Spark Plug replacement
Discussion in '1st Gen Tundras (2000-2006)' started by literallyme, Sep 22, 2023.
  1. Sep 22, 2023 at 4:11 PM
    literallyme
    literallyme [OP] New Member
    Southern California
    2006 Sequoia Limited 2WD, 1974 Pontiac Firebird 350
    Good evening 1st genners, I am back once again because I want your opinions on some spark plugs in thinking of buying now that I have the budget. I have a 2006 Sequoia Limited with the 4.7 V8, and just bought it a couple months ago. The plugs have never been replaced (I’m at 180,500 miles) as far as I know after going through all of the service records. First off, I am going with the Denso TT (Twin tip) 4702 from Rockauto. Yes I’m choosing Denso for the replacement just because, that’s what’s already in there. I have NGKs in a relative’s Honda and they are great, no hate towards them. Now this plug is advertised as being more fuel efficient, is that just a marketing gimmick or are these good? Lastly, the pre-set gap is 0.040 when the manual calls for 0.043-0.044 I believe. Let me know your thoughts. I want to get these replaced ASAP as preventative maintenance.
  2. Sep 22, 2023 at 4:15 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Let us know if the plugs don’t break coming out. +180k is a lot of miles.
  3. Sep 22, 2023 at 4:22 PM
    literallyme
    Southern California
    When you put it like that, should I have a mechanic do the job? I just DIY things, but I have no damn clue on how to extract a broke spark plug…
  4. Sep 22, 2023 at 4:28 PM
    Mr Badwrench
    Mr Badwrench New Member
    More efficient is just as you said... a gimmick. I've never had good luck with the platinum or tritiums in the 4.7, for what it's worth. They haven't lasted long and given me a rough cold-start.
    literallyme[OP] likes this.
  5. Sep 22, 2023 at 4:45 PM
    Jack McCarthy
    Bill
    North of Boston
    Maybe its not as bad for you living in a nicer climate. You don’t get severe cold like we do.
    Maybe some of our warm climate friends here can comment on getting out +150k plugs.
  6. Sep 22, 2023 at 4:51 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Open your owners manual and use one of the plugs specified therein. I do not believe that Twin Tips are correct for the 2UZ.
  7. Sep 22, 2023 at 4:57 PM
    Elevatorguy
    Elevatorguy Yotas and JD Green!
    James
    05 DC, 4.7, 4wd, LSD.
    I wouldn’t worry one bit about breaking plugs, This isn’t a 4.6/5.4 Furd.
    Mr Badwrench and literallyme[OP] like this.
  8. Sep 22, 2023 at 5:03 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Original plugs would have been:
    DENSO KS20R11 (3297) (Iridium Long Life)
    NGK IFR6A11 (4589) (Laser Iridium)
  9. Sep 22, 2023 at 5:09 PM
    literallyme
    Southern California
    Yeah, I’m thinking I’m just gonna go with the regular Denso Iridiums with the proper gap. Besides, I already priced out the plugs plus shipping for RA and it costs more than ordering online (automatic discount when you do) from my local stealership.
  10. Sep 22, 2023 at 7:51 PM
    shifty` Animals and insects don't do drugs
    You're not supposed to gap Iridium plugs. They come pre-gapped and with protection to make sure the gap can't be closed. Attempting to gap can damage the electrode.
    Note: "KS" is a typo in the owner's manual, it's supposed to be SK. I've made this mistake a number of times also.
    I personally bought NGK with the correct model number "SK20..." Just don't buy online. I'm not typing out the whole part number b/c the forum software will auto-link it to scAmazon and they're one of the largest sources of knockoff spark plugs on the internet.
    And @ OP, don't use anti-seize on the plugs when installing. I wouldn't be super worried about snapping anything off in the hole.
