Someone swapped a Lexus steering wheel into tundra
Discussion in '2nd Gen Tundras (2007-2013)' started by scotch, Jan 12, 2017.
  1. Jan 12, 2017 at 4:16 PM
    scotch
    scotch [OP] New Member
    Denver, CO
    2010 Tundra
    2010 Tundra Method 20x9 Fat Fives 18offset, 305/55/20 Duratracs, Bilstein 6112/5160, SPC/LR Upper Control Arms, TRD Rear Swaybar, OME/Dakar leafs with CB +1 Shackles, Husky Weatherbeaters, Du-Ha, Extang Solid Fold, Line-X, Toyota Bed Mat, Stoptech Cryo Rotors and pads, Goodridge brake lines, Stoptech STR-660, Rigid Fog Lights, Odyssey Battery, Firestone Airbags with CB spacer, etc, etc... Previous Toyota's: 97 4runner, 02 tacoma, 09 tacoma
    This wasn't me, just saw it posted elsewhere:
    https://forum.ih8mud.com/threads/steering-wheel-lexus-is-paddle-shift.232652/
    "On the Tundra, the clock spring in the steering column has the connections running through it for the steering wheel shift function to plug into. The plug/harness that connects to the clock spring in the steering column dosn't contain these two wires on the Tundra. So adding two pins to the connector along with two wires is all that is required. These wires then run down and splice into the stock sequential shift wires on the console shift."
    Law323 and BlueBottle like this.
  2. Jan 12, 2017 at 6:54 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    If I could find a heated wheel that would fit, I'd be all over it.
  3. Jan 13, 2017 at 8:04 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I remember reading about this, those steering wheels are ex-pen-sive. The air bag is the spendy part. I think I'd be content with a Lexus/Limited Tundra leather wheel.
