SOLD: JBL DSP4086 8-channel amp w/ Tech12V kit JBL audio - $400 shipped
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by RainMan_PNW, Oct 1, 2023.
Thread Status:
Not open for further replies.
  1. Oct 1, 2023 at 9:44 PM
    RainMan_PNW
    RainMan_PNW [OP] "Oz" SSEM #82 RGBA #4 Unofficial Forum Treasurer Vendor?
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    This is set up as it came from Tech 12 Volts to plug-and-play for a JBL audio setup (originally for a 2020/21, but looking at the wiring diagrams, any JBL system 2014-2021 uses the same amp wiring). This amp goes IN-LINE after the factory JBL amp (you will keep the factory amp, just change the mounting of it).
    New from T12V this setup is $489.
    Includes:
    • JBL DSB4086 amp, currently set with the T12V tune except that the master gain was reduced slightly from the +6dB it was shipped with
    • Wiring harnesses for the amp all connected to adapter harnesses for plug-and-play to the factory wiring.
    • 8AWG Power lead wiring to route to the battery, and ground wiring to ground at the lug located under the passenger seat under the carpet
    • Remote sub volume knob with extension cable
    • USB cable for adjusting amp settings (requires Windows PC)
    • USB stick with the amp settings software, and a file with the original T12V tune saved
    • Amp mounting board with screws
    • 60A inline fuse (buyer will need to get their own fuse holder assembly of their choosing)
    • Line level RCA adapters are labeled for the corresponding input channel for easy connection (makes shipping easier)
    • Copy of the instructions from Tech12V. I can also email a copy.
    PM me if you are interested
    E6D78F01-B951-4D55-9E2D-2A639B2884DF_1_105_c.jpg E3848724-3CDA-4EBB-910E-2F5F7CEE3346_1_105_c.jpg E1F2B2E6-3614-48D8-AEA0-6523AB2F1EA6_1_105_c.jpg 27131350-FE3D-47F6-B9FB-992D3B41C729_1_105_c.jpg 07B102D2-F8C8-4676-A59E-AE376ECDC7EB_1_105_c.jpg D0A15C8C-70A8-4B12-8DA4-2EB6BC693B16_1_105_c.jpg
    RobertD, T-Rex266, AZTundra and 3 others like this.
  2. Oct 4, 2023 at 8:04 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Sold
    RobertD and Mater like this.
Thread Status:
