Solar to keep main battery charged
Discussion in 'Outdoors' started by SpeshulED, Aug 26, 2019.
  1. Aug 26, 2019 at 10:29 PM
    SpeshulED
    SpeshulED [OP] New Member
    Sandy Eggo/Chula Vista, So Cal.
    2015 Mag Gry Ltd. CM TRD Tundra
    TRD Pro Grill | AMP Steps | Husky Floor Mats | SnugTop Sportsman Super Sport Shell | 55w 5k HID Headligts | Method Racing NV Bronze 18x9 | BFG KO2 35x12.5r18
    I used to be set on the idea of running a dual battery setup with a solar panel. Now I’m thinking I don’t want the added weight.
    So is it possible to just run a bigger deep cycle single main battery and have it connected to a solar panel to keep it topped off? If so is there also something I can use in conjunction so the battery doesn’t get over charged?
  2. Aug 28, 2019 at 9:38 PM
    SpeshulED
  3. Aug 28, 2019 at 10:47 PM
    P-Factor
    P-Factor New Member
    Yes indeed. You can get deep cycle batteries of various amp hour (ah) capacities and type i.e. AGM, Gel Cell, Lead Acid, Lithium etc. Depending on your load and needs, a single 100 watt solar panel will maintain a 100 ah battery if a good solar charger/controller is used and of course, direct sunlight.
    Renogy makes great solar products and they are located in California. Vrey friendly folks and egar to answer questions regarding your specific needs or setup.
    They also have a 100 watt starter kit which is reasonably priced and may work for you right out of the box.
    https://www.amazon.com/Renogy-Monoc...85F?psc=1&SubscriptionId=AKIAILSHYYTFIVPWUY6Q
    Renogy
    2775 E Philadelphia St,
    Ontario, CA 91761, USA
    TEL: 1(909) 287-7111
    TEL: 1(909) 287-7100
    FAX: 888-543-1164
    (Ask for Robert Young)
    Wallygator likes this.
