SPARE TIRE STORAGE
Discussion in 'General Tundra Discussion' started by SILVER FOX, Mar 1, 2020.
  1. Mar 1, 2020 at 4:53 PM
    SILVER FOX
    SILVER FOX [OP] New Member
    GARY
    IDAHO
    2015 SILVER DOUBLE CAB
    BULL BAR ** FENDER FLAIRS ** TINTED WINDOWS ** VISOR VENTS.....so far. :)
    Does anybody out there know why Toyota wants the spare tire stored with the valve stem facing up?? Not easy to check air pressure on it.
    Rica25 likes this.
  2. Mar 1, 2020 at 4:54 PM
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    2017 Barcelona TRD Limited CrewMax
    3/1.5 Toytec/Icon AAL, 17" Rebounds, 317-70-70 ST Maxx's
    Flip it around and call it good.
  3. Mar 1, 2020 at 5:04 PM
    Professional Hand Model
    Hand Protectors
    This is what I did. So far so good.
    Medic343 and AZBoatHauler like this.
  4. Mar 1, 2020 at 5:06 PM
    SILVER FOX
    GARY
    IDAHO
    I'm gonna do it tomorrow. Just spoke to the stealership: "never had anybody ask." :facepalm:
  5. Mar 1, 2020 at 8:37 PM
    jordan0317
    jordan0317 Just hoodrat things...
    Jordan
    Martin, TN
    2017 White Tundra XP 4x4
    Maybe so that the risk of it getting ripped off is reduced if you drag it across something offroad?
  6. Mar 1, 2020 at 8:55 PM
    SILVER FOX
    GARY
    IDAHO
    That is a possibility - I'll take measurements before and after just to see what changes. Thanks for the input.
  7. Mar 1, 2020 at 9:05 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    I assume it’s because of rim offset and the winch end/hub hook. If the valve stem is pointed down you might not have enough cable to fully lower the winch as well.
    jordan0317 likes this.
  8. Mar 1, 2020 at 9:49 PM
    SILVER FOX
    GARY
    IDAHO
    I thought of that and I have extra chain and a grinder or "French" links to extend to the correct length.
    I can always go back if needed. ***Necessity is the mother
    of invention.**
    Mountun Goat likes this.
  9. Mar 2, 2020 at 4:30 PM
    SILVER FOX
    GARY
    IDAHO
    Soooo...I was thinking :crazy: last night and came up with this thought: why deal with the spare, why not deal with the lousy lowering mechanism; it's inconvenient, flimsy when used and frustrating. :frusty:
    The following is what I came up with:
    It was made with all spare parts laying around the shop.
    ** a threaded eye hook, ground down and sized to the same dimension as the OEM. (Grind threads to press fit into 3/8" square tubing.) I put a roll pin through the tube and threads of the eye hook. Just in case it wants to freely rotate (visible when you zoom in.)
    ** length of 1/2" (1/2" OD 3/8"ID) square tubing. It just fits a 3/8" drive socket. :yes:
    **an old or cheap 3/8" socket drive or drive handle.
    ** one roll pin or nail or cotter key or???
    - It will stay in the truck. Ya don't have to put it together....
    - it fits the OEM jack.
    -You can operate it AND watch the spare tire seat into its cavity. Or just stand there and crank till its tight.
    It's not fancy, but wait till its sanded, primed, painted and pin striped.
    GODZILLA, TheBeast and Mountun Goat like this.
  10. Mar 2, 2020 at 4:37 PM
    TheBeast The Beach
    need battery operated ratchet now :) ala Milwaukee M12
    DaddyPete likes this.
  11. Mar 2, 2020 at 4:39 PM
    SILVER FOX
    GARY
    IDAHO
    ....yeah BluTooth....
