Spare tire
Discussion in 'Wheels & Tires' started by Willskaf, Apr 29, 2020.
  1. Apr 29, 2020 at 10:16 PM
    Willskaf
    Willskaf [OP] New Member
    William
    Castro Valley, CA
    19, Limited, CrewMax, Off Road, Cement Gray
    None Yet
    Hey Fellas,
    Ok, so I lifted my truck and put 295/70/18 Ridge Grapplers. I completely forgot about the spare . The spare is still the OEM 275/65/18. For some of you that did the same, what did you do with the spare. Did you get matching tire or left it with he smaller tire ?
  2. Apr 29, 2020 at 10:29 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Perfect usable as a spare
    Ncherry84 and 1lowlife like this.
  3. Apr 29, 2020 at 10:40 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    ^ +1
  4. Apr 29, 2020 at 11:24 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    You can't use 4 wheel drive with a smaller tire in the front. It's best to have the same size spare. If you look at the little donuts that some cars have for spares, the tire says on it, don't drive more than 50 mi. I think the tire will last for far more than 50 miles but what you're doing to the diff is causing a lot of extra heat.
    Flyinryank and dcsleeper408 like this.
  5. Apr 30, 2020 at 1:16 AM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Full size + matching rim. Better safe than sorry!
    831Tun and Flyinryank like this.
  6. Apr 30, 2020 at 7:06 AM
    7.62X51
    7.62X51 New Member
    Virginia Beach
    Will an after market 18X9 wheel with a 295/70/18 tire on it fit where the original spare is?
    dcsleeper408 likes this.
  7. Apr 30, 2020 at 7:10 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yes. 35s will fit so....
    831Tun and dcsleeper408 like this.
  8. Apr 30, 2020 at 7:12 AM
    7.62X51
    7.62X51 New Member
    Virginia Beach
    Oh Cool, Thanks I appreciate it.
  9. Apr 30, 2020 at 7:12 AM
    Ncherry84
    Ncherry84 New Member
    Nate
    Dickinson, ND
    2020 Tundra SR5 CrewMax Magnetic Gray Metallic
    Stock
    You would be fine in a bind to get you off the road and to a service station to get the tire replaced. If you have a rear flat not using 4wd then put the spare up front and good tire back. Front flat so long as you're not using 4x4 will be ok as the front diff does nothing anyways as its disconnected in 2wd.
  10. Apr 30, 2020 at 7:25 AM
    Suck it up and buy a matching spare.
    Flyinryank, 831Tun and texasrho83 like this.
  11. Apr 30, 2020 at 7:31 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Here's my spare lol
  12. May 1, 2020 at 9:48 PM
    EBenke
    EBenke I’m Ready To Go!
    Everett
    2007 Toyota Tundra DC, 5.7, 4x4
    3/2 lift, Icons, 35's, 3" CB's shackles
    I just threw a matching BFG AT on my spare, just in case.
  13. May 29, 2020 at 1:04 PM
    Stig
    Stig New Member
    Just got done modding my spare guide tabs.
    Cooper AT3 XLT 295/70/18 on scs wheel was not even close to fitting with the original guide tabs.
    I drilled out the rivets in case I want to reinstall the guides further out. For now I left them off and I think it's fine.
    Only thing is, in a rear end collision, the hitch normally gets slammed into the spare tire. Nothing is really stopping it from moving further forward and hitting the diff with the guides removed, but that'd be a pretty big slam to go that far.
  14. May 29, 2020 at 1:59 PM
    Lockmonster00
    Lockmonster00 New Member
    Dallas, Tx
    2015 Red SR5 4x4
    When I got my new tires, I purchased the cheapest 20inch rim the guy had and mounted 1 of the older tires that was still in perfect condition.
    Was like $50 out the door as the rims were discontinued and they only had 2 total left.
    YardBird likes this.
