SOLD: Rago Fabrication Ditch Light Brackets-So Cal
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by fireman_pete, Jan 1, 2023.
Thread Status:
Not open for further replies.
  1. Jan 1, 2023 at 10:56 AM
    fireman_pete
    fireman_pete [OP] New Member
    Pete
    2021 SR5 Trail Edition
    bulldog93 and Mater like this.
  2. Jan 1, 2023 at 11:51 AM
    Goofinator
    Goofinator New Member
    Bernard
    Hey do these shake or vibrate? I bought a pair of CBI and running a knock off LP9 and the bracket shakes
  3. Jan 1, 2023 at 11:56 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Do you have the hardware for the brackets?
  4. Jan 1, 2023 at 12:27 PM
    18DCTRD
    18DCTRD New Member
    Dave
    Dracut, MA
    ‘18 DC TRD Off Road
    Great deal for that set. I have the same ones, they are rock solid with no vibrating at all and they use the factory hood hinge hardware to mount.
  5. Jan 1, 2023 at 1:00 PM
    fireman_pete
    Pete
    I cant comment on the vibration, as I never installed them. However, when I was doing research, I bought these particular ones as other had said they were rock solid.
  6. Jan 1, 2023 at 1:01 PM
    fireman_pete
    Pete
    As far as I know, there is not any hardware for the brackets. They mount with the factory hood bolts, and then whichever lights you mount come with their own hardware.
  7. Jan 1, 2023 at 5:23 PM
    Tripleconpanna
    That makes sense. PM sent!
  8. Jan 1, 2023 at 5:28 PM
    allen_rubin
    allen_rubin New Member
    Allen
    2016 SR5 TRD 4x4 Crew Max
    King 2.5's with Camburg Uniball UCA Deaver u748 w/ TC Shackle Fuel Hype 17X8.5 10MM 37X12.5-17 BFG KO2 "Stock Gears" Alpha REX Pro Headlight and Tail Lights Custom Carven Side Exit exhaust ADD Front & Rear Bumpers along with Side Steps Westin Topper / Westin Power side steps
    Pm sent…
  9. Jan 3, 2023 at 12:55 AM
    shawn3210
    shawn3210 New Member
    Southern California
    Still available?
  10. Jan 3, 2023 at 7:49 PM
    fireman_pete
    Pete
    Yes they are.
  11. Jan 3, 2023 at 8:02 PM
    allen_rubin
    Allen
    Replied to the PM from the other day
  12. Jan 4, 2023 at 6:48 AM
    USAFx
    USAFx New Member
    Andre
    Port St Lucie, FL
    2021 Tundra Limited - Cement
    PMed.
  13. Jan 5, 2023 at 8:27 PM
    fireman_pete
    Pete
Thread Status:
