Sooo - I’ve been considering getting rid of my Tundra
Discussion in 'General Tundra Discussion' started by DalTee, Mar 29, 2018.
  1. Mar 29, 2018 at 9:33 AM
    DalTee
    DalTee [OP] New Member
    Dal
    2011 SuperWhite CrewMax Limited
    Extang Folding Tonneau, 20 percent tint, TRD dual exhaust, BedMat, Stubby antennae, Bully Hitch Step, AVS Window Shades
    This flashing dash light thing is killing me. I love my truck, but I feel like a huge repair is coming and I don’t want to deal with it.
    Has anyone come up with a fix for the flashing dash lights
  2. Mar 29, 2018 at 9:42 AM
    DalTee
    Dal
    It seems as if the flashing lights are happening more frequently -
    Everyone I take it to the dealer it’s something else -
    Battery
    Alternator
    Sensors
    I’m getting tired
  3. Mar 29, 2018 at 10:29 AM
    What do you mean by flashing lights?
    zcarpenter92 likes this.
  4. Mar 29, 2018 at 10:34 AM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    Got pictures or videos?
  5. Mar 29, 2018 at 12:45 PM
    DalTee
    Dal
    Hi lo
    Traction
    Speedometer jumping
    Tach jumping
    Brake
    Abs
    Air bag
    But no check engine light
    Also battery dies quickly - in about a half hour if I’m sitting in it - battery is dead. No start.
    Randy Morton likes this.
  6. Mar 29, 2018 at 1:08 PM
    nk1794
    San Jose, CA
    This is not a good reason to get rid of the truck. :) Any corrosion on the posts? Make sure + and - terminals are tight. Check the alternator. If you have a volt meter you can check while the engine is running. It should be 14.X volts. You can also take the alternator to Autozone and they will check it for you for free.
    I have one of these testers. It's handy for this type of troubleshooting.
    https://www.amazon.com/gp/product/B01ANF1D7U/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
    GNTundra, wasabi4 and T-Rex266 like this.
  7. Mar 29, 2018 at 1:08 PM
    wasabi4
    wasabi4 New Member
    Lee
    2017 Limited CM 4x4
    sounds like the battery is bad. sometimes a bad battery will cause all sorts of lights to go off. how old is the battery you're running?
    NewImprovedRon, Upgrayedd and nk1794 like this.
  8. Mar 29, 2018 at 1:09 PM
    nk1794
    San Jose, CA
    :thumbsup:
  9. Mar 29, 2018 at 1:14 PM
    DalTee
    Dal
    I bought it in November after the lights went nuts the first time.
  10. Mar 29, 2018 at 1:16 PM
    DalTee
    Dal
    It’s running at 14v. Dealer says the alternator Is good. It’s maintained per the book. It’s frustrating.
  11. Mar 29, 2018 at 1:20 PM
    rustynail11
    rustynail11 New Member
    Scott
    Mansfield,TX (DFW Area)
    2017 Grey Tundra TRD
    check you negative battery terminal. I haven't had this issue with my Tundra but with my Jeep Wrangler the same thing would happen if the negative battery cable was loose.
    Mountun Goat, wasabi4 and DalTee[OP] like this.
  12. Mar 29, 2018 at 1:26 PM
    nk1794
    San Jose, CA
    You might need to take it to a shop that's specialized in electrical system or someone that knows how to look for parasitic drain on the system. If you have any aftermarket electronics like amps and other things you might want to leave them in plugged and see if that helps.
    wasabi4 likes this.
  13. Mar 29, 2018 at 1:34 PM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    The battery drain is the biggest indicator. Put an ammeter in line with the battery cable and see how much current is being drawn. Then, start pulling fuses until the drain goes away. That'll tell you which subsystem is causing problems. If the dealer hasn't done this test, find one with competent mechanics.
  14. Mar 29, 2018 at 2:23 PM
    DalTee
    Dal
    I don’t have anything connected to the electoral system except an alarm
    Randy Morton[QUOTED] likes this.
  15. Mar 29, 2018 at 2:28 PM
    Randy Morton
    Randy
    The entire truck electrical system is connected to the battery. Something is draining it, the ammeter and systematic removal of load will tell you what's wrong.
  16. Mar 29, 2018 at 2:32 PM
    DalTee
    Dal
    It seems to be a fairly common problem but no one has any answers
  17. Mar 29, 2018 at 2:33 PM
    DalTee
    Dal
  18. Mar 29, 2018 at 3:04 PM
    Adam New Member
    IDK about fairly common issue...That being said, it sucks it is happening.
    Does it throw any codes when you hook it up? And what do you mean by the battery goes dead in a half hour if your sitting in it? Is the key in the ignition? What setting?
  19. Mar 29, 2018 at 3:11 PM
    That almost looks like a broken wheel sensor. Also, the actuator will not allow you to shift in/out of 4wd unless you're moving. At a stand still it normally will not do anything such as your video.
    Marty McFly and Pudge like this.
  20. Mar 29, 2018 at 3:25 PM
    Right, in low you need to engage high first. But nothing will occur parked like he was...
  21. Mar 29, 2018 at 3:32 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Just trade it in for a new 1. Problem solved
    DalTee[OP] likes this.
  22. Mar 29, 2018 at 3:38 PM
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    I have seen threads like these before over on TT. Seems like every time it was either a broken sensor or damaged wire to the sensors. I'd start by checking the wheel sensors first as someone already mentioned.
    T-Rex266 and Boerseun like this.
  23. Mar 29, 2018 at 3:45 PM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    Looking at the video my first thought was that it is Christmas. But then, maybe not. Maybe the wheel sensors. In seriousness, I would agree with the wheel sensors. I have had one that on a previous work truck where the cable got pinched and did something similar. If not the sensor, then go the route of checking the drain on the battery by eliminating areas through pulling fuses as someone has already mentioned above.
  24. Mar 29, 2018 at 4:07 PM
    Bailey
    Bailey Enjoy Every Sandwich
    CO
    2011 DCSB Limited 4x4 “Clifford”
    Taken from another forum. Hope this helps:
    Adam, 1UPPER, Newm and 4 others like this.
  25. Mar 29, 2018 at 4:19 PM
    TheBeast The Beach
    rodent chew some electric wiring maybe ?
  26. Mar 29, 2018 at 6:00 PM
    DalTee
    Dal
    Wow! Thank you very much!
  27. Mar 29, 2018 at 6:03 PM
    DalTee
    Dal
    I thought that too - especially since the wires are rodent attractive
  28. Mar 29, 2018 at 6:05 PM
    DalTee
    Dal
    Yep - one very similar to yours
  29. Mar 29, 2018 at 6:11 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    I hope you figure your problem out . You added an alarm? I'd check there first.
    But thank God for the electoral system.. MAGA!
    ColoradoTJ likes this.
  30. Mar 29, 2018 at 7:13 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    Quicksand is the best color and fastest so join the quicksand brotherhood
