SOLD: Aluminum Tonneau Cover. American Roll Cover: Truck Covers USA $500 -Will fit Crewmax
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by NUMB LOCK, Apr 27, 2021.
Thread Status:
Not open for further replies.
  1. Apr 27, 2021 at 8:54 AM
    NUMB LOCK
    NUMB LOCK [OP] Perpetual Member
    Northern VA
    2016 MGM TRD Pro
    Fox 3" lift, Methods, 35" A/T Baja Boss, Retrax Pro XR, Baja Designs light bar, Warn winch, Chaos Fab Shop tire carrier
    American Roll Cover from Truck Covers USA. $500
    This is about $2000 if bought new.
    Great condition. Nothing wrong with it, just replacing it with a Retrax Pro XR.
    You can cut the rails to fit a Crewmax (refer to pdf).
    This is on my Tundra TRD Pro Double Cab with a 6.5' bed. Roll cover made of aluminum. Have had this on for about 4 years. Has rails for Yakima mounting system (not included). Locks in place every 12 inches. Key included. You will not be able to use the bed track/rail system in order to install this (refer to pictures).
    Minimal leaks at the corners if rain is heavy. Tip - If you park on an incline, park it with the nose of the truck uphill which prevents the cover from leaking into the bed.
    Local pick up only in Northern Virginia. Paypal preferred.
    Here is a link on their web site: https://www.truckcoversusa.com/american-rack-system/
    Thanks for looking,
    Bob I.
  2. Apr 27, 2021 at 2:08 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Good deal on a great cover. GLWS OP.
    Curious why the switch to retrax? Is it just to get an overhead rack?
  3. Apr 27, 2021 at 2:30 PM
    NUMB LOCK
    Northern VA
    2016 MGM TRD Pro
    Yeah, been waiting for Truck Covers USA to collaborate with Yakima for HD Overhaul or Outpost towers. Hoping to go overlanding/camping sooner than later. Patience ran thin during COVID and ordered an Uptop Overland bed rack which fits the Retrax Pro XR rails. Hoping to top it off with a Roofnest Condor XL.
    Bob I.
    RainMan_PNW and Mater[QUOTED] like this.
  4. Apr 27, 2021 at 2:44 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Gotcha. Sounds like a great setup you’re going to have there. Those UpTop racks are sweet
  5. Apr 27, 2021 at 3:01 PM
    NUMB LOCK
    Northern VA
    2016 MGM TRD Pro
    The UpTop should be here in a few more weeks :) Here's some pix of it in use. We used it mainly for mountain bikes on easy trails with the kids. Great cover to keep out the rain and snow. Great for mounting bikes and a Yakima/Thule basket/cargo box.
    biebs96 and Mater[QUOTED] like this.
  6. Apr 29, 2021 at 8:22 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Awesome price for a bomb-proof cover.
    NUMB LOCK[OP] likes this.
  7. Apr 30, 2021 at 1:10 PM
    trucknut
    trucknut New Member
    2021 Cav blue SR5 TRD Off Road
    Wish this was for a CM. I'd head right over from Frederick.
  8. Apr 30, 2021 at 1:18 PM
    NUMB LOCK
    Northern VA
    2016 MGM TRD Pro
    I sent an email to Truck Covers USA. You/someone may be able to buy the side rails for a Crewmax.
  9. Apr 30, 2021 at 1:30 PM
    trucknut
    trucknut New Member
    Ugh, didn't realize you can't use the bed rails. It doesn't even look like you can lower them to a new spot at all.
  10. May 1, 2021 at 7:48 AM
    NUMB LOCK
    Northern VA
    2016 MGM TRD Pro
    Got instructions from Truck Covers USA. You can cut the side rails to fit a Crewmax.
  11. May 1, 2021 at 9:24 AM
    RainMan_PNW
    Casey
    Clark County, WA
    You can get a bracket set to lower the bed rails. That’s how mine is from TCUSA
  12. May 1, 2021 at 9:42 AM
    vng1906
    vng1906 New Member
    Vinh
    dang if you were closer. GLWS
  13. May 1, 2021 at 4:59 PM
    trucknut
    trucknut New Member
    Do you need to drill new holes as part of installing the brackets?
  14. May 1, 2021 at 5:46 PM
    RainMan_PNW
    Casey
    Clark County, WA
    The rail relocation brackets from TCUSA re-use the factory screws and screw into the factory rail mounts. Then they give you new hardware to screw the rails to the brackets, which drops them down about 3”. They aren’t as “robust” as in the original location because you’re not hanging below, but for light duty tie-of they are fine. The tonneau cover itself clamps to your bed lip.
    Picture of the clamp, and the relocated rail below it
    This view shows one of the original holes that isn’t used and the new rail location
  15. May 4, 2021 at 12:01 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Cut it to size! I did and would be happy to walk you through it.
    Free bump!
  16. May 6, 2021 at 9:29 PM
    RainMan_PNW
    Casey
    Clark County, WA
    This cover is $1800+ new - can’t believe someone hasn’t snagged it yet.
    Free bump for the OP
    Mater, NUMB LOCK[OP] and Hbjeff like this.
  17. May 12, 2021 at 5:41 PM
    CoffeeAddict
    CoffeeAddict New Member
    2016 Tundra CrewMax
    I’d buy this today if you were within a few hundred miles of central Texas.
  18. May 12, 2021 at 5:45 PM
    YotaBro
    Calvin
    FL
    Lots of shenanigans.
  19. May 12, 2021 at 6:48 PM
    NUMB LOCK
    Northern VA
    2016 MGM TRD Pro
    YotaBro[QUOTED] and RainMan_PNW like this.
  20. May 12, 2021 at 8:03 PM
    For odd objects like this, bumpers, canopies, etc we usually let it slide.
  21. May 13, 2021 at 5:37 AM
    NUMB LOCK
    Northern VA
    2016 MGM TRD Pro
    RainMan_PNW likes this.
  22. May 13, 2021 at 8:28 AM
    PermaFrostTRD
    Northern NY
    Man - wish you'd ship. I'd love one of these. If you get the urge and consider shipping I'd take it from you
  23. May 13, 2021 at 3:48 PM
    CoffeeAddict
    2016 Tundra CrewMax
    I guess I can’t say dibs if you ship but ditto to PermaFrost.
  24. May 13, 2021 at 3:56 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    There’s gotta be someone driving up the eastern seaboard between here, Tacoma world or ih8mud. Even if you pay for their gas it’d be cheaper than shipping. That cover is in great shape!
  25. May 24, 2021 at 8:11 AM
    CoffeeAddict
    2016 Tundra CrewMax
    Just posting to say if you can box these up, shipping may not be as bad as you think to ship UPS ground. I’m still willing to buy depending on shipping cost. I ran some guesstimates on size/weight through UPS from Virginia to central Texas and it may be ~$150-200. I REALLY want this tonneau but new cost is out of the budget.
  26. May 24, 2021 at 8:18 AM
    NUMB LOCK
    Northern VA
    2016 MGM TRD Pro
    You are behind one other for possible shipping. I'll give you a heads up if things change :)
  27. May 29, 2021 at 1:38 PM
    NUMB LOCK
    Northern VA
    2016 MGM TRD Pro
    Sold. Thanks for all the interest.
    PermaFrostTRD and RainMan_PNW like this.
Thread Status:
