SOLVED Power Windows Not Working
Discussion in '2.5 Gen Tundras (2014-2021)' started by Thattundradude, Nov 3, 2018.
  1. Nov 3, 2018 at 11:55 AM
    Thattundradude
    Thattundradude [OP] New Member
    Platinum Tundra
    Lifted
    Hi all got a new issue in my tundra. All windows except for the driver one are not working. The locks work perfectly but the windows won't go down or up at all on all switches.
  2. Nov 3, 2018 at 12:19 PM
    What year Tundra we talking about?
    GNTundra likes this.
  3. Nov 3, 2018 at 12:36 PM
    Thattundradude
    Platinum Tundra
    Lifted
    2014 crewmax platinum
  4. Nov 3, 2018 at 12:39 PM
    Midnighttaco08
    Midnighttaco08 High Quality H2O Inspector
    Sam
    Gilbert, AZ
    2017 Quicksand TRD OR 4x4 2008 Indigo Ink Tacoma TRDOR
    None yet!
    I’m sure you already checked the window lockout?
    Maybe blown fuse?
    15whtrd likes this.
  5. Nov 3, 2018 at 12:40 PM
    You would think all windows would be affected the same. I wonder if this could be fuse related?
  6. Nov 3, 2018 at 12:45 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Lockout button stuck maybe
  7. Nov 3, 2018 at 12:49 PM
    Very good point..
  8. Nov 3, 2018 at 1:09 PM
    Thattundradude
    Platinum Tundra
    Lifted
    What's that? Is that on the connection of the main switch?
  9. Nov 3, 2018 at 1:23 PM
    csuviper
    Broomfield, CO
    15whtrd likes this.
  10. Nov 3, 2018 at 2:09 PM
    Thattundradude
    Platinum Tundra
    Lifted
    That's not the issue it's not clicked in.
  11. Nov 3, 2018 at 2:10 PM
    Thattundradude
    Platinum Tundra
    Lifted
    All fuses look good. I think this issue occurred when I tried swapping a driver window switch from a 2018 base tundra
  12. Nov 3, 2018 at 3:04 PM
    csuviper
    Broomfield, CO
    Well you didn’t say you switched anything out
    Midnighttaco08, TheBeast and 15whtrd like this.
  13. Nov 3, 2018 at 3:22 PM
    Thattundradude
    Platinum Tundra
    Lifted
    Yes I did
  14. Nov 3, 2018 at 3:22 PM
    Thattundradude
    Platinum Tundra
    Lifted
    Forgot to mention the switch replacement
  15. Nov 3, 2018 at 3:57 PM
    15whtrd
    15whtrd Mr. Blonde
    Tried disconnecting the battery?
  16. Nov 3, 2018 at 4:01 PM
    Thattundradude
    Platinum Tundra
    Lifted
    Tried the battery nothing. After trying the 2018 one I out my old one back on and it didn't work. That time it was a fuse the was blown replaced the fuse and the driver window started working. I didn't try the others at that time probably because it didn't come to my mind.
  17. Nov 3, 2018 at 4:03 PM
    15whtrd
    15whtrd Mr. Blonde
    This as well as and the drivers kick panel.
  18. Nov 3, 2018 at 4:05 PM
    Thattundradude
    Platinum Tundra
    Lifted
    I checked all fuses theres one left called main power 2 or 3 under the dashboard it's a 30amp but its bulky and I couldn't get it out
  19. Nov 3, 2018 at 4:08 PM
    15whtrd
    15whtrd Mr. Blonde
    Might need to grab it with some needle nose. I think it’s definitely a fuse issue.
  20. Nov 3, 2018 at 4:09 PM
    Thattundradude
    Platinum Tundra
    Lifted
    I really hope that's not the case those damm things are expensive
    15whtrd and GNTundra like this.
  21. Nov 3, 2018 at 4:10 PM
    Thattundradude
    Platinum Tundra
    Lifted
    I'll try it once I get it out again. Truck is driven about 10-15 times a month at most
  22. Jan 21, 2019 at 6:43 AM
    TechTundra
    TechTundra New Member
    Did you ever figure this out? I have a 2014 Tundra Platinum where same exact thing happened today, all windows except driver side works. When I press to lock the windows the indicator for the driver side does not change,still shows filled/colored, seems like while the lock will go down and up the driver side is not connected to it somehow.
  23. Jan 21, 2019 at 6:51 AM
    Thattundradude
    Platinum Tundra
    Lifted
    Fuses were bad on mine
    Pudge likes this.
  24. Mar 15, 2019 at 8:19 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Where are the fuses for window switches located? Does each window have it's own? My rear drivers side window switch stopped working yesterday
  25. Mar 15, 2019 at 10:59 PM
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    OP can you post a photo of the exact fuses for us all? Thanks man!
    Sunkissed likes this.
  26. Mar 16, 2019 at 7:10 AM
    Thattundradude
    Platinum Tundra
    Lifted
    The fuse was located under the driver side dash. I think it was called power something
    Inferno579, Sunkissed and Pudge like this.
  27. Jun 24, 2021 at 6:25 AM
    icoachem14
    icoachem14 New Member
    2014 Toyota Tundra Ltd
    I have a 2014 Tundra Limited. I was fixing my door locks and I believe, shorted out my windows. My passenger side windows wouldn't go down, but the master switch would allow them to go down (but not back up). Then, I took the switch on the passenger doors and tried to touch the connectors with the switch myself and it sparked a bit. The windows wouldn't go up or down... and the master switch wouldn't control them either up or down. So now all of the windows won't work... and the rear window doesn't work either.
    I've replaced the passenger switches (front and back passenger) and all of the fuses are good... tested them and everything. What should I do next? Anyone have a thought? (I haven't replaced the master switch panel yet... hoping that I don't have to do that, because it was good to begin with.)
  28. Jun 24, 2021 at 7:33 AM
    2mchfun
    I think you better be checking fuses again, if sparks were flying, pretty much certain a fuse was smoked, that's the whole purpose of the fuses to begin with. Short occurs fuse blows to stop heat and fire before it starts.
  29. Jun 24, 2021 at 8:54 AM
    icoachem14
    I did check them again, and they're all fine. I checked the ones under the hood and under the dash.
    I also changed out the driver's side switch and have the same issue.
    The back window (which is on a different switch) also won't come down.
  30. Jun 24, 2021 at 8:59 AM
    icoachem14
    I have a wiring diagram (from google images) and it talks about a "junction connector"... could that be it?
    I have also pulled the relays and replaced those in the fuse box, and they still don't come up. So I don't think that's it.
