Soft brake pedal
Discussion in 'General Tundra Discussion' started by Tundra-XP, Jul 22, 2020.
  1. Jul 22, 2020 at 5:17 PM
    Tundra-XP
    Tundra-XP [OP] New Member
    Will
    2020 Toyota Tundra XP MGM CM TRD Off Road
    Anyone having or had similar issues.
    I purchased Stop Tech slotted rotors along with Power Stop brake pads and had Toyota do the install. I thought the pedal was softer than usual and Toyota felt the same way. They bleed the brakes for me again and it still feels softer than usual but stops fine. They said everything else was fine. Any suggestions out there.
    Thanks
  2. Jul 23, 2020 at 3:05 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
  3. Jul 23, 2020 at 3:43 AM
    timsp8
    NY
    Most likely cause power stop uses ceramic pads. Does it still stop good? Just the pedal feels like it goes down farther? Gets better once warmed up?
    I have power stop rotors and pads. My first stop in the morning isn’t the firmest, but it gets better when they warm up. They do feel like they go down farther than stock, but it stops good. I can tell they are making contact with a slight push. They’ve gotten better after a few hundred miles too.
    Unless you got air in the abs or your pedal sinks when holding it, it’s probably the normal feel for ceramic pads. They will feel softer and need to warm up to get full stopping strength.
  4. Jul 23, 2020 at 6:22 PM
    Tundra-XP
    Will
    It does stop good nd Toyota did mention the fact that they are ceramic and not Toyota pads. It get a bit firmer after longer use. They do go down further thank stock and does stop fine. I even left skid marks when testing them after reading a post on here about the ABS. Toyota bled them twice, all four, says there's no air. They are looking at it again soon. I just might have them put Toyota pads on and check then. No sure I like the feel if this is normal. I'm use to and like a firm pedal.
  5. Jul 23, 2020 at 6:29 PM
    timsp8
    NY
    I think you’ll get used to it, but pads are fairly easy to change. You can do it at home in an hour or so with simple tools. I wouldn’t keep paying Toyota to go back and forth.
  6. Jul 23, 2020 at 6:45 PM
    Tundra-XP
    Will
    True. I would have but I thought it was worth paying them the $120 since I haven't had time to do the job. I appreciate the info. They aren't charging me to look at it to resolve the issue. Now they may for the pads if I so choose. LoL
    TundraGuy68 likes this.
  7. Jul 24, 2020 at 5:21 AM
    TundraGuy68
    TundraGuy68 New Member
    If they don't break in and feel better, try EBC rotors and their Truck /SUV Extra Duty pads. I had the EBC slotted / dimpled rotors and EBC XD pads (all 4 corners) on a Suburban 2500 (hydroboost) and it made the braking about 20 - 30% better and a much firmer pedal feel.
  8. Jul 24, 2020 at 5:34 AM
    timsp8
    NY
    Yeah id like a firmer feel too and will probably try ebc next. I’ve read good things about them. But I needed something and the power stop kit had a good sale when I got it. I’ve gotten used to the feel now. And if I slam on it I know it’ll stop.
