Spare tire carrier mod
Discussion in '1st Gen Tundras (2000-2006)' started by remington351, Sep 5, 2021.
  1. Sep 5, 2021 at 7:56 PM
    remington351
    remington351 [OP] New Member
    2006 SR5 DoubleCab
    Hi Guys,
    Quick mod to the spare tire carrier that I did this week. I always seem to forget to check the psi in my spare tire until after the truck is loaded and i'm leaving for a trip at 4am. Then I gotta lower it down, knock off mud and grime, and hoist it back up again. Not a huge deal I know, but still a pain.
    I wanted to install the spare with the valve facing down so I could check it real quick. Pretty easy to do. Grind off some aluminum from the wheel and grind some metal off the hoist.
    The hoist unbolts from the top. You have just enough room to fit a ratchet with 11mm or 12mm extended socket between the carrier crossmember and the underside of the bed. The square nuts are tack welded to the carrier.
    FrenchToasty likes this.
  2. Sep 5, 2021 at 8:06 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Have you tried driving with the spare yet? That’s probably going to throw the balance off.
    MT Madman and GODZILLA like this.
  3. Sep 5, 2021 at 8:11 PM
    remington351
    2006 SR5 DoubleCab
    I'm sure it will, but it's a spare. Probably wont drive more than 100 miles before I get the regular tire patched or replaced.
    I don't do the 5 wheel rotation pattern.
  4. Sep 5, 2021 at 8:14 PM
    TXTundra2722
    2015 Black Tundra
    Balance shhmalance...... we ain't got any time for that hocus pocus, voodoo stuff!
    :curls:
  5. Sep 5, 2021 at 8:38 PM
    I guess my only question is, how do you keep the anodized face from getting all jacked up? One of the benefits of it facing upwards is surface preservation. Dunno about you, but I don't like the of slaving over polishing wheel surfaces with Mother's M&W Polish to get things shiny in the event I need to use it. Nor needing to re-anodize or something due to road sludge and chemicals sitting on the face.
    Edit: I don't want to sound all super negative. Kudos for creativity. This is definitely a well-thought out mod. I don't think I'd personally do it, but clearly serves a purpose of function and looks cool.
  6. Sep 5, 2021 at 10:52 PM
    Siebler
    Siebler Taco Tow Vehicle
    CJ
    Eastern Oregon
    01 AC 4x4,07 Sequoia 4x4, 99 Tacoma Long Travel
    Monstaliner, Kings and Camburg UCA, projector retros, DD injectors, homebuilt bumper/ sliders
  7. Sep 6, 2021 at 4:40 AM
    RR60
    RR60 New Member
    2003 SR5 Tundra long bed
    If I remember right. My valve stem is fine. But I have a plain steel wheel that came on the 2003 Tundra. Like on a base model with the hubcaps.
    Does not look good. But I would not leave the spare on a long time anyway.
  8. Sep 6, 2021 at 4:52 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Another advantage of dropping the spare to check it is that you'll know that you can actually drop the spare (that it's not rusted in place). I once had to use bolt cutters to get my spare out. I have 3 Toyotas with the same mechanism, so now I make a point to drop the spare and lubricate the cable/mechanism once or twice a year.
