SOLD 2017 Toyota Tundra 4x4 Limited Double Cab Adventure Build, Indiana
Discussion in 'Tundras For Sale' started by blackoutt, Aug 9, 2021.
Thread Status:
Not open for further replies.
  1. Aug 9, 2021 at 5:33 AM
    blackoutt
    blackoutt [OP] YEAH BUDDY!
    Indy
    07 DC Long Bed - Old Man Tan
    OEM+
    2017 Toyota Tundra Limited, just over 60k miles, superwhite 040 on tan heated leather interior, doublecab, 4x4, 5.7 liter, 38 gallon fuel tank, remote start, 2 keys, second owner, clean clear Indiana title in hand. Water pump replaced under warranty recently, no cam tower leaks, mechanically sound. Fat folder of receipts for all work done by previous owner, SDHQ, and myself. Located in Columbus Indiana, fly and drive opportunity from Indianapolis, Louisville, or Cincinnati. PM with any questions.
    Price: $ with everything in the list below included (pictures may be missing some things and show personal items that are not included)
    Cons: For full disclosure. Pinstripes, scratches, rock chips, mud packed in places that'll never get cleaned out, consistent with its intended use but no major dents or body damage. Wheels have superficial rock rash. Front body mount and wheel wells trimmed for tire clearance. Front bumper rubs on headlight filler panels when flexed, "normal" for rubber mounted body with frame mounted bumper but bumper might be mounted a little high. Muffler has internal baffle failure, still sounds fine but it'll rattle if you shake it by hand. Dash panel scratched from cell phone booster mounted on air vent. Topper color match is slightly off and poorly painted over its original burnt red/orange color. Rear seat aux power ports not mounted yet, just loose panel wired in, I haven't decided the best place yet.
    Suspension/Wheels/Tires/Gears/Brakes
    Icon "stage 9"
    Icon 2.5 front coilovers with CDC
    Eibach 700# springs w/ bump stop spacer
    Icon 2.5 Rears with CDC
    Icon RXT leafs set to option 3
    Icon billet upper UCA with delta joints and heims
    LCA cam tab reinforcement with weld beads
    Durobump front and rear bumpstops
    Coachbuilder +1 shackles
    Front sway bar removed (included with sale)
    Energy Suspension steering rack bushings
    5x Method 701 17x8.5 0 offset
    5x 37x12.50r17 Toyo RT (rotated spare through for consistent even wear)
    Spare tire cover
    Nitro gears 5.29 with Auburn LSD rear
    Toytec extended rear brake lines
    ARB rear brake line and ABS bracket extenders
    Armor/Exterior
    TRD Pro grille with color matched surround
    Color matched handles
    Toyota Tow mirrors
    RCI raw aluminum engine and trans skids
    SDHQ sliders w/ grip tape step
    SDHQ ABS guards
    Total Chaos bed stiffeners
    Expedition One Storm Trooper Front Bumper
    Expedition One Dual swingout rear bumper
    Expedition One Roof rack
    Expedition One Geri Cans x2 white (used for water) x2 black (never filled), comes with x1 valve for gravity fed system
    Warn VR-12S Winch
    Factor 55 fairlead and flat link
    Leer Topper with Thule rack 2x locking crossbars included, tilt windows, carpeted interior
    Tailgate bed rug
    ESI Ultimate Taper Seal tailgate seal and other waterproofing
    ESI Ultra cap seal
    Sealed bed for dry/dust free living space
    Lighting/Interior
    2019 OEM TRD Pro LED headlights + harness
    Baja Designs S2 roof rack lights
    SDHQ A-pillar mounts
    Baja Designs XL80 Ditch lights
    Baja Designs Squadron sport R Amber fog lights
    LED rear bumper backup lights with reverse trigger and switchpro switch
    Max Liner floor liners
    Brackateer and Halotron fire extinguisher
    Backup camera relocation with anytime backup camera mod
    Front camera and spare RCA input added
    ICS dash mount
    Blue Sea USB fast charger in dash
