Software Update
Discussion in 'Audio & Video' started by Red Five Tundra, Jan 21, 2019.
  1. Jan 21, 2019 at 1:42 PM
    Red Five Tundra
    Red Five Tundra [OP] Red Five Standing By
    Cory
    Las Vegas
    2014 Limited Crew Max
    Just me, for now
    Hello all,
    Just purchased a 2014 Crew Max Limited TRD with 29,000 miles. So stoked to be back in a Tundra again. I previously owned a 2003 Limited and loved every 183,000 miles I put on it.
    Unfortunately the Bluetooth is not working - I read a previous thread regarding getting a software update.
    I am getting the same "Waiting for Bluetooth" the selection is gray and cannot be selected and the truck does not show up on my phone.
    The truck has low miles, but I am told it is not under warranty.
    Does anyone know how much the software update cost?
    Thanks,
  2. Jan 21, 2019 at 1:47 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    WELCOME
  3. Jan 21, 2019 at 2:22 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
  4. Jan 21, 2019 at 2:27 PM
    Red Five Tundra
    Cory
    Las Vegas
    Just me, for now
    Thanks Jeremy. I have tried this as well. But the unit would not let me install the update from the USB - is there a trick to that? I got to the update software on the unit, then I got lost as far as selecting the USB for the download.
  5. Jan 21, 2019 at 2:30 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    I do remember being unsuccessful the first time.. I then tried another usb stick. Hope that helps.
  6. Jan 21, 2019 at 2:32 PM
    Red Five Tundra
    Cory
    Las Vegas
    Just me, for now
    Yes. After reviewing your link - it seems a little more legit than the previous one I did. I will try this out tonight.
    Thanks again!
    jeremyd likes this.
  7. Jan 21, 2019 at 2:36 PM
    Jadoti
    Jadoti New Member
    Central TX
    2017 sr5 5.7l
    Roll n lock, viper remote start, RC 6" lift, 35" Toyos, 1.25" Spidertrax adapters, Bullydog BDX tune
  8. Jan 21, 2019 at 2:53 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    jeremyd[QUOTED] likes this.
  9. Jan 21, 2019 at 2:56 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    I should of mentioned this earlier, I would reset the radio back to default and see how that works before attempting the firmware update.
    General setting
    Delete personal data.
  10. Jan 21, 2019 at 7:27 PM
    Red Five Tundra
    Cory
    Las Vegas
    Just me, for now
    Thanks Jeremy. I did try that as well. Off to try the software update- hopefully it will be successful.
    jeremyd likes this.
  11. Jan 21, 2019 at 7:34 PM
    Jadoti
    Jadoti New Member
    Central TX
    2017 sr5 5.7l
    Updated mine, 10 minutes tops, no issues. Thanks again @jeremyd !
    jeremyd likes this.
  12. Jan 21, 2019 at 8:20 PM
    Red Five Tundra
    Cory
    Las Vegas
    Just me, for now
    Installing now. Forgot to mention the truck did not have the Map SD card when I purchased. I bought an oem one that should be here in a couple days. Will this prevent the update? I guess I will find out.
  13. Jan 21, 2019 at 8:24 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    Not sure on that, If I had to guess, I would say no.
  14. Jan 21, 2019 at 8:30 PM
    Red Five Tundra
    Cory
    Las Vegas
    Just me, for now
    All updated and was able to connect my phone. Thanks. When I receive the SD card I will give it a shot. Right now it just says “unable to read the map SD card” I am hoping that when I put it in it should be good to go. Now I can start with the real upgrades. Thanks again for all the help. Looking forward to contributing to this site.
  15. Jan 22, 2019 at 3:18 AM
    Dano8855
    Dano8855 New Member
    2018 Tundra Limited
    Great information. I was having issues with my phone also and this solved it. Thanks for sharing.
    nj636 and jeremyd like this.
  16. Jan 22, 2019 at 6:46 AM
    Jadoti
    Jadoti New Member
    Central TX
    2017 sr5 5.7l
    I'm probably just pushing my luck, but no chance you'd know how to download the gracenote updates, would you? That would make you a god among men...
  17. Jan 22, 2019 at 6:48 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    @Jadoti sorry brother, I don't
  18. Jan 23, 2019 at 6:00 AM
    tundracap
    tundracap New Member
    NC
    2017 CM Limited 4x4 Silver Sky Metallic
    I did this update yesterday with no issues.
    I assume this is just a system software update and not a maps update? Is this the case?
    I found one link recently where a map update was like $150, which I declined.
    Has anyone tried other map updates, or maps other than from Toyota?
  19. Jan 23, 2019 at 6:59 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    correct. Just for the system, not the maps.
    I would be interested to know if other maps work as well..
  20. Jan 23, 2019 at 8:46 AM
    Red Five Tundra
    Cory
    Las Vegas
    Just me, for now
    I bought the OE184 Micro SD card through Amazon. It was $80.00. Installed it last night and works perfectly.
    Part # 86271-OE184
    soloshairtrigger and jeremyd like this.
  21. Jan 23, 2019 at 8:57 AM
    tundracap
    NC
    Did you notice a difference in the maps to be worth it?
  22. Jan 23, 2019 at 9:23 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    nice ! I just ordered my new one (oe184).
    This is what was in mine from 2014..
  23. Jan 23, 2019 at 9:25 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    @tundracap , Tough question cause you won't know if streets were added or not..
  24. Jan 23, 2019 at 9:41 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    I just ordered the new map update (oe184) from Ebay, 35 dollars, seller is 100 percent feed back, I'll post back after I install it.
    https://www.ebay.com/itm/2017-Toyot...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
    tundracap[QUOTED] likes this.
  25. Jan 23, 2019 at 10:05 AM
    Red Five Tundra
    Cory
    Las Vegas
    Just me, for now
    I did not have one in the truck when I bought it. So I have nothing to compare it to. Seems to be good.
  26. Jan 23, 2019 at 11:17 AM
    jlaval
    jlaval New Member
    Jeff
    2015 Toyota Tundra Crew TSS 5.7
    Just FYI you can buy the latest update, 86271 0E185A on ebay for around 65-70 bucks.
  27. Jan 24, 2019 at 9:11 PM
    Red Five Tundra
    Cory
    Las Vegas
    Just me, for now
    Perfect. Thanks
  28. Jan 25, 2019 at 6:45 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Or use google map for most up to date and traffic through your phone.
    Jadoti likes this.
  29. Jan 25, 2019 at 7:03 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    I just put chocolate milk in my frosted flakes !! Lol
    BrandonL812 likes this.
  30. Jan 25, 2019 at 7:08 AM
    Jadoti
    Jadoti New Member
    Central TX
    2017 sr5 5.7l
    This is the only reason I want an aftermarket Android head unit. Google maps and Waze. Forget these maps with paid updates.
    nj636 likes this.
