Spacer/block lift kit how important is the brand?
Discussion in 'Suspension' started by Daganh62, Jan 28, 2021.
  1. Jan 28, 2021 at 5:26 PM
    Daganh62
    Daganh62 [OP] New Member
    2017 TRD Off Road
    Hey guys new to the world of lifts. I've been researching putting a small spacer/block lift on my truck. How important is brand? Seems like it's just a hunk of metal. I have narrowed down my search to BDS, Zone, Rough Country, and Rugged. So if brand is important which should I go with? Thanks for the help in advance.
  2. Jan 28, 2021 at 5:49 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    This is not the answer that you want.
    I’m not sure what your model truck has stock and I don’t know what uses you plan for it but regardless, there’s no situation where a spacer/block lift won’t be detrimental to the truck, Either the ride or the durability of associated components will suffer, (or both). Acceptable for a mall queen, if the image that goes with a “lifted” truck is what you’re after
  3. Jan 28, 2021 at 6:04 PM
    rjsimz
    rjsimz New Member
    Rob
    2015 SR5 CrewMax 4x4
    ^^ Yes, just have to think about how you will be using the truck. Lots of guys I’ve seen are running the ready lift spacers with no problems.
    RoniusMaximus likes this.
  4. Jan 28, 2021 at 6:08 PM
    RoniusMaximus
    RoniusMaximus The One and Only
    J
    Tri-Cities, Washington
    2020 MGM Toyota Tundra TRD PRO
    Synthetic Blinker Fluid
    I have the readylift sat pro plus 2. Love it, rides like stock.
  5. Jan 28, 2021 at 6:44 PM
    I had the Readylift 3/2 and it rode rough as hell. I would spend a little more and at least move up to the Bilstein 5100's.
  6. Jan 28, 2021 at 6:45 PM
    Skew12
    Skew12 New Member
    2010 Black Rock Warrior
    Don’t do it.
  7. Jan 28, 2021 at 7:20 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    The brand does not matter. Currently have 61000 miles with a block and I tow regularly, no issues.
    Daganh62[QUOTED][OP] likes this.
  8. Jan 29, 2021 at 5:21 AM
    PhilActual
    PhilActual New Member
    Phil
    2018 Doublecab SR5 5.7 4x4
    SDHQ ABS guards, Hondo Garage/Ram phone/GPS mounts, 275/65r18 duratracs
    Try the Low Range Offroad kit. It's the only kit that has bumostop spacers. As long as your bumpstops work you shouldn't blow out any struts when you bottom out.
    Daganh62[OP] likes this.
  9. Jan 29, 2021 at 4:38 PM
    usaf.2012
    usaf.2012 New Member
    AK
    2010 Black CM Tundra RW
    10" BAMuffler // Bilstein 5100s all around & front on Mid setting // Toytec shackles // BHLM
    Second the 5100s and consider using shackles vice block in the rear.
