Spare Tire Hoist
Discussion in '1st Gen Tundras (2000-2006)' started by sgruver78, Jul 3, 2018.
  1. Jul 3, 2018 at 4:28 AM
    sgruver78
    sgruver78 [OP] New Member
    2000 Tundra TRD
    Just bought a 2000 Tundra and was so excited that I didn't see any rust or leaks that I didn't even notice it didn't have a spare tire. Anyway, while looking under there I noticed that the hoist plate is rotted so it wouldn't even hold the spare anyway. Is there any way just to get the plate? Seem silly to replace the whole unit for 100 bucks when only the plate is bad. I am attaching a picture to show you what part I am talking about. Thanks!
  2. Jul 3, 2018 at 5:55 AM
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
    check ebay, they're the same from 00 to 06.
    or make your own steel plate, if you have the means.
    Otherwise, they're an assembly and aren't available as separate pieces.
    Tundra2 likes this.
  3. Jul 3, 2018 at 6:00 AM
    Ha! I need one for me T100! At the end of the cable ther was like a piece of metal smashed to hold the bracket that holds the tire and the cable broke loose from that metal tab and there are 4 bolts that hold the hoist but only 2 can be removed other 2 looks like the bed has to be removed @LOTSOFTOYS anyway around this? Or any other T100 owner or Taco owner see this???
  4. Jul 3, 2018 at 12:01 PM
    Professional Hand Model
    Hand Protectors
    The thinness of that braided cable sketches me out everytime I’m under the truck inspecting things. Might look into making a bracket/wedge mount as an auxillary backup.
  5. Jul 5, 2018 at 7:48 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Lift the bed
    joonbug likes this.
  6. Jul 6, 2018 at 5:27 AM
    I thought so
  7. Aug 15, 2020 at 11:20 PM
    DrOfficer
    DrOfficer New Member
    M
    2000 Toyota Tundra SR5 V6
    None
    New to the forum but thought I would chime in on this question. Just to be honest with everyone. I have no Automotive experience and I think the most technical thing I did was change my rotors on my 2009 Toyota Corolla. However I like to think myself handy and can accomplish pretty moderate tasks with direction. With that being said I replaced my girlfriends spare tire lift yesterday. You do not need to remove the truck bed.
    Step 1: Remove the four bolts from the top.
    Step 2: The mechanism that turns ( which lowers the cable) pull down on it.
    Step 3: As you pull down on it there should be enough room for you to angle the bottom part out.
    Step 4: Install new part the way you took out old part.
    Hope that helps. I also went to a you pull and pic I and found a replacement for 19 dollars. I cleaned it up and it looks good as new. So I can't comment on a non oem part.
    jimf909 and Pucks18 like this.
  8. Mar 6, 2021 at 12:59 PM
    jimf909
    jimf909 Battery almost dead...
    Washington or Idaho
    '03 Tundra SR5 AC 4.7 TRD w/LSD
    Dead stock with oem 16" starfish wheels. We'll see how long that lasts. :) Topper of unknown origin.
    FWIW, the bolt that threads into the welded on nut is an M8x1.25. 16mm or 20mm length.
  9. Mar 13, 2021 at 8:08 AM
    jimf909
    Washington or Idaho
  10. Mar 13, 2021 at 8:13 AM
    jimf909
    Washington or Idaho
    I think the hoist is pretty secure but if I was concerned I'd take a bike lock cable and run it through the wheel and around the frame. It's be noisy if the hoist busted but at least you wouldn't drop a bomb for the motorcyclist following you.
  11. Apr 24, 2023 at 1:05 PM
    bluelogic
    bluelogic New Member
    @jimf909 How did you get the hoist off? What size socket did you use to remove them? I have tried 8mm-13mm and extractor sockets, and they all slip off. I'm about to cut the welded nuts off the frame.
    Bluelogic
    w666 likes this.
  12. Apr 24, 2023 at 1:56 PM
    bluelogic
    I checked for recalls, and my VIN returns zero unrepaired recalls. I did have the airbag replaced.
  13. Apr 24, 2023 at 2:18 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Guess you’ll have to buy one I suppose.
  14. Apr 24, 2023 at 2:20 PM
    bluelogic
    I'm cool with having to get a new one. I want to remove the old one off.
  15. Apr 24, 2023 at 4:17 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    I cut mine off with a cutoff wheel, and then used through bolts/nuts to attach the new one.
    bluelogic[QUOTED] likes this.
  16. Apr 24, 2023 at 4:20 PM
    bluelogic
    This is awesome. I'm going to use mini hack saw. Yes I know it will be slow. What is the length of the bolt? Also what did you use to clean up the rust?
  17. Apr 24, 2023 at 4:45 PM
    w666
    Maryland
    A mini hacksaw will take you ALL DAY. Go to Harbor Freight and buy a cheap angle grinder (do be mindful of which direction the sparks fly). There are religious debates about rust treatment. I like Permatex Rust Converter, and Eastwood Rust Encapsulator on top. One advantage over POR-15 is that Eastwood comes in aerosol as well. Regardless of the product(s) you choose, the key to success is preparation. I don't recall the length of the bolts (other than too long as I now see in the pic), just some I had laying around.
  18. Apr 24, 2023 at 5:34 PM
    Or even a Dremel with cutoff discs. That's an easy one to pull off.
  19. Apr 24, 2023 at 5:58 PM
    bluelogic
    Ok. I saw it was only spot welded on my frame and figure I could just cut the corners and the nut would come loose.
  20. Apr 26, 2023 at 1:15 PM
    bluelogic
    I know what you mean by sparks when I was under there and saw my gas tank. Cut with the guard going from the front to the back. I have a bunch of Ryobi tools so I ended up using
    Bluelogic
    w666[QUOTED] likes this.
