SOLD: TRD SKID PLATE (2020 TRD Pro take offs)
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by jmladdy, May 28, 2024.
Thread Status:
Not open for further replies.
  1. May 28, 2024 at 7:49 AM
    jmladdy
    jmladdy [OP] New Member
    Oklahoma
    2020 Tundra TRD Pro
    Local (OK) and surrounding states only (TX, NM, CO, KS, AR, MO)
    …unless you want to pay shipping… which will be stupid expensive…
    TRD Front Skid Plate: $300 - SOLD
    Also taken off at 34k miles as it wouldn’t fit with my new suspension and diff drop. Surface rust around front bolts/bracing, but is covered up when installed and can be cleaned off. Scratches and rock chips on the lower center show all the love and character only if you’re under it!
    TRD Fox 2.5 Suspension: $1250 - SOLD
    Taken off at 34k miles. Great condition aside from nicks/scratches/peeling from rocks, washing, etc. Factory leaf springs can be included.
    ColoradoTJ, chugs, V3N0M and 2 others like this.
  2. May 28, 2024 at 7:50 AM
    Slag_Dynamics
    Slag_Dynamics Cut. Weld. Repeat.
    Arizona
    Gone
    Solid deal man. GLWS
    jmladdy[OP] likes this.
  3. May 30, 2024 at 7:11 AM
    hithereitstim
    hithereitstim New Member
    Damn interested in the suspension. Located in Houston.
  4. May 30, 2024 at 7:02 PM
    Drew281
    Drew281 New Member
    Drew
    2017 Sr5 crewmax
    Where you located seller?
  5. May 30, 2024 at 7:39 PM
    Slag_Dynamics
    Arizona
    Gone
    I believe Oklahoma
    jmladdy[OP] and RobertD like this.
  6. May 30, 2024 at 7:39 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    I concur.
  7. May 30, 2024 at 8:07 PM
    blenton
    blenton New Member
    I concurrently concur.
  8. May 31, 2024 at 8:45 AM
    jmladdy
    Oklahoma
    2020 Tundra TRD Pro
    The Great State of Oklahoma!
    RobertD likes this.
  9. May 31, 2024 at 8:48 AM
    713Tundra
    713Tundra New Member
    HTX
    2017 BBP Limited TRD OR CM
    PM sent.
  10. May 31, 2024 at 4:26 PM
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    Damn good deal. GLWS.
  11. Jun 3, 2024 at 6:50 PM
    Garyj
    Garyj New Member
    Jeremy
    2017 tundra TRD Pro
    I am in Okc/ edmond and could come pick them up. Where are you located?
  12. Jun 4, 2024 at 9:44 AM
    jmladdy
    Oklahoma
    2020 Tundra TRD Pro
  13. Jun 18, 2024 at 7:10 PM
    QuikreteTundra
    QuikreteTundra Previously owned '16 Tacoma SR5 Pro
    '21 Tundra Cement TSS OR 4x4 | '23 T4R Lunar TRD ORP
    Does this interfere with a cat shield?
  14. Jun 18, 2024 at 7:16 PM
    RobertD
    Robert
    DFW, Texas
    No, most cat shields will slide between the skid plate and frame.
  15. Jun 19, 2024 at 7:43 AM
    QuikreteTundra
    I will have to double check today and see where my current cat shield is mounted. Mine doesn't look like yours, and the dealership had gotten it installed. It doesn't look very protective because it only prevents the front of the cats from being cut but the rear of the cats are still accessible.
    If it looks like it may fit, I may be interested.
  16. Jun 19, 2024 at 7:57 AM
    RobertD
    Robert
    DFW, Texas
    As long as your cat plate uses those 2 frame bolt hole locations and is smooth (no raised areas) along that front edge. You should have no issues. If you need new bolts to account for the addition of the skid plate, hit up @Talon2006 for his welded nut plate retainer and accompanying bolts. Good vendor and its worth having the nuts welded to a plate and not free. Its hard to fish a hand up there once you have a front skid that connects to the cat plate
  17. Jun 21, 2024 at 4:21 PM
    jmladdy
    Oklahoma
    2020 Tundra TRD Pro
    Let me know if you're interested! I haven't been online recently with work so buys.
  18. Jun 28, 2024 at 5:20 AM
    jmladdy
    Oklahoma
    2020 Tundra TRD Pro
  19. Jun 28, 2024 at 5:29 AM
    Chucksmith07
    Chucksmith07 New Member
    Chuck
    Wish you were closer, I would snag skid plate.
  20. Jul 16, 2024 at 4:38 PM
    luxury4play
    luxury4play New Member
    do you know if it would fit a procomp lifted truck?
  21. Jul 17, 2024 at 7:27 AM
    jmladdy
    Oklahoma
    2020 Tundra TRD Pro
    I unfortunately do not!
  22. Jul 30, 2024 at 7:15 AM
    jmladdy
    Oklahoma
    2020 Tundra TRD Pro
    Price drop: $250
    Please PM if interested. Located in OKC.
  23. Jul 30, 2024 at 7:55 AM
    jtwags
    jtwags Concrete jungle
    League City, TX
    2018 Tundra CM
    Undercover Elite LX, Xact Contour
    Dang, I would take it but I am on the opposite end of Texas from OK, south of Houston.
    jmladdy[QUOTED][OP] likes this.
  24. Aug 20, 2024 at 8:42 AM
    jmladdy
    Oklahoma
    2020 Tundra TRD Pro
    Found a local buyer for the Skid! Thanks to all.
Thread Status:
