Spare tire releasing mechanism rusted
Discussion in '1st Gen Tundras (2000-2006)' started by Sip, Feb 17, 2019.
  1. Feb 17, 2019 at 12:18 PM
    Sip
    Sip [OP] New Member
    2004 Double Cab
    I'm new to Tundras.com and was looking for some info on the spare tire releasing mechanism. I have a 2004 Double Cab and the Releasing mechanism is rusted and frozen. I cannot engage the mechanism to turn and lower the spare. Anyone have this problem. I wanted to check before I got under there with a grinder and cut it out. HELP!
  2. Feb 24, 2019 at 7:40 AM
    Benyo
    Benyo New Member
    Hudson, NY
    03 SR5 4x4 AC
    Mine’s pretty visibly rusted, been meaning to test it for function. Worried I’ll be faced with the same delimma. Believe the replacement mount system is pretty cheap and easy to install though, once you get the old one off!
  3. Feb 24, 2019 at 7:53 AM
    BestGen
    BestGen New Member
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    Welcome aboard! :cheers:
    Try soaking it with PBblaster for a few days and see if it helps. :fingerscrossed:
    15whtrd likes this.
