Spare Tire carrier options
Discussion in '2.5 Gen Tundras (2014-2021)' started by dcsleeper408, Apr 26, 2016.
  1. Apr 26, 2016 at 11:27 AM
    dcsleeper408
    dcsleeper408 [OP] BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Wondering what you guys are running as far as an In-bed spare tire carrier.
    I've seen folks mount 35" down low w/ removal of the guides..
    I wanted to have 2 full size spares.
    Really considering Wilco's hitch option at the moment. But I gotta keep the budget down.
    So for the mean time any ones ideas can help!
    Looking at this one as well if anyone has tried this.
    http://www.amazon.com/Spare-Tire-Ca...=1461694283&sr=1-17&keywords=spare+tire+mount
    -Mark
  2. May 5, 2016 at 12:21 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  3. May 5, 2016 at 4:48 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Picking up my 35" spare this weekend. and mounting it Sunday.. gonna try to work it down low under the bed. I'll be shaving the guides for sure, but not completely off.
    I also made sure when I installed the CB shackles that the bolt head was on the inside and not towards the outside like most ppl run.
  4. May 5, 2016 at 5:15 PM
    Cubanchem
    Cubanchem New Member
    Pedro
    Washington, DC
    TBD
    That looks like a cool option. I looked for a tailgate swing out tire carrier and couldn't find one that didn't require a specific bumper, not the OEM bumper. This would eliminate the need for a new bumper.
  5. May 5, 2016 at 5:54 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    si5, allstar617 and Ancient1 like this.
  6. May 5, 2016 at 6:38 PM
    Cubanchem
    Pedro
    Washington, DC
    TBD
  7. May 5, 2016 at 8:13 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    No problemo!
    It's a nice setup! Tryna convince the wifey, "we can use it for the tacoma and the tundra!" Lol she isn't having it right now hah.. Maybe try again next week.
  8. May 6, 2016 at 3:10 AM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
  9. May 6, 2016 at 3:15 AM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
  10. May 6, 2016 at 6:52 AM
    csuviper
    Broomfield, CO
  11. May 6, 2016 at 8:31 AM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    @csuviper Hah! wow that does look sketchy.. I think the wilco one would be more balanced. But havent seen any videos/reviews about wheeling with the wilco setup.
  12. May 6, 2016 at 10:16 AM
    csuviper
    Broomfield, CO
    Wilco one does look nice. They say it doesn't wobble in the video from the page. Pricey though.
    dcsleeper408[OP] likes this.
  13. May 6, 2016 at 11:59 AM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Yeah! it does look well built.
    Pricey, but you know how that saying goes.. "you get what you pay for."
    It's a much better option for me, so I can swap between the taco and the tundra on different occasions w/o buying 2 swing out bumpers for each truck.. Right?!!? we'll see if this one works with her :devil: . :argue:
  14. Aug 4, 2016 at 2:13 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Welp. Ended up not going with a hitch mount after asking a few folks who had them. They just didn't seem stout and would block the rear camera for sure.
    The second spare I will tie down in my bed for now. Just as long as I have full size with me at all times I am happy.
    Got it mounted underneath.
    Specs of rim:18x9 +12
    Tire: General grabber M/T 35x12.50r18 weight is 106lbs ish.
    Had to cut the brackets, bash them in a bit with a bfh, smoothen it out with stone bits, and paint black for rust prevention.
    Really close to shackles, but lucky I flipped the bolts the other way when installing he shackles knowing I was going to try to mount underneath in the future.
    Got lucky it was far from the Trd dual exhaust as well. It does touch the hangers a bit. Just as long as you have someone crank it up while you maneuver it into place and line it up you will be good.
    If I had a ko2 underneath I would definitely clear a lot more since diameter is a bit smaller @ 34.50
    But it works for now. I'm happy with it. And got a few wheeling trips coming up so we will see how it holds up. Assuming worse case scenario would be those bolts will scrape the nubs.. But I will update this as much as possible.
    Thanks to different forums and the tundra community for all the info and guidance.
  15. Aug 5, 2016 at 12:32 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    I had a lot of wobble in my cooler holder in the front receiver. Got something like this and it calmed it right down.
    https://www.amazon.com/Stainless-St...=1470425298&sr=1-7&keywords=hitch+accessories
    si5 and dcsleeper408[OP] like this.
  16. Aug 5, 2016 at 11:07 PM
    cheehab
    cheehab Fan Boy
    Southern Maine
    2015 TRD Pro CrewMax
    Wow! That looks tight. The Toytec shackles are thinner and would allow a bit more clearance I think
    dcsleeper408[OP] and csuviper like this.
  17. May 24, 2017 at 9:55 PM
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    N-Fab recently came out with a bed cage for two spares. What do you guys think?
    NewImprovedRon likes this.
  18. May 24, 2017 at 10:03 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    @dcsleeper408
    I don't think i've seen an update to this thread with your follow up information on how the tight squeeze after some off road trips. Maybe i missed your update....
  19. May 24, 2017 at 10:08 PM
    Eclipsed & Floating
    Voluptuous Whitey
    I like it but i think it would take up too much space for my liking. I think i'd like it if the rack spanned the entire width of the bed and had the spares all the way against each side of the bed for carrying 2. maybe even have a locking cabinet of some sort that is fabbed in to the rack. Sounds expensive but i think i might try to find something with stackable center space or a cabinet/box for between the spares
  20. May 24, 2017 at 10:37 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    I'm preparing for a trip this weekend. I am checking the spare tomorrow. We'll see if it had any contact/damage the shackle etc.
  21. May 25, 2017 at 9:24 AM
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    NFAB Bed rail mount.
    Ol’Remy likes this.
  22. May 25, 2017 at 10:52 AM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    So I pulled the spare tire out and examined it for any damages..
    No damages what so ever.(other than the rub from the bottom side of frame where it rests-cranked up)
    No gashes or anything from the shackles being close.
    Air psi dropped about 3psi (filled 45 last check-42 on this check.)
    Wheel weights look all intact
    No gashes either from any ass dragging- if I ever had any incident.
    still want to get a swing out with a higher clearance bumper and hitch..
    Tundra88, jro05065 and joonbug like this.
  23. May 25, 2017 at 11:25 AM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    I should've put a thick coat of tire shine before i mounted back up......
