Spacer on a lifted strut
Discussion in 'Suspension' started by Jetjr1981, May 14, 2017.
  1. May 14, 2017 at 6:27 PM
    Jetjr1981
    Jetjr1981 [OP] New Member
    2015 Tundra Cm Limited
    6 in RC Lift, 35 trail grapplers, 20x9 Fuel Hostage, Fender Flares and Grille
    2015 Tundra, Currently have a 6 inch RC lift, have the lifted N2.0 struts. I know they say to not put a spacer on a lifted strut, but I been hearing different from people. Some say as long as you don't off-road you will be fine to put a spacer on a lifted strut. Wanting to put a 2 inch spacer to even out with the my rear
  2. May 14, 2017 at 6:36 PM
    I have the RC 6" with extended rear shocks front is stock..i wana get rid of this setup hate it
  3. May 14, 2017 at 6:46 PM
    Jetjr1981
    Extended rear shocks? I thought the kit came with blocks for the back? My front sits lower either due to after market coils( old man Emu) kit was on the truck when I bought it and I went with the RC. Not sure if the coils are smaller than the stock ones, I know nothing about lifts. But I have the OME leaf pack in the rear, so I only put a 1 1/4 inch block roughly on the back instead of the 3 or 4 (whichever came with the RC kit). Not sure why my front sits lower, you can see it in the pic
    TXRailRoadBandit73 likes this.
  4. May 14, 2017 at 6:49 PM
    Yeah sorry yeah blocks in rear spacers up front with a smaller spacer added truck i bought used so it already had kit the rear shocks are longer because of kit i hate it rough ride feel every bump don't like cv axles angels turning radius decreases
  5. May 14, 2017 at 6:52 PM
    Nice rig
    AnonVet likes this.
  6. May 14, 2017 at 6:53 PM
    Actually i wanna bring down...toyotec (Boss Kit) or fabtec 4" kit i run 35s if i do boss kit i need oem knuckles
  7. May 14, 2017 at 7:20 PM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    IMG_1196.jpg I have the RC 6 inch lift
    Replaced front spacers to struts
    Rides like a truck
    AnonVet likes this.
  8. May 14, 2017 at 7:26 PM
    AnonVet
    AnonVet That's what she said!
    Weatherford TX
    2015 TRD SR5 CM
    7 inch pro comp 35x12.5 RPB Repulsars (Hate'em) 18x9 Rhino Glamis Bilstein 5100's TRD Pro grille Murdered out Spyder heads Smoked tails Leds all around her Debadged Go Rhino BR5 Front Bumper
    Mine has the same issue but smaller lift. I'm definitely interested in which way you go with thus because I'm wanting the same lift.
  9. May 14, 2017 at 7:37 PM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    Can you post some pics of your coilovers and the underside of your front and rear suspension? I'm curious how your coil-overs are adjusted. Did you measure your rear block under the leaf springs? Its possible someone put a larger block in the rear & your front suspension is setup lower. Some guys will crank the suspension as high as possible giving your truck a stiff ride and feel. For a 6" lift the front of your truck does look low from the photo.
