Sound Deadening
Discussion in 'Audio & Video' started by Ps3udonymous, Nov 10, 2017.
  1. Nov 10, 2017 at 5:51 AM
    Ps3udonymous
    Ps3udonymous [OP] Who is the smart ass that changed the title?
    Has anyone done a diy, could be any vehicle. I've heard of people using hvac insulation. Wondering if there are any other alternatives to spending big bucks on the products designed for this.
    NativeHoustonian58 likes this.
  2. Nov 10, 2017 at 6:00 AM
    trueaspect
    trueaspect New Member
    2017 Platnium Tundra
  3. Nov 10, 2017 at 6:23 AM
    Cfincke
    San Antonio
    I installed dynamat extreme on all 4 doors last weekend, used 14 sheets (56sq.ft.) for near 100% on both inner and outer door skins. I also installed a 1/4 sheet on the dynaliner 1/4" thick behind the speaker to help with resonance off the outer door skin from the speaker cone. Took me 12-14 hours or so to install it all. I had to quarter the sheets to fit thru the door opening. I disconnected all the wire clips and cut out for them and the door panel attachment points.
    Here is the door from the factory.
    Here is part way thru the install on this door
    Here is the complete door
    Here is a photo of where I installed the dynaliner. There is a 9"x18" strip above and below the inner crossbar, plus I wrapped the cross bar with a 5" strip.
  4. Nov 10, 2017 at 6:25 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    I've used rammat on a few. Would not use anything else.
    FlashCulprit and MotoTundra like this.
  5. Nov 10, 2017 at 6:44 AM
    That really worth it? Went into audio place that stuff pretty expensive...
    FlashCulprit likes this.
  6. Nov 10, 2017 at 6:45 AM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Just curious how much difference you think it made?
    I dynamatted my entire cab of my old 98 taco so yea I know it's a lot of work.
  7. Nov 10, 2017 at 6:46 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    it is absolutely worth it.
  8. Nov 10, 2017 at 7:14 AM
    Cfincke
    San Antonio
    Amazon - I bought the bulk packs for $150 or so a box. The MSRP is $280 or so. I found a study of 15-20 sound deadening products someone on an audio forum did over a year or two. For performance to weight, the dynamat was the best deal and it was the 2nd or 3rd best in his tests. The winner was way more expensive and was almost twice as thick. Some of the cheaper products are a tar based material which is not good for areas with high heat (texas).
  9. Nov 10, 2017 at 7:16 AM
    Cfincke
    San Antonio
    I still have the floor to go. It made a big difference for the stock JBL speakers. There is noticably more base now. I cannot wait till I install my JL speakers and amps
  10. Nov 10, 2017 at 7:43 AM
    Newm
    Newm New Member
    KC
    I did my tundra last spring. Gutted the entire truck and used CLD tiles, Mass Loaded Vinyl (MLV), Closed Cell Foam (CCF) and a little Butyl. Some pretty good info in the link below.
    https://www.sounddeadenershowdown.com/
  11. Nov 10, 2017 at 10:38 AM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    i may be going that route. did you buy the pre-packaged kit he has?
  12. Nov 10, 2017 at 11:40 AM
    Newm
    Newm New Member
    KC
    I did. You could save some money though just buying the materials separate on Amazon. I was going to go that route but Don (the owner I believe) was so helpful during the process I wanted to give him my business. He answered numerous emails with all kinds of stupid questions I had and even offered his number up for contact on the weekend I was doing the install if I needed any advice or help.
    It really did help with the sounds quality of the stock HU in my truck. That and road noise was noticeably reduced. If you do it and have any questions just holler at me and I'll try and help.
    831Tun and smslavin[QUOTED] like this.
  13. Nov 10, 2017 at 2:47 PM
    FlashCulprit
    FlashCulprit ColoradoTJ's whipping boy/Gino's illegitimate son.
    Joe
    Salt Lake City, UT
    2010 Super White SR5 TRD 5.7 4x4
    Hopping on the dynamat train. Used in all my vehicles for audio or engine noise. It's a little more expensive but if you shop around it's not too bad. I absolutely love it.
