, 2015 at 3:04 PM
    irishpride114
    irishpride114 New Member
    Travis
    2015 SR5 TRD Double Cab
    Following
  20. May 7, 2015 at 5:04 PM
    ausei
    Ause
    Baton Rouge, LA
    got them installed. everything works great so far. no errors. it runs a little better. I'm impressed a little.
  21. May 7, 2015 at 5:15 PM
    That's good to hear. In theory you should see improvement with a more efficient burn. After a week or two you should really be able to see if mpg's go up.
