SOLD - Kenwood DMX9707S Stereo w/ Wireless CarPlay/Android Auto be
Discussion in 'Marketplace - Other' started by TRDFerguson, Dec 28, 2023.
Thread Status:
Not open for further replies.
  1. Dec 28, 2023 at 8:45 AM
    TRDFerguson
    TRDFerguson [OP] SSEM #99/RGBA #8-ish?/It’s a funny name.
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    For sale: $300 local pickup or $320 shipped, Kenwood DMX9707S Stereo w/ Wireless CarPlay/Android Auto
    This stereo worked great for me, and sounded fantastic with minimal tuning, but I upgraded to a larger screen unit and am tired of storing this one. It has built in Wireless CarPlay and Android Auto (the CarPlay worked flawlessly for me, but never tried AA on it), has 4 camera inputs, and supports SiriusXM with the separate SXV300 tuner (can find these for "free" after rebate). I recommend adding the Maestro RR to maintain steering wheel controls and OEM settings for lighting and whatnot, as well as having on-screen gauges and TPMS.
    I'm located in Chandler, AZ, and can meet within a reasonable distance if you're local. Shipping is available for $20.
  2. Dec 28, 2023 at 8:53 AM
  3. Dec 30, 2023 at 7:18 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Saturday bump!
  4. Jan 3, 2024 at 7:06 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  5. Jan 6, 2024 at 7:53 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Weekend bump
  6. Jan 7, 2024 at 8:12 AM
    bchaase
    bchaase New Member
    Daphne,Alabama
    2015 WHITE TUNDRA TRD PRO
    LOOKING FOR IDEAS
    Interested, not sure which maestro I need
    Want to retain current microphone
    Steering wheel controls
    In dash settings of course
    Backup camera
    What about trim around the HU ?
    TRDFerguson[OP] likes this.
  7. Jan 7, 2024 at 9:28 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I used the Maestro RR (not the newer v2) with the HRN-RR-TO2 harness, but there are several options depending on your year and trim level. If you want to keep/add SXM and retain factory GPS and SXM antennas, there is another set of adapters for that. I do have the Kenwood GPS included that you can just stick to the underside of the dash though. This is the dash kit I used. https://www.amazon.com/dp/B01DFSPUOY
  8. Jan 7, 2024 at 9:56 AM
    bchaase
    bchaase New Member
    Daphne,Alabama
    LOOKING FOR IDEAS
    Was trying to find which harness and maestro I specifically need
    Not seeing the main differences between RR2 and RR
  9. Jan 7, 2024 at 10:00 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    The RR2 has Bluetooth to do config changes and such, but I’ve heard it’s buggy as hell. I ran a longer micro USB cable to the passenger kick panel so I can just pull the radio fuse at the driver kick panel and reprogram as needed that way. This thread covers pretty much everything you need for install: https://www.tundras.com/threads/the-great-hu-install-of-2023.129229/
  10. Jan 7, 2024 at 10:17 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    The RR2 can also be set up with a couple of trigger controls but not sure all the details there. It also uses a USB-C cable…for the two times after install that you might mess with re-flashing it
  11. Jan 7, 2024 at 10:25 AM
    bchaase
    bchaase New Member
    Daphne,Alabama
    LOOKING FOR IDEAS
    Ok so purchases breakdown need to complete :
    HU from @TRDFerguson
    Maestro RR2
    Metra installation kit
    Little bit of patience
    Missing anything ?
  12. Jan 7, 2024 at 10:44 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I didn't see it addressed but you will not be able to retain the current (OEM) microphone with ANY aftermarket HU.
    @TRDFerguson is supplying the microphone for the HU he is offering.
    Simple to install.
    I ran mine from the HU, up thru the driver's side dash speaker hole, up the pillar and headliner.
