SPARK PLUG SERVICE
Discussion in 'Performance and Tuning' started by so_melo149, May 14, 2022.
  1. May 14, 2022 at 10:34 AM
    so_melo149
    so_melo149 [OP] New Member
    Los Angeles, CA
    2017 Tundra Crew-Max TRD off-road
    1.75” Rough Country Leveling Kit 275/70/18 GoodYear DuraTrac AT Honey Comb Grill
    what’s up fellas
    my 07’ black mamba is at 127k miles and i’m just now going to replace the original spark plugs.
    i purchased NGK laser iridium replacements.
    my question is, what else is recommended to service at this time? or any other recommendations for service at 127k miles ?
  2. May 14, 2022 at 11:26 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    With that mileage I would change coil packs too. And use anti seize on the plugs.
    change plugs every 50k
    Coils every 100k
    BenAZ and BTBAKER like this.
  3. May 19, 2022 at 3:27 PM
    so_melo149
    Los Angeles, CA
    thanks for the help
    i am buying the parts from my local Autozone and i have 2 options for the Coil packs… they have the duralast with lifetime warranty and Denso with a 1yr warranty
    which do you recommend ?
  4. Jun 8, 2022 at 8:02 PM
    Larly5000
    Larly5000 Local Scumbag
    NV
    07 Crewmax
    I wouldn't replace the coil packs til you need to replace the coil packs. To each their own though, I guess. Not a common failure and you’ll know when you have it.
    I’ve replaced my plugs twice, each at 100k’ish (210k miles now). Original coils still truckin’.
    There isn’t much else there to get pro-active on, if you’re simply doing plugs.
    Trust86, Sumo91, Zebruaj and 2 others like this.
  5. Jun 14, 2022 at 1:57 AM
    Larly5000
    NV
    07 Crewmax
    Anndd dont use anti-seize on the plugs either. (Its not 1971)
    Almost every plug manufacturer(like NGK in your case or factory Denso’s)uses a coating on the threads to prevent seizing.
    If you gotta scratch that itch, make sure you apply a little bit near the center threads and dont torque too much. Or the threads in the head are coming out with the plug.
    Trust86 likes this.
  6. Jun 14, 2022 at 8:31 AM
    dirtydeeds
    Keith
    USA
    Yep. To each their own. Having built literally hundreds of tundras, I base my advice on real world experience. Your truck would perform better if you’d look at the advice I’m giving you.
    Coil packs sometimes ‘just go out’. But usually that’s not the case, usually they just don’t work as well. The most common failure that I see is a small, random voltage leak. You can actually tell by looking at your fuel trims.
    to tell a guy ‘you’d know when you have it’ is extremely vague, random, and is simply bad advice. They’re inexpensive enough to change as a matter of fact. As a matter of fact I’ll be bold and say this, ‘There should be a change interval specified in the owners manual’.
    Seaflea and Cruzer like this.
  7. Jun 14, 2022 at 8:33 AM
    dirtydeeds
    Keith
    USA
    these are aluminum heads. You need anti seize no matter what year it is. It stops the plugs from sticking into the head. And it lubricates the threads for a more accurate torque reading. Also, look up the torque value for yourself. I’ve always used 18ft lb. moral of the story, use an actual torque wrench. Don’t just guess.
    Cruzer likes this.
  8. Jun 14, 2022 at 9:20 AM
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    I just looked up Ignition Coil Packs on the Sparks Toyota website.
    Are they really $85 each?
    Do you need to get eight of them?
    That might be out of my price range.
    dirtydeeds likes this.
  9. Jun 14, 2022 at 12:20 PM
    dirtydeeds
    Keith
    USA
    What I did:
    Buy an 8 pack from Autozone. Bring an extra couple of your old stock as back up thst ll I hate to admit to using Autozone parts, especially electrical. But they worked better than my old factory coils with 200k mikes on them.
  10. Jun 14, 2022 at 1:51 PM
    huntertn
    huntertn New Member
    Tennessee
    2008 White CrewMax Limited 4x4
    Rockauto has Denso coils for a little over $50 each. Another option if you are thinking of going that route.
    dirtydeeds and FrenchToasty like this.
  11. Jun 14, 2022 at 3:37 PM
    dirtydeeds
    Keith
    USA
    Definitely the route I would’ve taken if I had the tine to wait. With the OP doing this project at his convenience this would be the best choice.
    huntertn[QUOTED] likes this.
  12. Aug 4, 2022 at 8:29 AM
    so_melo149
    Los Angeles, CA
    GOOD MORNING,
    does anyone know torque specs for the spark plugs and coil packs?
    i finally have time to do the job
    and my oil change while im at it
    LMK thanks
  13. Aug 4, 2022 at 9:34 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I never torque the coil packs. No need to. Dirty Deeds says 18 ftlbs on plugs. Seems like a good number. Tacoma 4.0s are 15.
