Soft spongey brake pedal feel.
Discussion in '2nd Gen Tundras (2007-2013)' started by Clay00019, Oct 8, 2024.
  1. Oct 8, 2024 at 9:10 AM
    Clay00019
    Clay00019 [OP] New Member
    Winnipeg Manitoba Canada
    2011 Dbl Cab TRD Tundra
    Had an annoying brake pedal issue after doing my pads and rotors a few months ago. The problem turned out to be a bent front brake pad upper retainer pin that was causing an outer pad to stick.
    I purchased new front pins/springs kit, cleaned and lubed all surfaces. Much better now, thought I would share as this seams to be a common issue for some Tundras.
    PhotoNerd likes this.