    Switch Pro 9100 on SDHQ console mount
    Victory 4x4 console molle panel
    OEM TRD shift knob
    Salex Vehicle OCD center console organizer
    Fyre Flys LED interior and cargo lighting
    Xprite 42" Sunrise bulge light bar
    LED rock lights wired to cargo switch
    FatMat Sound Deadener on rear cab wall
    WeBoost Drive Sleek single phone cell signal booster
    Always hot rear 12V and USB ports for fridge
    Dual USB/Voltmeter in center console
    40 side rear seat delete with 53qt fridge (can easily swap seat back in with a few bolts)
    Inside cap lighting - color change with bluetooth + remote
    Cap hatch glass white LED lighting
    CO detector
    Indoor/outdoor thermometer
    Rear hatch bug screen
    Other
    SDHQ air pump relocation kit
    AFE exhaust dumped before axle (tailpipe included)
    AFE prodry S air filter w/ carbon filter delete
    ARB safari snorkel
    Bully Dog Programmer/Gauges
    ARB single compressor and mount
    ARB Diff breather
    Alt-s diode
    Optima Red Top starting battery
    Blue Sea winch cutoff switch on battery tie down
    Custom bedside track mounts for hi lift and shovel (included in sale)
    Tech12Volts Fortin remote start
    Wood drawer system, sleeping platform/kitchen/storage
    4" memory foam mattress
    Reflectix window insulation
    Maxxfan 12v RV vent fan in bed cap
    SDHQ dual battery tray with washer fluid bottle relocation
    24F AGM house battery
    Noco Genius 2D battery maintainer
    Blue Sea 7610 ACR
    2x 100w HQST solar panels (roof rack flush mounted)
    HQST MPPT Solar Charge Controller with remote display
    Pop n lock tailgate
    Alum oil filter housing
    Fumoto oil drain valve
    Camo trasharoo
    Not pictured but included: Iceco 50 fridge with cover (normally rides on the single side of the back seat with the seat back/bottom removed), queen size 4" tri-fold memory foam mattress with fitted sheet. Trasharoo.
    Not included: Personal items shown in drawers and bluetti power pack in back seat, although I will work with you to provide whatever camping gear you may need to make it turn key, especially if you're wanting to fly and drive the scenic route home!
    Nic146 and B.Ross like this.
  2. Aug 10, 2021 at 7:13 PM
    blackoutt
    Indy
    OEM+
    Whoops, shared album pictures fixed!
  3. Aug 10, 2021 at 7:56 PM
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
    Nice rig OP, GLWS.
    blackoutt[OP] likes this.
  4. Aug 10, 2021 at 9:28 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Beautiful, well appointed truck here folks.
    Good luck with the sale, @blackoutt
  5. Aug 19, 2021 at 11:15 AM
    blackoutt
    Indy
    OEM+
    Offering FREE delivery anywhere from Indianapolis to ---> Eastern Kentucky, Eastern Tennessee, North Carolina, South Carolina or anywhere else reasonably close to this region if deposit received on or before next Thursday August 26th.
    Contact me to setup a video walkthrough and discuss your truck wants/needs, deposit, and desired delivery date.
    Please share to your Tundra groups and friends that may be looking!
  6. Aug 19, 2021 at 11:21 AM
    Piki
    Piki New Member
    2017 Tundra crewmax 1794 TRD
    Nice Rig, good luck with the sale
  7. Aug 19, 2021 at 1:12 PM
    W3agle
    W3agle New Member
    San Diego, CA
    2016 White Tundra SR5 TRD Off-Road
    Wow I love this build. If I had seen this before I bought my truck ~3-4 months ago I'd be taking it off your hands no doubt! Guess I'll just use it as a template for my build. Really like the wheels and tires.
  8. Aug 22, 2021 at 11:06 AM
    blackoutt
    Indy
    OEM+
    Bump price dropped again, lets get this thing moved!
  9. Sep 19, 2021 at 1:18 PM
    blackoutt
    Indy
    OEM+
Thread Status:
