Sound like the air compressor kicking off when cold
Discussion in '1st Gen Tundras (2000-2006)' started by RoscoethaDon, Oct 9, 2023.
  1. Oct 9, 2023 at 10:09 PM
    RoscoethaDon
    RoscoethaDon [OP] New Member
    I have a 2006, 4.7, 4x4 with about 80K on it. Only when the engine is cold it does this, but a short time after startup, the engine lets out this sound as if the air compressor is kicking off and it can breathe again. It's not the air compressor (I don't think). After that, Rex purrs like a kitten. I'm not extremely concerned about it, but I would like to know if it's normal. I don't remember it doing this before. With age, maybe there are vacuum issues? I really just want to get ahead of any potential problems.
    FrenchToasty likes this.
  2. Oct 9, 2023 at 10:12 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    It’s called the secondary air injection pump system it’s normal, and it’s normal for them to fail
  3. Oct 9, 2023 at 10:16 PM
    RoscoethaDon
    Thanks for the info. At least I know it is a thing now. What do you mean by fail?
  4. Oct 9, 2023 at 10:18 PM
    FrenchToasty
    Mo
    Bone stock
    There’s valves and pumps and sensors, not sure which is the most common failure, but little worry, there is a bypass for certain failure codes? Hewitbypass or the likes, is one of them.
  5. Oct 9, 2023 at 10:20 PM
    RoscoethaDon
    Got it. Thanks a ton!
  6. Oct 9, 2023 at 10:20 PM
    FrenchToasty
    Mo
    Bone stock
    It’s a emissions thing. That’s all. It helps pre warm your cats.
  7. Oct 9, 2023 at 10:20 PM
    40man
    40man New Member
    If you run the engine for 10 or 15 minutes, shut down, then restart immediately and don't hear it, highly likely it's air pump as it wont activate when the cats are hot. If not, could be a serpentine belt.
  8. Oct 9, 2023 at 10:21 PM
    RoscoethaDon
    That describes it perfectly.
  9. Oct 10, 2023 at 9:10 AM
    shifty` I'm having daydreams about night things
    Are you throwing any codes yet (check engine light) for it?
    Pump is expensive, but can be bypassed, though not technically emissions-legal.
