Spare tire with a slide-in camper
Discussion in 'Wheels & Tires' started by Scruffy_Nerf, Oct 19, 2022.
  1. Oct 19, 2022 at 10:03 PM
    Scruffy_Nerf
    Scruffy_Nerf [OP] New Member
    2022 Toyota Tundra SR5
    I’m getting ready to take delivery of a slide-in camper for my ‘22 Tundra and have concerns about the factory spare tire handling the increased load if I need to use it while loaded. I currently have 2 sets of wheels. One with OEM wheels and KO2s and the other with OEM wheels and factory Yokohama tires. As I see it, I have 3 options.
    1. Use the factory spare. My concern is load capacity and a reduced ability to get home before having to go to a shop due to the spare not being full sized. I often find myself 100 to 200 miles from home.
    2. Use one of the wheels from my second set as a spare. My concern is mainly with degradation to this tire, from being stored under the truck, leading to unbalanced wear on my second set of wheels. I could rotate the wheel out periodically but that seems like a hassle.
    3. Buy another wheel and tire and use it to replace the factory spare. My only real concern is the cost.
    Any advice would be greatly appreciated.
  2. Oct 20, 2022 at 9:56 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    a 2022 does not have a full size spare with a tire of the same load/capacity as what is on the truck?
  3. Oct 20, 2022 at 10:02 AM
    Scruffy_Nerf
    Not on the SR5 at least. I got a flat and the tire shop was fairly surprised. I’m not sure about the higher trimmed models.
    I imagine having a lower profile (smaller width) spare tire makes a small difference in fuel economy and weight savings. It probably also costs less for Toyota.
  4. Oct 20, 2022 at 10:40 AM
    frichco228
    Im quite surprised as well. Ive never heard of a half ton truck not having a full capacity spare of the same size and load rating as what is on the truck. Guess it is about Toyota saving a few bucks. Space saver spares are fine for cars, emergency use, but a truck that may be working, towing, hauling needs a full capacity spare. I mean, what if you got a flat while towing a 6000lb camper? That is a safety issue to me/
    Id definitely get another SR or SR5 rim and another tire to match what you run. Will a real tire fit where the space saver spare sits?
  5. Oct 20, 2022 at 10:48 AM
    Scruffy_Nerf
    I was able to get the factory wheel and tire in the spare tire space. I imagine people with 35” tires will need to do some modifications.
  6. Oct 20, 2022 at 11:36 AM
    Scruffy_Nerf
    At the scale Toyota makes these decisions, I can see why they made the decision they did for a few reasons including cost.
    • Improving fuel economy, even marginally, on a fleet of vehicles traveling millions of miles per year can make a big difference.
    • Reducing cost, even marginally, can make a big difference at Toyota’s sales volume.
    • Including a donut instead of a full-sized spare is unlikely to change the purchase decision for the majority of buyers.
    I’m certainly frustrated with Toyota’s choice here but I understand it and I don’t regret my purchase because of it. I honestly didn’t factor this into my purchase decision when I got the truck and it wouldn’t now that I’m the position I find myself. With that said, I totally understand why people might feel differently.
  7. Nov 4, 2022 at 7:43 AM
    Scruffy_Nerf
    I am thinking about picking up a set of SR steelies with tires for $300 and swapping out my spare with one of the those. It’s not the perfect solution but much cheaper than buying a new single wheel and tire.