  14. Nov 10, 2017 at 3:00 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Nice work Newm.
    The doors on the 3rd gen sound tinny and cheap if shut too hard. Did it help them sound a bit more solid when closing? I would imagine it made a big difference but want to be sure.
    Newm[QUOTED] likes this.
  15. Nov 10, 2017 at 3:39 PM
    Juanjoolio007
    Juanjoolio007 New Member
    Oregon
    24 Blueprint Sequoia Platinum / 23 Tesla MYP
    Yeah it makes a huge difference. Mine are dynomated on every surface. When those Focals start screaming there is zero rattle or noise from the doors. They sound solid when you close them. I remember the first time I shut them after the stereo was done.
    vipgs3, smslavin and 831Tun[QUOTED] like this.
  16. Nov 10, 2017 at 4:49 PM
    Newm
    Newm New Member
    KC
    100% huge difference in the feel of the door. It feels way more solid and heavyer feeling... in a good way. If you knock on the exterior of the door it sounds like a solid core door in a house instead of the empty can kinda sound.
  17. Nov 10, 2017 at 5:11 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Thanks. I like solid feeling doors. I made all the doors for my house and all the stiles and rails are at least 2" thick.
    One more mod for the truck.
    Thanks
    Juanjoolio007
    Juanjoolio007 and Newm[QUOTED] like this.
  18. Nov 10, 2017 at 6:06 PM
    Ps3udonymous
    Those of y'all that used dynamic, or other similar products, did they actually make a noticeable difference?
  19. Nov 10, 2017 at 6:18 PM
    Cfincke
    San Antonio
    Yes, both sound quality and cut down on road noise. I fully dynamatted my 2002 Tundra after installing some flowmaster mufflers. Driving for 30 minutes gave me headaches, so I lined the doors, floor, and back wall.
  20. Nov 11, 2017 at 6:59 AM
    Ps3udonymous
    Well I guess I'm gonna have to do it.
  21. Jan 14, 2022 at 9:02 AM
    DCarboletti
    DCarboletti New Member
    2017 Platinum Crewmax
    Newm, from the research I've done, it looks like you used the most effective method for reducing road noise. I would like to do the same very, very soon. Too bad the sounddeadenershowdown is offline. I was able to read some of their pages through the wayback machine (internet archive). I'll be getting materials online this week if anyone has any suggestions!
  22. Oct 24, 2022 at 10:09 AM
    kstateskier
    kstateskier New Member
    Bradley
    Kansas City, MO
    2022 Tunda 1794 - Dark Metallic Grey
    What are you guys using for a moisture barrier on the rear doors? Does the butyl backed panels provide enough over the holes? I was going to cut new plastic sheeting to recover mine? Replacements from Toyota are $12.50 each which is fine but its still just plastic sheeting glued on.
  23. Oct 24, 2022 at 10:10 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I imagine you could make your own out of 10 mil plastic if can find some scrap/small pieces and some butyl adhesive.
    kstateskier[QUOTED] likes this.
  24. Oct 25, 2022 at 5:13 AM
    coTony
    Tony
    Montrose, CO
    This is in my future
  25. Dec 3, 2023 at 7:17 PM
    MrJimmyPenguin
    MrJimmyPenguin Penguined
    Jimmy
    2021 Black Crewmax Toyota Tundra TRD Off Road Premium 4x4
    Future arrived?
    coTony[QUOTED] likes this.
  26. Dec 7, 2023 at 9:51 AM
    coTony
    Tony
    Montrose, CO
    Well I cannot see it being a priority looking at costs and what else I can get for the cost. I don't want the smell in my truck I hear a lot of people complain about and others say they can smell something but not bad. On the fence but leaning towards a no
  27. Dec 7, 2023 at 4:37 PM
    MrJimmyPenguin
    Jimmy
    ....ok there is no smell and you'd be looking at less than $500 in materials for overkill coverage but alright.
