Soft rattling noise from passenger side.
Discussion in '2.5 Gen Tundras (2014-2021)' started by smr1619, Jan 27, 2020.
  1. Jan 27, 2020 at 7:20 AM
    smr1619
    smr1619 [OP] New Member
    San Diego
    2019 SR5 Crew Max, 4x4, Cement
    This started a few weeks ago and it sounds like it's coming from the front passenger side. Once my truck is warmed up and I'm driving, I start to hear a slight rattle when I'm pressing on the gas. It sounds like 2 pieces of metal hitting each other, but it's not very loud. I removed everything in my truck that could possible be causing this, but I still hear it. If I'm just coasting, it doesn't make the sound. I tried hitting the gas while I was in part to see if it would make the noise, but it didn't. I'll be taking it in the next couple of weeks.
  2. Jan 27, 2020 at 8:33 AM
    Heat shield by muffler??
  3. Jan 27, 2020 at 9:17 AM
    RollTide82
    RollTide82 New Member
    Michael
    2019 Tundra 4x4
    My passenger window rattles. I let it down a few millimeters and it goes away....crazy. might not be the same problem but a suggestion
  4. Jan 27, 2020 at 9:28 AM
    15whtrd
    15whtrd Mr. Blonde
    Check your intake where it has the inlet cut into the fender. That’s where @Pinay has a rattle.
    Pinay likes this.
  5. Jan 27, 2020 at 9:54 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Thanks for the reminder Sean :angrygirl:
    15whtrd[QUOTED] likes this.
  6. Jan 27, 2020 at 9:54 AM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    I had a loose heat shield on my Camry when it was new and took me forever to figure it out.
  7. Jan 27, 2020 at 9:57 AM
    15whtrd
    15whtrd Mr. Blonde
    Oh it will remind you every time you go off road. Maybe think about getting some weatherstripping that’s made to go on the edge of metal. Similar to the stuff that’s on the rear fender of your truck where they cut it for the new bumper. But just with some rubber insulation on it as well.
    Pinay[QUOTED] likes this.
  8. Jan 27, 2020 at 10:04 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    Like this?
    https://www.tundras.com/threads/humming-rattle-in-cab-when-rpm-1800-2000.20373/page-4#post-1074208
  9. Jan 27, 2020 at 10:21 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    I'm thinking double-sided tape. But better yet, get @CaptSpaulding to come out of hiding and get me the stock intake that he's holding!
  10. Jan 27, 2020 at 1:21 PM
    15whtrd
    15whtrd Mr. Blonde
    https://www.tundras.com/threads/fixed-passenger-side-dash-rattle.60854/
    Here’s another thread to check out
  11. Jan 28, 2020 at 2:16 PM
    smr1619
    San Diego
    Thanks for the replies!!
    15whtrd likes this.
  12. Feb 23, 2020 at 3:04 PM
    smr1619
    San Diego
    Took it to the dealer last week, but they couldn't replicate the sound( figured they would say that). I have another appointment to drive with the shop foreman. I checked all the heat shields and none were loose, but I tightened them all as far as I could and I could still hear it. Going to look in to the other options provided.
  13. Feb 23, 2020 at 3:15 PM
    Sparkyman13
    Sparkyman13 Sparkyman13
    Washington State
    Magnetic grey tundra limited 2016
    Bilstein 5100's, CB 1" Rear, Diode Dynamics SS3 Fog Lights, Goodyear Duratrac 305/55R20
    Is the noise outside the cab? I know i had a rattle and it ended up being the rear seatbelt strap not slipped into the holster thing and it was vibrating against the plastic side panel.
    rebmo likes this.
