Spacers for center carrier bearing?
Discussion in 'Suspension' started by TXRailRoadBandit73, Mar 29, 2017.
  1. Mar 29, 2017 at 5:05 PM
    TXRailRoadBandit73 [OP] YOTAS,RAILROADIN',RÖKnRÖLLN',BEER,MAX/GEMMA
    Hey fellas i researched my past threads but i looked at all responses and questions n i didn't ask.. as we all know my truck has a 6" lift on it with 35s just crawled under to check if everything is ok i noticed there are no spacers for center carrier bearing...do i need them? I feel no vibration at any speed jus wanted to get info on em..any info greatly appreciated
  2. Mar 29, 2017 at 8:38 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    If you aren't feeling any vibration when taking off from a stop, your driveshaft alignment is probably ok. Doesn't sound like you need a carrier bearing drop.
  3. Mar 29, 2017 at 10:30 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I'm surprised you don't have a CB drop with a 6" lift. But, like bobeast said, if you don't feel a vibration I would think you're probably OK.
  4. Oct 8, 2017 at 1:01 PM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    Is there an alternative solution to ordering — meaning, can I pick up a make shift set of the sort from the local store?
    Am on a 6 inch RC lift
    https://youtu.be/FXDSUpofy2U
  5. Oct 8, 2017 at 1:10 PM
    Les7311
    What measurements do I ask for?
  6. Oct 9, 2017 at 5:27 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    Coachbuilder1 and Law323 like this.
  7. Oct 18, 2017 at 11:29 AM
    Coachbuilder1
    Coachbuilder1 Industry Leader Vendor
    David
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    Thanks for the mention @andy9743 We build Cb drop kit in 2 sizes. from (0"-2"of rear lift small kit) (2.5"-5" of rear lift Large Kit) We have plenty built and ready to go if anyone is in need. Im also happy to help with sizing if needed. David 801-635-4872
    DVYota likes this.
  8. Oct 20, 2017 at 4:01 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
