Spare Tire Size Fit
Discussion in '1st Gen Tundras (2000-2006)' started by wingnutted, Feb 10, 2020.
  1. Feb 10, 2020 at 2:03 PM
    wingnutted
    wingnutted [OP] New Member
    Seattle
    2006 Black Tundra TRD Double Cab
    Does anyone think I would have an issue fitting a 33" spare tire under the truck? Tire size is 255/80/17, so it's actually a little bit narrower than stock, but a larger overall diameter.
    My assumption is that it would fit fine, but I figure one of you fine folks will have actual experience with a similar (or larger) diameter tire!
    mcharfauros likes this.
  2. Feb 10, 2020 at 2:07 PM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    Shouldn't be a problem
    mcharfauros and wingnutted[OP] like this.
  3. Feb 10, 2020 at 2:13 PM
    Professional Hand Model
    Hand Protectors
    I have a 32.8” (285/75/r16) spare which just barely fits. Survey says....
    Its doable!
    mcharfauros and MrAristo like this.
  4. Feb 10, 2020 at 2:24 PM
    wingnutted
    Seattle
    Is the fit issue due to width of your tire (285) or overall diameter?
  5. Feb 10, 2020 at 2:30 PM
    Hand Protectors
    I have no issue because it does indeed fit, but if it was bigger/rounder (in diameter) I’d think it would become a problem. The tire width doesn’t factor in on this being a potential problem I don’t think.
  6. Feb 10, 2020 at 2:32 PM
    wingnutted
    Seattle
    Gotcha. It doesn't seem like all that many people are running this specific tire size, so I suppose I'll just get them all mounted and hope the spare fits!
  7. Feb 10, 2020 at 3:06 PM
    Hand Protectors
    I think you’ll be fine if its 33” as you say. Drop your existing spare and do any rust prevent or lubing the cable/bracket before the tire goons do your work. You could measure while under there just to be safe.
  8. Feb 10, 2020 at 5:55 PM
    speedtre
    speedtre New Member
    Inland Northwest
    I just put a 255\80R17 up there a couple weeks ago...no problem.
  9. Feb 10, 2020 at 6:05 PM
    wingnutted
    Seattle
    Awesome, thanks! Doesn't seem like it's a super common tire size to run, how have you been liking it?
  10. Feb 10, 2020 at 6:11 PM
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    I have a 275/70R 18 for a spare, and it barely fits.
    wingnutted[OP] likes this.
  11. Feb 10, 2020 at 6:16 PM
    speedtre
    speedtre New Member
    Inland Northwest
    So far so good....since I changed the whole suspension it's hard to say how the tires specifically feel...I can say they have done great in the snow and rain we've had here recently....Falken Wildpeak AT3s e-rated.
  12. Feb 10, 2020 at 6:54 PM
    wingnutted
    Seattle
    Yeah, same exact tire as what I ordered. I'm also doing 6112 / 5160 / SPC UCA / poly steering bushing at the same time as tires, so I'm imaging it will feel pretty much completely different. I really just didn't want something that was crazy wide (285, etc) but would still be larger in diameter than stock.
  13. Feb 10, 2020 at 7:34 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    My 315 70 17 (34.5" if I recall) fits no problem. Just hangs down a bit more than I'd like. Then again my exhaust hasn't been past my rear axle since I purchased the truck. Maybe someone would have issues fitting a tailpipe or whatever, but mine went right in place of the factory sized spare.
  14. Feb 11, 2020 at 4:03 AM
    speedtre
    speedtre New Member
    Inland Northwest
    Same setup I just went with with the exception of Freedom Offroad UCAs. It will feel no nothing like stock...that I can attest to...not really better or worse, just more like an old-school truck, less like a car. :)
  15. Feb 11, 2020 at 4:10 AM
    coTony
    Tony
    Montrose, CO
    I have a 35X12.5 under mine... she fits
    KarmaKannon and mcharfauros like this.
  16. Feb 16, 2020 at 7:12 AM
    coTony
    Tony
    Montrose, CO
    I forgot to mention I had to remove the two brackets that point towards the ground to get it in there. I just ground the head of the rivets off and hit them with a punch and DONE! I only took me 20 minutes once I had the tools under the truck and I laid down. I figured it would be longer but the grinder was key
    Ely010606 and Krautman73 like this.
  17. Feb 16, 2020 at 8:38 AM
    KarmaKannon
    Utah
    Some junk
    What year? I had no brackets in the way to fit a 35" on my first gen 2006
  18. Feb 17, 2020 at 6:29 PM
    coTony
    Tony
    Montrose, CO
    2018
  19. Feb 20, 2020 at 9:37 AM
    Krautman73
    Krautman73 New Member
    Austin, Tx
    2018 SR5 Crewmax TSS
    6" Maxtrac suspension lift 20x10 KMC XD Buck 25s with -24 offset 35x12.5x20 BFG KO2s Cherry Bomb Extreme muffler 2/1 Stubby antenna
    Good to know bro, going to be doing this soon...
  20. Mar 31, 2020 at 7:41 PM
    What the!?
    What the!? New Member
    2017 Pro
    I should have read this first. I spent about an hour today trying to drill the damn rivets out. Ended up busting my drill bit.
    After that I tried to use a cut off wheel on my dremel and went through 3 cut off discs. I eventually gave up and will fight the battle another day...
  21. Mar 31, 2020 at 8:14 PM
    Hhtundra
    Hhtundra New Member
    Get a 1/2 titanium drill bit, progressively drill up till you get to the 1/2 bit and it will grab the collar of the rivet and you can punch the other end out. I did this and was able to use one hole to secure the brackets. Make sure you use wd40 in between drilling or you break the bits.
    What the!? likes this.
  22. Mar 31, 2020 at 10:38 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Thanks for the info, planning to do this in my free time
