Southern truck headed north, advice?
Discussion in 'General Tundra Discussion' started by Sumo91, Dec 11, 2020.
  1. Dec 11, 2020 at 9:00 AM
    Sumo91
    Sumo91 [OP] Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    So the gf and I have a trip planned to Colorado in the next couple weeks. I'm guessing there will be snow, which means salt on the roads. We will only be up there for about 4 or 5 days. Will being exposed to salt for this period of time cause any rust issues? I'm not sure what to do exactly because we never salt the roads down here. Will I be ok to just wait till I get back down south to wash the truck off? I'd rather not apply any fluid film or other products for a short trip like this if I don't need to.
    Any driving in the snow. Should I keep it in 4 hi on the roads? I plan on getting some sandbags in the bed to place over the axle once I arrive and unpack. Just not sure how much weight I need.
    This southern boy needs help!
  2. Dec 11, 2020 at 9:02 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    For that period of time don't worry about any of it.
    Throw it in 4hi if the roads are slippery and go.
    Pkahir12 and Sumo91[OP] like this.
  3. Dec 11, 2020 at 9:03 AM
    TaquitoBandito
    Joel (AKA Bif)
    Been a long time since growing up in Northern Michigan. My dad had a little blue Toyota pickup that I got to drive. Rear wheel drive, nothing fancy. I seem to remember keeping big bags of dirt or cat litter in the back to help with the weight and to use as traction if you get stuck. Never happened to me though - just take it slow and give yourself plenty of room to stop. Have a great trip!
    Sumo91[OP] likes this.
  4. Dec 11, 2020 at 9:11 AM
    Gould71
    Gould71 Member
    2017 Platinum Midnight Black
    TRD swaybar, TRD shift knob, FN FX Pro wheels, Toyo AT/IIIs, VLED interior and puddles
    Put it in 4wd if the roads are slippery, just be mindful that driving on pavement that has good traction can be stressful on the 4x4 system. 4 or 5 of those 60lb sand tubes can help with traction in both 2 and 4wd. Hopefully you have a decent set of all-season or AT tires on the truck. Summer tires up in the mountains will be dicey. Also, depending on where you are going, there might be a requirement for tire chains on some of the high passes or if there’s a storm warning.
    As for the salt, just give the undercarriage a good hose-down with clean water when you get back. Shouldn’t be an issue at all.
    Have a good trip!
  5. Dec 11, 2020 at 9:19 AM
    Sumo91
    TN
    Thanks for the advice everyone! I'll keep it in 2wd unless needed. I'll get 300lbs or so of sand bags to put in the back. I have the falken wildpeak at3w tires. I believe they're rated well for snow. My main concern was the rust issue. Glad to hear I won't have any issues with that. I'll do some research on where we will be traveling exactly to see if there is a tire chain requirement.
  6. Dec 11, 2020 at 9:29 AM
    Gould71
    Gould71 Member
    You have some really good tires- you’re golden there. I wouldn’t worry too much about the sandbags then- I see now you have a crewmax. They put a little more weight in the rear axle than a DC.
    ColoradoTJ and Sumo91[OP] like this.
  7. Dec 11, 2020 at 9:46 AM
    LATERAL G
    LATERAL G New Member
    2013 RCSB SR5 TRD Off-Road 5.7 4x4
    great white north guy here
    wash underneath every day if you feel so inclined
    or buy some rustproofing spray online and give the frame a good coat
    even WD40 would work, just not as well as say fluid film
    but like others have said, you may not have to worry about it at all
    I'm going to assume you dont have any rustproofing places down where you are
    drive safe!
    cheers!!
  8. Dec 11, 2020 at 9:55 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Irrigate the underside of your chassis with liberal amounts of low pressure fresh water when you return.
    Sumo91[OP] and Rex Kramer like this.
  9. Dec 11, 2020 at 10:02 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Colorado doesn't salt the roads, they put sand down or just plow.
  10. Dec 11, 2020 at 10:24 AM
    Medinasmoke
    Medinasmoke New Member
    hugh
    Ohio
    2020 black crew max
    I take sprinkler to it. After returning from beach
    Sumo91[OP] and hagrid[QUOTED] like this.
  11. Dec 11, 2020 at 10:31 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    And this is why your roads are flavorless.
    @Saltyhero13 ... front and center, young man. Pack an overnight case including prodigious quantities of personal lubricant. You're Colorado bound to un-f**k the tasteless road situation out there.
  12. Dec 11, 2020 at 10:32 AM
    Sumo91
    TN
    More good advice here. I love this forum. It's helpful, hilarious, and I'm happy to be a member! And no, we don't have rustproofing places here, we get flash rust or light surface rust from the humidity, but that's about as far as it goes with almost anything I've encountered. So Colorado puts sand on the roads instead of salt? I didn't know that. Pretty interesting. If its just sand I won't even have to worry about an immediate wash. I have tons of sand and gravel under there now from my most recent escapade
    hagrid likes this.
  13. Dec 11, 2020 at 11:49 AM
    Sharpienads
    Sharpienads New Member
    2018 Tundra SR5 TRD O/R
    Like already stated, they just put sand down. Which is cool until you get 70mph winds and you truck sounds like it's getting sandblasted.
    I personally wouldn't put any weight in the back. Never did in colorado and still don't in Alaska. The best advice is to drive according to road/weather conditions, which can vary greatly by time/location in Colorado. Where are you planning on going? The snow doesn't usually stick around for long unless your up in the mountains.
  14. Dec 11, 2020 at 12:00 PM
    Sumo91
    TN
    I'll have to check with my gf on the locations, all I know right now is "Colorado". I need to listen to her better :D I'm pretty sure its in the mountains at a couple cabins and a hot spring
    Sharpienads[QUOTED] likes this.
  15. Dec 11, 2020 at 12:03 PM
    Sharpienads
    Nice. Have fun, lots to do in CO.
    Sumo91[QUOTED][OP] likes this.
  16. Dec 11, 2020 at 2:28 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Outrage! OUTRAGE I SAY! What is the culinary travesty! LET. THE. UNCOUTH. HAVE. SALT!!! <starts gyrating in the roadway tastefully>
    hagrid[QUOTED] and Sumo91[OP] like this.
  17. Dec 11, 2020 at 2:53 PM
    rock climber
    I don't think I'll ever look at a Colorado road the same after this :)
    hagrid and Sumo91[OP] like this.
  18. Dec 11, 2020 at 2:56 PM
    Saltyhero13
    We can recommend a good psychiatrist to deal with the trauma. Discount code: SALTYTUNDRA
    hagrid likes this.
  19. Dec 11, 2020 at 3:05 PM
    hagrid, Sumo91[OP] and Sharpienads like this.
  20. Dec 11, 2020 at 3:06 PM
    Good tires, I would leave the sandbags at home, drive for conditions. Wash the truck off when you return.
  21. Dec 11, 2020 at 3:08 PM
    Sharpienads
  22. Dec 11, 2020 at 3:12 PM
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    They seem to have quite a number of warm water self car washes.
    When you get there rinse the truck real good then do it again when leaving.
    I thought the locals would look at me like I was crazy until I saw the line of local cars waiting to wash
    Up after 18” fresh.
  23. Dec 11, 2020 at 3:17 PM
    For a while now. Salt is cheap and used with mag chloride...works great.
  24. Dec 11, 2020 at 3:42 PM
    Sumo91
    TN
    So the only place I know of right now is Monument CO. I'll update once I know of the other places we are going.
