Spare Solution on 4" lift - spacer or new wheel?
Discussion in 'Wheels & Tires' started by rt_tundra_co, Jan 28, 2019.
  1. Jan 28, 2019 at 3:01 PM
    rt_tundra_co
    rt_tundra_co [OP] I'll get tired of tweaking this truck...never
    '15 SR5 CM TRD
    Magnaflow cat-back exhaust Leer Topper, color matched to truck Thule Aeroblade roof rack on topper FABTECH 4” Suspension Lift Decked Storage, 2 drawer SPYDER LED headlights and taillights kits Hertz HDP5 5 Channel Class D Amplifier 2 x 10” subwoofer boxed behind rear seat Door speaker upgrades by Elite Auto Sound Colorado Springs Lock’er Down EXxtreme Console Safe LD2043EX Lock’er Down rear seat 3 x safes Lock’er Down gun magnet 80 LED in-grill light bar Baja Designs LED ditch lights TRD Pro grill Rotiform SIX-OR 20x9 wheels 35x12.5R20 Toyota Open Country R/T tires TheSource sPOD power control hub with in-cab installed accessory switches Firestone Ride Rite air suspension system with Air Command remote, on board compressor and rear bumper air port SDHQ rock sliders
    I figured that the original spare was just dead weight under my '15 CM with a 4" suspension lift and running 20" SIX-OR Rotiform wheels. I actually tried putting the spare on anyway this weekend and confirmed it - the spare bumps the suspension. So, I need a solution.
    I cannot go larger on the total diameter of the spare because I'm going to keep it stored under the bed. I was thinking that I'll either try and find a cheap wheel that has the offset I need or consider carrying a good spacer that I'll put on with the spare if/when I need it.
    I checked the Rotiform site and it says that my model of wheel has an "Offset" of "1"...?
    Also, I don't have much of a clue on how to measure for either solution. Anyone have suggestions?
  2. Jan 28, 2019 at 3:30 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    I'd get a spacer for now. At least it'll get you home, or to the shop. You can fit 35" tire in the spare location, few posts on it somewhere on here.
  3. Jan 28, 2019 at 4:36 PM
    You can get the 35” under the bed. I did.
    Marty McFly and Rica25 like this.
  4. Jan 28, 2019 at 5:25 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Not sure what suspension you have but you don’t need to get the exact same offset as your wheels. You don’t even need a 20” wheel. I’d look for something cheap with at least a +25 offset. Installing spacers at night on the side of the freeway is going to suck.
  5. Jan 28, 2019 at 8:35 PM
    rt_tundra_co
    '15 SR5 CM TRD
    The thought of doing that fills me with dread albeit a tiny bit less than not even being able to get the spare on the lugs!
    joonbug[QUOTED] likes this.
  6. Jan 28, 2019 at 8:36 PM
    rt_tundra_co
    '15 SR5 CM TRD
    I'll have to look for the post on how that was done because the brackets and bumper spacing only allows for the factory full size spare under my bed. Must have cut the brackets off...
    Rica25 likes this.
  7. Jan 28, 2019 at 8:58 PM
    Use a BFH. It’ll fit.
  8. Jan 28, 2019 at 9:01 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    That’s what she said.
    Is the stock cable strong enough to hold a 35 long term?
  9. Jan 28, 2019 at 9:04 PM
    rt_tundra_co
    '15 SR5 CM TRD
    I think I just found the post you guys were referring to by @bandit. According to him he removed the tabs, hitch and the muffler box. I'm not good with that. I could see cutting off the tabs but that's it.
    Any advice on where to look for cheap wheels? Cheapest option on Tire Rack for +255mm offset are $170.
  10. Jan 28, 2019 at 9:08 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    To fit 35’s all you need to do is cut off the 2 guides.
  11. Jan 28, 2019 at 9:08 PM
    rt_tundra_co
    '15 SR5 CM TRD
    Copy - thanks!
  12. Jan 29, 2019 at 7:47 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    After reading this thread, it reminded me that my spare is currently useless ! Does anyone have one spacer for sale ?
  13. Jan 29, 2019 at 8:12 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Maybe 4 of us should make a purchase together
  14. Jan 29, 2019 at 8:14 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    Lol, I'm game ! I'll probably never even use the spacer !
