(SOLVED) Programming home link to electric gate opener?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Akaklutz, Nov 23, 2021.
  1. Nov 23, 2021 at 12:26 PM
    Akaklutz
    Akaklutz [OP] New Member
    Alan
    2021 Tundra
    New stock
    Hey guys I've tried the search but with my limited experience on forums I'm guessing I may have overlooked this topic.
    Anyways can we pair the home link to a power gate opener? The brand I ha e is ez gate.
  2. Nov 23, 2021 at 12:39 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    shouldn’t be a problem, a gate opener and a garage door opener work exactly the same way. You will just have to pair with your truck.
  3. Nov 23, 2021 at 12:43 PM
    Akaklutz
    Alan
    2021 Tundra
    New stock
    That was my thoughts. And I believe I had it programmed. The gate opened once but didn't close.
  4. Nov 23, 2021 at 5:01 PM
    ampruett
    ampruett New Member
    2018 DC XP
    Rear sway bar, stubby antenna, in channel window vents, seat covers, tool box
    Following as I can’t get my Ghost Controls programmed to open/close my gate
  5. Nov 23, 2021 at 5:11 PM
    Akaklutz
    Alan
    2021 Tundra
    New stock
    I checked the owners manual while ago. It directly state's. Home link will work on automatic gates...
    Well see I'm sure we'll figure it out..
  6. Nov 24, 2021 at 6:24 AM
    Southshore30
    Southshore30 New Member
    2018 Limited Crew Max
    What year did this begin please?
  7. Nov 24, 2021 at 6:27 AM
    DSLKSL
    DSLKSL New Member
    Don
    Is it possible the gate has one command for open and another for close?
    Akaklutz[OP] likes this.
  8. Nov 24, 2021 at 6:34 AM
    Akaklutz
    Alan
    2021 Tundra
    New stock
    Not sure I'm brand new to the Tundra family. But my owners manual states it will work on gates, doors, lights etc..
  9. Nov 24, 2021 at 6:34 AM
    Akaklutz
    Alan
    2021 Tundra
    New stock
    My thoughts exactly...
  10. Nov 24, 2021 at 6:35 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    What does your gate remote look like? Is it a single button or one for open and a different one to close? When you say you got it to open once but not close, can you close it with the normal method and open it again with the Homelink button? Or it worked once then never again? There’s a different process to pair rolling code remotes vs others.
    Mike59 likes this.
  11. Nov 24, 2021 at 6:39 AM
    Akaklutz
    Alan
    2021 Tundra
    New stock
    Well now that you put that way, with the same button opening and closing the gate that would appear the code is fixed and not a rolling code. I kinda feel stupid for not realizing that lol. But then again that's why I asked for advice..
    The remote has one button, press it once to open, and once again to close..
  12. Nov 24, 2021 at 6:39 AM
    Southshore30
    I only ask because I m new too. I’ve had a 2018 Limited for just about 2 months and don’t know if I had been missing something. I don’t think I have this in my truck
  13. Nov 24, 2021 at 6:45 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    If it’s a single button it’s still probably a rolling code, since I think most gates use that. I can’t remember what I finally had to do to get it to work, but it was an awkward process of 2-3 second hold and release until Homelink learned the remote.
  14. Nov 24, 2021 at 6:46 AM
    Akaklutz
    Alan
    2021 Tundra
    New stock
    I'm certain you do your limited has more bells and whistles then my base sr5.
    It's in the rear view mirror..
    Southshore30[QUOTED] likes this.
  15. Nov 24, 2021 at 6:48 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    It could also be in the roof console with the moon roof controls. That’s where my wife’s Highlander has them.
    Akaklutz[QUOTED][OP] likes this.
  16. Nov 24, 2021 at 10:42 AM
    SpyderRC
    SpyderRC New Member
    2021 Limited Nightshade
    I don’t see ez gate as compatible on the home link website, maybe that’s why you’re having issues.
  17. Nov 24, 2021 at 10:58 AM
    Akaklutz
    Alan
    2021 Tundra
    New stock
    Thanks never crossed my mind to look there lol. The gate opener goes under a couple of different brands. I'll have a look.
  18. Nov 24, 2021 at 11:28 AM
    Akaklutz
    Alan
    2021 Tundra
    New stock
    Thanks SpyderRC After looking on the home link website and following the directions there got it working. They differed slightly form the owners manual. I suppose different brands have different pairing sequences.
    Anyways got it working great. One button opens and closes the gate now.. :)
  19. Nov 24, 2021 at 3:47 PM
    SpyderRC
    SpyderRC New Member
    Glad to hear you got it working! :cheers:
  20. Nov 25, 2021 at 6:50 AM
    Southshore30
    Excellent! I’ll look there. I’d been looking in the console on the roof where it was in my GMC
  21. Nov 25, 2021 at 6:51 AM
    Southshore30
    That was my first thought!