    Then tuck the wires..
    drs5d8cz_zpsamasmgca_119117003988f7160b971e70890c33aa77b62631.pngxgh0kdg1_zpsryzcfwvu_86bad8b422829792005b33a832a8cbb9b9c7b01d.pngkgqzyv3z_zpsj5y425c1_920eaf4643b10ff04345fef24d97e7c4df781b8f.png
    I have a similar HU Kenwood Excelon DMX906S and I've been happy with it..
    T-Rex266 likes this.
  13. Jan 7, 2024 at 10:45 AM
    bchaase
    bchaase New Member
    Daphne,Alabama
    LOOKING FOR IDEAS
    I'll probably run it to the OEM to completely hide it
    Why can we not splice it into the new HU ?
  14. Jan 7, 2024 at 10:45 AM
    RainMan_PNW
    Casey
    Clark County, WA
    With the maestro unit you will need the appropriate adapter cables as well.
  15. Jan 7, 2024 at 10:46 AM
    RainMan_PNW
    Casey
    Clark County, WA
    The factory mic is powered/amplified. Aftermarket head units don’t support that.
    1lowlife likes this.
  16. Jan 7, 2024 at 10:48 AM
    bchaase
    bchaase New Member
    Daphne,Alabama
    LOOKING FOR IDEAS
    @1lowlife
    How far recessed is the Kenwood from the front of the dash where the existing Hub was flush ?
  17. Jan 7, 2024 at 10:50 AM
    bchaase
    bchaase New Member
    Daphne,Alabama
    LOOKING FOR IDEAS
    Is there a data sheet to find which one ?
  18. Jan 7, 2024 at 10:52 AM
    Scud
    Scud New Member
    San Francisco Bay Area
    2017 1794 Tundra Super White
    Working on it :-)
    Does it have an HDMI input?
    Thanks
  19. Jan 7, 2024 at 10:53 AM
    1lowlife
    DADA
    2014 MGM DC SR5
  20. Jan 7, 2024 at 10:59 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    It does not.
  21. Jan 7, 2024 at 10:59 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    The site @1lowlife linked will list out all the harnesses needed for your year and trim
  22. Jan 7, 2024 at 11:01 AM
    bchaase
    bchaase New Member
    Daphne,Alabama
    LOOKING FOR IDEAS
    Shit. It's like you get one piece of info and get shotgun blasted with more
    Then which of these is it ?
  23. Jan 7, 2024 at 11:02 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    Pardon my dust..
  24. Jan 7, 2024 at 11:03 AM
    bchaase
    bchaase New Member
    Daphne,Alabama
    LOOKING FOR IDEAS
    Not bad at all, thank you sir !
  25. Jan 7, 2024 at 11:04 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    The top one you’d splice wires into the Kenwood harness. The bottom one (I think) would be fully plug and play to the Kenwood, from the black plug shown, but I’m not positive on that part.
  26. Jan 7, 2024 at 11:06 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    It's perfect because you can stabilize your fingertips on that space.
    Having wireless Carplay is awesome and I run my XM off the app on my phone.
    I have the external tuner, but I never use it....
  27. Jan 7, 2024 at 11:08 AM
    bchaase
    bchaase New Member
    Daphne,Alabama
    LOOKING FOR IDEAS
    Had a company truck , used android auto and got spoiled. Changed jobs and now I miss it. Going on a few road trips and would love to ease of use to the nav on the dash and allow the gf to watch movies
  28. Jan 7, 2024 at 12:42 PM
    RainMan_PNW
    Casey
    Clark County, WA
    The bottom one you would then also buy the replacement Kenwood harness from Maestro that allows for it to plug-and-play. The black plug on that Maestro HRTO2 harness would connect to a matching connector on the Maestro Kenwood-specific harness.
    Personally, I’d buy the top one and splice it.
  29. Jan 7, 2024 at 12:52 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    The top one is what I’ve always used. I never looked into the second. Thanks for clarifying
    RainMan_PNW[QUOTED] likes this.
  30. Jan 7, 2024 at 8:17 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
Thread Status:
