Soft Rear End with Static Weight
Discussion in 'Suspension' started by DetroitDevo, Apr 23, 2024.
  1. Apr 23, 2024 at 8:11 AM
    DetroitDevo
    DetroitDevo [OP] New Member
    Devin
    2024 Black Metalic Tundra TRD Pro
    Decked system, Leitner Rack, tinting, nothing crazy..... YET!
    Hello, All; I'm happy to be here as a first-time Toyota and Tundra owner. I have a new 24 TRD Pro Hybrid. After searching and reading other comments and posts about this issue, I still find myself a little perplexed and need to reach out to the group.
    I added a Decked system with my camping gear (about 225lbs loaded now), and my Leitner rack with three loaded rotopax and two side boxes with gear (about 200-250lbs), and now the rear end sags about 1.5" to 1.75", so my goal here is to obtain some advice on how to correct.
    I want to level the truck back out, and my TRD Pro already has the factory lift. After calling the dealership they advised me to look at aftermarket as Toyota doesn't have a stiffer spring kit. In my reading, it looks like springs and shocks will need to be replaced, but most of my reading wasn't on TRD Pro's, so I'm not sure how my truck should be upgraded, so any advice would be welcomed.
  2. Apr 23, 2024 at 8:21 AM
    Markus
    Markus Hermitic Member
    Mark
    Boring, MO
    2 1794 Tundys 2014 and 2023 AG TRD
    A few
    Welcome from West MO. Went camping over the week, had some good sag as well. Curious as well what others are recommending/using
  3. Apr 23, 2024 at 8:51 AM
    DetroitDevo
    Devin
    @Mattedfred The front has also come up just slightly (not 1.5") but I had the same issues on my Raptor back in 2022 and was out west camping in Moab and made a B-Line to LA straight to Dever, where I spent the morning getting a new spring-pack installed because my rear approach/exit angle was so bad and they leveled the truck out nicely. My fear is adding in more gear in the bed and toys on top that it will sag even more as we camp/tow. so the goal was to get this firmed up and level when hauling around 1000lbs of camping fridge, goal zero battery bank, luggage etc..
  4. Apr 23, 2024 at 8:53 AM
    terraj66
    terraj66 New Member
    Las vegas
    Stiffer rear springs
    DetroitDevo[OP] likes this.
  5. Apr 23, 2024 at 8:56 AM
    mayan
    mayan One pull a day keeps the engine debris away.
    Mayan
    DFW
    2023 SM Tundra Limited
    It's normal but you can control it if don't like the sag. There are more in depth threads on this but you could check out dobinsons springs they offer different rate springs. This should bring you back to ride height while you are loaded. Once you unload you will have a lot of rake. There is no simple answer since use case varies across owners so only you can decide whats best for your setup. Also our stock springs are dual rate which is why you see so much compression try to stick to stock numbers and if you are stuck read thru the threads relating to 3rd gen suspension lift or just call dobinsons they are pretty smart and will guide you in the right direction.
  6. Apr 23, 2024 at 8:58 AM
    DFS
    DFS New Member
    2022 Capstone Tundra
    Echoing what others have said, call Dobinson or an off-road shop and advise them of your use case and typical static load so they can recommend springs with the correct spring rate to manage your cargo.
  7. Apr 23, 2024 at 9:00 AM
    DetroitDevo
    Devin
    Thanks @mayan & @terraj66 the dealership said the same but could not work with me on that. The biggest question so far was since i have the TRD PRo already with a 3" lift kit from factory is there any options for me without compromising the factory stuff. Meaning if I replace springs do I also have to replace shocks ect.. And the forum searches I have done already don't really address TRD PRo's and even some of the sites I have gone too or most really, have exceptions in their kit (not for TRD PRO) so it's been a bit confusing really.
  8. Apr 23, 2024 at 9:09 AM
    mayan
    Mayan
    DFW
    You wouldn't necessarily have to upgrade shocks since TRD Pro shocks are adequate for most use cases but if your rear end is too bouncy you might want to upgrade to something adjustable. Again dobinsons lol they let you control high speed comp, low speed comp, and rebound. Since you are carrying more mass you need to control it with bigger shocks or better valving/ adjusting shim stack. I would slow down the front rebound and speed up the back till you find a happy spot. If you are gonna go long travel extend the brake lines it's simple and cheap.
  9. Apr 26, 2024 at 7:22 AM
    DetroitDevo
    Devin
    I called them, and they recommended https://dobinsonusa.com/products/dobinsons-rear-coils-springs-c59-845v-c59-845vr/, which I have ordered as I have between 400-450 of static weight with the rack, decked, system I and I all I the gear I in I there I. I appreciate the recommendation. Now, I need to find a reliable shop in my area (Metro Detroit) that installs springs. Even though it's a fairly painless process, if shops are recommended in the Tri-State area (Michigan, Ohio, Ill), I'm all ears since the Dealership will not install aftermarket parts.
  10. Apr 27, 2024 at 1:51 AM
    wing-2
    wing-2 New Member
    I added Airlift Air bags to my SR5 TRD Off Road. The weight of my fiberglass cap made the rear sag a bit. Pathetic. Really pathetic with a trailer. The Airbags cured it. Definitely notice a stiffer ride. More truck like.......
