Spare Tire Rods Scratch Paint
Discussion in '2.5 Gen Tundras (2014-2021)' started by New_DoorDing, Feb 17, 2021.
  1. Feb 17, 2021 at 8:44 PM
    New_DoorDing
    New_DoorDing [OP] New Member
    2016 TRD Pro DoubleCab
    Fair warning to everyone. The factory rods to lower and raise your spare tire will scratch your trucks paint to the bare metal. Then you have to worry about rust. The paint will chip at the rectangular insert in between the tailgate and bumper. You could get a good angle on it by opening the tailgate. Make sure to apply primer if you see bare metal. Then you could apply touch up paint and clear coat afterwards. What you DONT want to do is leave the bare metal exposed. Given the location of that, it will rust before no time.
    I suggest using a shop rag between the rod and frame of truck to prevent from chipping your paint.
    DO NOT open your tailgate with the rods inserted. It will dent and chip your tailgate! :angrygirl:
    panicman, TundraRV and Ely010606 like this.
  2. Feb 17, 2021 at 8:59 PM
    TundraRV
    TundraRV New Member
    2021 SR5 SX Double Cab
    Yeah I just removed my spare off my truck and will store it in bed. I’ll double check that hole. Thanks
  3. Feb 17, 2021 at 9:00 PM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    so sad to see this...Although its a little different, One of the reasons why I said from the get go do not put anything on the bumper...too easy to drop tailgate on objects. I don't even set drinks on my bumper.
    New_DoorDing[OP] and panicman like this.
  4. Feb 17, 2021 at 9:17 PM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    I set a headlamp on mine and forgot it!!
    luckily I just had to buff out the scratch.
    New_DoorDing[OP] likes this.
  5. Feb 18, 2021 at 6:22 AM
    Geezer
    Geezer New Member
    Heart of the Catskills
    2019 Tundra Limited
    From experience on other pickups, even an accumulation of snow or ice can cause a dent in the tailgate if you lower it without clearing the bumper. Fortunately we have the damper to slow it down.
  6. Feb 18, 2021 at 7:56 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I’d think door edge protector would work but maybe the metal is too thin there? Could also try the 3M version that’s just a clear film.
    https://www.amazon.com/dp/B07W6T7M4C/ref=cm_sw_r_cp_awdb_imm_B93FNPPWH1T92D0H6EX5
    3M Door Edge Protection Film, 08582, 36 Inch https://smile.amazon.com/dp/B00650N...abc_20JPPTKM9M69SYBA4QAJ?_encoding=UTF8&psc=1
  7. Feb 18, 2021 at 8:36 AM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Instead of trying to find a grommet that fits the access hole in the body, install the rod, make a mark where it meets the metal, and wrap some protectant around the rod. I used a piece of rubber ice shield, works great. :)
  8. Feb 18, 2021 at 10:29 AM
    mtntop
    mtntop New Member
    2004 4x4 Access Cab SR5
    Tilly is definitely an outside of the box thinker!
  9. Feb 18, 2021 at 10:37 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    This is what I did when I had a spare under the bed.
