Spare tire max size ?
Discussion in 'Wheels & Tires' started by TheBeast, Mar 8, 2018.
  1. Mar 8, 2018 at 1:18 PM
    TheBeast [OP] The Beach
    what the biggest you can fit without any cutting ? will 295/70/18 works ?
    also, would you use/trust the steel rim for your spare or get the matching rim in case you had to use your spare in an off road situation ?
    831Tun likes this.
  2. Mar 8, 2018 at 1:20 PM
    I hoping my 295/70/18 will fit but highly doubtful without some modification.
  3. Mar 8, 2018 at 1:21 PM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    295 fit under without the tabs cut.
    if you cut the tabs you can maneuver the spare away from stuff, would help if you had a extra set of hands.
    I say go full size rim if you can.
  4. Mar 8, 2018 at 1:23 PM
    I'm just gonna cut off the tabs and be done with it.
    dcsleeper408[QUOTED] likes this.
  5. Mar 8, 2018 at 1:26 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    I would.
    When you get to cranking it up just have someone crank it up while you guide it where you want. Bring it tight, then 1/4 to 1/2 turn after. you'll be fine.
    My bfd fits fine under.
  6. Mar 8, 2018 at 1:31 PM
    #BALLERSTATUS
  7. Mar 8, 2018 at 1:31 PM
    also, I guess you also have to take into account the size of shackles, for example the CB ones are pretty thick.
    dcsleeper408 likes this.
  8. Mar 8, 2018 at 1:31 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Lmao.. no no no.
    #blemishedwheelstatus
  9. Mar 8, 2018 at 1:33 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Yeah CB 295 will be close possible touch. But with the tabs removed u can maneuver away a bit.
    Helps with the cb bolt head on inner part of shackle and nuts on outward.
  10. Mar 8, 2018 at 1:34 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Don’t you have methods?!
    I bet you can find one on eBay for a steal.. maybe Craig’s.
    GodlessPro and joonbug like this.
  11. Mar 8, 2018 at 1:40 PM
    15whtrd
    15whtrd Mr. Blonde
    Whatever you do make sure you can use your stock Lugnuts with your spare. If you can’t obviously make sure you have the proper Lugnuts for the spare.
    Now you have me thinking the spare is steel on my truck but I have the TRD rims. I was pretty sure steel rims take conical Lugnuts. Maybe the factory spare is different than standard steel wheels?
    TheBeast[OP] and dcsleeper408 like this.
  12. Mar 8, 2018 at 1:45 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    I think factory spare uses factory lugs, but there is a huge sticker saying TEMP USE ONLY.
  13. Mar 8, 2018 at 1:58 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    That sticker is a bit disconcerting but I've seen the same (11 hole or whatever) design used as wheels. So, I'm unsure as to whether or not you could drive a couple hundred miles off road with it.
    I just drilled out the tabs for the spare tire guides the other day. @joonbug said his tire (295 70 18) now sits .25 - .5" higher.IMG_20180306_161021542.jpg
  14. Mar 8, 2018 at 1:59 PM
    that's a good point.
  15. Mar 8, 2018 at 2:02 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    if you can save the tabs and do it right. do it this way!
    really good job @831Tun :thumbsup:
  16. Mar 8, 2018 at 2:03 PM
    but a 295/70/18 will fit with the tabs in.
    831Tun and dcsleeper408 like this.
  17. Mar 8, 2018 at 2:09 PM
    Paul84
    Paul84 New Member
    Paul
    2014 4x4 Crewmax
    I have a 295 spare with CB +3 shackles and it barely fits. I cut the tabs and had to use a spacer block at the back of the hitch to keep it away from the shackles. So far seems fine.
    dcsleeper408 and 15whtrd like this.
  18. Mar 8, 2018 at 2:26 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Yep, it'll fit
  19. Mar 8, 2018 at 4:31 PM
    need to find a cheap method Standard....
    joonbug likes this.
  20. Mar 8, 2018 at 5:21 PM
    stsuda
    stsuda New Member
    2018 Magnetic Gray Tundra Double-Cab Limited
    Does anyone know if a 295/70/18 will not only fit (tabs or no tabs) but stay unscathed enough to put in the tire rotation?
    joonbug likes this.
  21. Mar 8, 2018 at 5:23 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Yes, I do a 5 tire rotation. Just gets dirtier than shit under there.
  22. Mar 8, 2018 at 5:23 PM
    Paul84
    Paul84 New Member
    Paul
    2014 4x4 Crewmax
    Yup me too. 5 tire rotation
  23. Mar 8, 2018 at 6:14 PM
    jc153
    jc153 Speed-ish Glamper
    San Diego
    2009 Tundra Ltd CM 4x4
    TC Front Long Travel, ADV Glass Fenders & Bedsides, TC Spindle Gussets & King LT Coilovers, RCV Axles, DuroBumps, CB Steering & Carrier Bearing Drop Kit, SDHQ ABS Sensor Shields, Rear 3.0 ADS Triple Bypasses w/MCM Fab Under Bed Shock Mount Relocation, SUA Deaver I96HD Springs & TC Shackles, MCM Fab Rear Hydro Bumpstop Kit, Solid Offroad Engine Mounts, 17" Method Standards, 37/12.5/17 Toyo RT's, Nitro 488 Gears w/Auburn LSD, Evil Off Road Bumpers, RCI Skid Plates, White Knuckle Sliders, Dirty Deeds Ind. BAMuffler 8" Catback, Baja Designs Lighting, SwitchPros Controller, Custom PS Cooler Relocation Kit, Custom Dual Battery Setup
    I have a 35/12.50/17 Toyo RT in the stock spare location. I pounded the tabs flat (will probably drill out the tab rivets eventually) and had to replace my CB shackles with some from Total Chaos. CB shackles are really thick and rubbed the tire tread. It fits fine now. I also do a 5 tire rotation.
  24. Mar 8, 2018 at 6:17 PM
    good to know
  25. Mar 8, 2018 at 6:46 PM
    I'm usually cranking it up/down by myself. What a fucking pain in the ass.
  26. Mar 8, 2018 at 6:50 PM
    Porschetech29
    Porschetech29 New Member
    Francis
    Rancho Cucamonga, CA
    2008 white double cab 4x4
    My 35x12.5x17 General Grabber x3 fits with the tabs removed.
  27. Apr 18, 2018 at 9:15 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Spare tire question for any of you guys.. if I have 37’s and 22 inch wheel.. just to get to a store or whatever.. could I put a 35 tire on there with a smaller wheel? Or a 37 tire with smaller wheel.. would any of that work ??
  28. Apr 18, 2018 at 10:08 AM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Yeah you should be ok with that. If it's a smaller tire just make sure the spare goes up front so you don't mess with the gearing
    Jsena[QUOTED] and 15whtrd like this.
  29. Apr 18, 2018 at 10:10 AM
    15whtrd
    15whtrd Mr. Blonde
    I wouldn’t do it in 4 x 4 or if you’ve got a locker. You wouldn’t want tires spinning at different ratios. But otherwise I would say go for it.
    Jsena[QUOTED] likes this.
  30. Apr 18, 2018 at 10:13 AM
    15whtrd
    15whtrd Mr. Blonde
    This is probably the best bet. I had a 2x ram with a locker. I got a flat out in the desert and my spare was smaller than my running set up. What a hot pain in the ass that was to put the spare on the front then relocate the front to the rear where I had flat tire. Hundred degree weather 2 tire changes 2 lane hwy LOL
    I felt like people were looking at me, going WTF is that guy doing changing that tire when the other ones flat? LMAO
