Some help and advice
Discussion in 'Wheels & Tires' started by Canuckian, Nov 10, 2018.
  1. Nov 10, 2018 at 1:51 PM
    Canuckian
    Canuckian [OP] New Member
    Living in British Columbia, they will be laying down sand and gravel all winter long. The offset of my winter rims was a little more then I anticipated, and I am curious if that will cause all that sand and gravel to blast my paint and body. Can anyone tell me if I should be concerned?
    The winters are Nokian Hakkapeliitta LT2 275/70 r18 - Factory Studded
    The rims are Procomp series 32
    I had to remove the small mud flaps at the front of the wheel well, and that seems pretty good. No cutting or trimming, but possibly a heat gun and a little plastic pushing
  2. Nov 10, 2018 at 1:53 PM
  3. Nov 10, 2018 at 1:54 PM
    To add, you can get a thin duraflap to stop most of the road debris.
  4. Nov 10, 2018 at 2:08 PM
    Blueknights75
    Ron
    Clayton, NC
    Beautiful truck! To answer your question, yes you should be concerned!
  5. Nov 10, 2018 at 2:12 PM
    Fender flares should be considered. You can always take them off in the spring.
  6. Nov 10, 2018 at 2:58 PM
    KirthGersen
    KirthGersen New Member
    So Calif
    2018 SR5 Crewmax
    Also, gravel & rocks could also be thrown up at the vehicle behind you ... not cool.
    Mikekoot and Black Wolf like this.
  7. Nov 13, 2018 at 8:59 AM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    Yea those wheels have a low offset, and you will certainly have crap thrown up and down the truck!!
    jewsNbrews and Mikekoot like this.
  8. Nov 13, 2018 at 9:10 AM
    Nice rig
  9. Nov 13, 2018 at 11:29 AM
    speckmon
    speckmon Must. Have. Pow.
    Thornton, CO
    '07 mountain road bomber
    Fender flares, big ole mud flaps, wide body kit....
  10. Nov 13, 2018 at 11:36 AM
    Mikekoot
    Mikekoot New Member
    Canadia
    2018 MGM tundra sr5 DC /2014 SSM Toyota Tacoma sr5 DCLB
    Where in BC? Yeah get steelies with proper offset. Save you a world of trouble
    Edit: nvm looks like Kamloops
  11. Nov 13, 2018 at 12:12 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Looks good in my opinion. Yes you will get some stuff flung up on the truck.
    jewsNbrews likes this.
  12. Nov 13, 2018 at 2:49 PM
    Canuckian
  13. Nov 14, 2018 at 8:22 AM
    parker44
    parker44 New Member
    Custom offset is a great site! I would definitely stay near +35mm if possible,
  14. Nov 14, 2018 at 10:06 AM
    Pit_goral
    Pit_goral New Member
    Piotr
    Greeley, Colorado
    17 Tundra Limited TRD OFF ROAD
    I had the same question before I saw a lots of paint chips from oem tires20180818_135656.jpg 20180818_142208.jpg
  15. Nov 25, 2018 at 11:53 AM
    Canuckian
    So thanks for all the advice. Shop was great and took back the rims and replaced them with these. Not a 100% sure, as they are a little glossy, but will soon be covered grit and dust from BC highways.
    2eepStn8T1e13adGcOd+wA.jpg UNADJUSTEDNONRAW_thumb_2f6d.jpg 2eepStn8T1e13adGcOd+wA.jpg rytiyHNUReKwbHUmojEeMQ.jpg
    parker44 and Y0TA PR0 like this.
