Spark plug question
Discussion in 'General Tundra Discussion' started by healeyman, Jan 23, 2020.
  1. Jan 23, 2020 at 9:06 PM
    healeyman
    healeyman [OP] New Member
    Hello All,
    It's been a couple of years since my last post and I have some questions regarding spark plugs.
    My 2002 4.7 Tundra has 130K miles on it. I bought it used about 6 years ago with 80K miles on it. I decided to change the spark plugs but I've seen on the forum that there is some discrepancy with regards to type and gap.
    I pulled the old one and they were Bosch Iridium with a gap of .044".
    Went to the Napa parts store and got a new set of NGK that aren't Iridium and they are gapped to .032". It appears that different plugs have different gaps which has led to numerous discussions but in the forum no one has stated exactly which of the plugs they have been using.
    I went to the NGK web site and put in the year, model and engine size. It gave me about 6 options, all are gapped to .032"
    Then I saw a post from a member that is rebuilding his truck and he has a sticker on the valve cover that says "Use Iridium Plugs Only".
    I looked at Denso and they have different gaps for different plugs, see below.
    K20R-U
    Engine:
    V8 (4.7L)
    CC:
    4663
    CID:
    285
    8
    Note:
    Gap 0.032
    Label:
    U-Groove Conventional
    View
    Buy
    PK20R8
    Engine:
    V8 (4.7L)
    CC:
    4663
    CID:
    285
    8
    Note:
    Gap 0.032
    Label:
    Double Platinum
    View
    Buy
    SK20PR-A8
    Engine:
    V8 (4.7L)
    CC:
    4663
    CID:
    285
    8
    Note:
    Gap 0.032
    Label:
    Iridium Long Life
    View
    Buy
    PK20TT
    Engine:
    V8 (4.7L)
    CC:
    4663
    CID:
    285
    8
    Note:
    Gap 0.040
    Label:
    Platinum TT
    View
    Buy
    IK20TT
    Engine:
    V8 (4.7L)
    CC:
    4663
    CID:
    285
    8
    Note:
    Gap 0.040
    Label:
    Iridium TT
    View
    Buy
    IK20
    Engine:
    V8 (4.7L)
    CC:
    4663
    CID:
    285
    8
    Note:
    Gap 0.044
    Label:
    Iridium Power
    What are most of you guys using and what are you experiencing with regards to performance and fuel economy?
    What is the reason for so many different choices?
    What seems to be the consensus with the best plug for this engine?
    I'm really confused.
    Pete
  2. Jan 25, 2020 at 8:44 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
    First off, the proper heat range is important.
    I have tried AC, Champion, Bosch and NGK. Hands down NGK, for my application is the best. That was the only plug I could run on the street, Time Trial the car (Corvette, not a Toyota), and still keep going on the same plugs. AC is also a good reliable plug.
    Many people will like the Denso. But I have had such good luck with NGK, I see no reason to switch. Any plug change in my Toyota's have always been NGK.
  3. Jan 25, 2020 at 8:47 AM
    What does your owner's manual say? @Roman parts guy give him your VIN# or call your dealer run #VIN they should tell you
    Roman likes this.
  4. Jan 25, 2020 at 2:44 PM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    When you decide on which plugs are correct make sure to buy from a reputable vendor. There are cheap Chinese counterfeit NGK spark plugs for sale on eBay and Amazon. There's a thread on here that goes into detail about this.
  5. Jan 27, 2020 at 9:18 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
  6. Jul 31, 2021 at 11:24 AM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    Please help fellas I’m getting conflicting info on correct Denso part number for plugs.
    My VIN engine specs.
    My manual specs
    My questions are:
    What engine do I have according to manual?
    What Denso part number do I need?
    Is .043 the correct gap?
  7. Jul 31, 2021 at 11:37 AM
    40cpe
    40cpe New Member
    gene
    2008 double cab 5.7L
    none
    The 5.7L is the 3UR-FE engine. The factory plug was Denso SK20HR11 according to my 2008 manual.
    Shanet421 likes this.
