[Solved] Wire that only has voltage when cranking?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Overland_Mike, Apr 7, 2018.
  1. Apr 7, 2018 at 9:49 AM
    Overland_Mike
    Overland_Mike [OP] New Member
    2001 Tundra, Gen2 build plan in progress
    Like the title says. I'm trying to wiring in my ML-ACR battery isolator and they want me to hook up a wire that only has voltage when cranking. I suspect its going to be the harness at the ignition switch but I haven't seen any of the diagrams listing "only when cranking". I was gonna tear the column apart and test but if someone knew of another location that or even which wire at the column that would be awesome!
    Thanks!
    -M
    2014 5.7 CM
  2. Apr 7, 2018 at 10:03 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Overland_Mike[OP] likes this.
  3. Apr 7, 2018 at 10:31 AM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    Pudge likes this.
  4. Apr 7, 2018 at 11:48 AM
    Overland_Mike
    Thank you! I found it- dark green at the ignition harness.
    Much appreciated!
    nk1794 likes this.
  5. Apr 7, 2018 at 11:50 AM
    nk1794
    San Jose, CA
    :thumbsup:
